Old 06-12-2004, 08:12 PM   #7351
Registered User
Formula1fan, I use the aps bearings and they work great.I also bought a pack of aps carbide diff balls they weren't that good for the price.
Zach P is offline   Reply With Quote
Old 06-12-2004, 08:39 PM   #7352
The factory bearings rock. When mine wear out I'll probably buy more of them. Several team drivers I know say they perfer the stock bearings to anything made.
psbarger is offline   Reply With Quote
Old 06-12-2004, 09:42 PM   #7353
rc_square24's Avatar
just wonderin, how long do your cars spin without the pinion but w/wheels on?
mine spins for about 13-14 secs.
rc_square24 is offline   Reply With Quote
Old 06-12-2004, 09:50 PM   #7354
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Not bad.....
picco007 is offline   Reply With Quote
Old 06-12-2004, 10:27 PM   #7355
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
the ceramic bearings from RC4less.com are great as well. Ive used them for over 2 years now with out one single bearing failure.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 06-12-2004, 10:35 PM   #7356
picco007's Avatar
EA
How do you take care of them? Have the sheilds stayed in place? That's a great deal if you can make them survive even one year of racing. Tell me what you do to take care of them. thanks
Old 06-12-2004, 10:47 PM   #7357
Team EAM
They are metal shielded bearings. No need to take them out. I just soak them in motor cleaner over night about every month of racing unless its real dusty outside then I will clean them every 2 weeks. If I am on carpet I will be sure to blow the tire dust off them every week. I just use light weight oil to keep them lubed. Finishline racing makes some great bearing oil as well as Zubaks speed products. Which can all be found at rc4less.
Hope this helps!!
EA
Contact Us
Old 06-13-2004, 01:00 AM   #7358
Neil Rabara's Avatar
That's quite long for a belt car. You must be referring to a shaft car.
Neil Rabara is offline   Reply With Quote
Old 06-13-2004, 05:11 AM   #7359
Default Bearings
Hi,
I use the bearings that come standard in the FK-kit. These are the polished ultra low friction bearings. Allmost all team drivers are using them as well as the Serpent team drivers.
In my pro 4 I use Acer racing bearings, and these are superb.
The reason why I don't use them in my FK is that they are very expensive, and don't bring that much extra compared to the FK bearings.
I use Serpent bearing oil to service my bearings. This oil is used in all the X-ray bearings, and works great.
The factory kit diff is allready outfitted with ceramic balls, and a ceramic trust bearing. I use foam pieces in the diffoutdrives to protect my trust bearing against dirt.
840918001 is offline   Reply With Quote
Old 06-13-2004, 06:14 AM   #7360
Formula1fan's Avatar
EA
That sounds like a deal. Do they sell them as a kit or do you have to buy them individually? Thanks
Formula1fan is offline   Reply With Quote
Old 06-13-2004, 07:27 AM   #7361
Robfo's Avatar
You can buy them individually or as a kit. The xray is listed as a set they sell but i don't know if it includes the steering bearings aswell but i doubt it.
Robfo is offline   Reply With Quote
Old 06-13-2004, 09:18 AM   #7362
picco007's Avatar
Hope this helps!!
EA
Thanks EA !!!
Old 06-13-2004, 09:31 AM   #7363
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
Hi guys.
Just to share with you guys.
There is a machine that used ultrasonic waves to clean the jewellery. Guess what? It also is able to clean our bearings.
From my understanding, this machine uses sound wave to break down the dirt and dissolve them.
This is a great way and faster way to clean your bearings.
Furthermore, you do not need to open up the bearings and take risk of causing damage to the housing.
Hope it helps
AdR|aN is offline   Reply With Quote
Old 06-13-2004, 09:46 AM   #7364
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
its called an ultra-sonic cleaner.
any auto electriction or mechanic should have one. best way to clean bearings.
ive cleaned mine in asatone and they come out really good
dontfeelcold is offline   Reply With Quote
Old 06-13-2004, 07:38 PM   #7365
evaa's Avatar
hi guys, need ur inputs on this matter, we just implemented a minimum weight requirement in our races, its around 1530 grams i think. when our xrays were weighed, we were the lightest, barely touching 1400 grams. i added countersunk washers and bath tub tape ti increase my car's weight, however, im still struggling to make the minimum weight requirement.
i'd like to add the weights that xray sells, any inputs on where to put them. im driving an FOC with short arms.
evaa is offline   Reply With Quote
