Old 05-31-2004, 08:19 PM   #7186
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally posted by protc3
i thought i would try to be different,what do you think.
Damn!!!!!!!!! Thats is wild.
ST Racing Concepts (STRC)
Old 05-31-2004, 08:49 PM   #7187
azenis's Avatar
how did u do that? custom made?
now u just need to anodise the bulkheads blue or purple or red or something
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 05-31-2004, 08:50 PM   #7188
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
BMI Racing Carbon Fiber R/C components
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-31-2004, 09:01 PM   #7189
Location: Built By The Racers For The Racers. Corona CA
Red Bulkheads, now that would be sweet!
R/C HEAT is offline   Reply With Quote
Old 05-31-2004, 09:12 PM   #7190
azenis's Avatar
yes it would be sick
i wonder if it can be done?
pity you cant make the spring steel a different color too....
Nige
Old 05-31-2004, 09:18 PM   #7191
scmicromike's Avatar
Send a message via AIM to scmicromike
yes it can be done. a buddy of mine has had it done in red on all alluminum parts. it looks sick!
scmicromike is offline   Reply With Quote
Old 05-31-2004, 09:43 PM   #7192
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
yes it can a racing partner of mine has dark emerald green bulkheads and aluminum parts on his Xray
BHenderson is offline   Reply With Quote
Old 05-31-2004, 09:47 PM   #7193
azenis's Avatar
where would you go to get it done? is it an expensive process?
Nige
Old 05-31-2004, 11:01 PM   #7194
fatdoggy's Avatar
Are the Xray part no. 307214 front lower hinge pins 3mmx80mm? It doesn't give you the exact specs on teamxray.com. The corally pins on my C4 got mangled a week ago and I'd rather replace them with pins that arn't as soft.
Cheers.
fatdoggy is offline   Reply With Quote
Old 05-31-2004, 11:46 PM   #7195
Could someone who knows Joneser let him know he's got PM?
Or, if you see this, Joneser, you have PM.
aviaar is offline   Reply With Quote
Old 06-01-2004, 01:27 AM   #7196
evaa's Avatar
Originally posted by Scrad
I use the FOC rear tower on my short arm conversion. I first just switched arms no setup changes. The car was ok. Pretty close actually. Then I ended up taking out some caster and the car works fine. FYI.
i did the same thing, but i havnt run the car yet. by the way what track were u runnin on? asphalt or carpet? and what tires?
tanx
bukel: back at ya
evaa is offline   Reply With Quote
Old 06-01-2004, 04:37 AM   #7197
Rowdy's Avatar
I wonder if someone could offer me some advice on building xray shocks?
The problem I'm having is that, I can't seem to build them so they have no rebound. I bleed them in the way the manual says to do it and still I have rebound. The only way I can eliminate it is to bleed to much oil out and then I end up with a shock that has air in it.
The shocks are from the xray FK I bought a couple of months ago and I have until now been running them with rebound, but I would like to get them operating properly. I have built xray shocks before but can't remember ever having this problem.
Rowdy is offline   Reply With Quote
Old 06-01-2004, 04:41 AM   #7198
xray racer's Avatar
Trader Rating: 22 (100%+)
hey everyone,
i recently dremeled off every second tooth on my front oneway pulley... and found it WAS better, just wondering if its worth doing this to the pulley aswell???
thanx
robbie
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 06-01-2004, 08:15 AM   #7199
Scrad's Avatar
Trader Rating: 15 (100%+)
evaa, I did that to my rubber and foam car that I race on carpet. I only changed the caster on the foam car. I ran plaid and purple jacos. The rubber car uses CS27's, but by the time I did the short arm conversion my tires were shot and I only had 3 more races left. So I didn't change anything.
Scrad is offline   Reply With Quote
Old 06-01-2004, 10:16 AM   #7200
sands's Avatar
You will always have a little rebound. That is in the rubber cup and the air that is compressing behind it. If you really want to get rid of that, you will need to drill a small hole. (not recomended, unless you want to re-build them more often and risk an oil leak.)
the rebound should be from 1/4 to 1/2 inch and be pretty slow. It doesn't impact the performance of the shock though.
sands is offline   Reply With Quote
