Xray T1
#7052
Originally posted by Neil Rabara
MVP's and Monsters are rpm motors. Your FDR should be alot lower that it is right now. Somewhere in the 7's.
but then again, i'll give your suggested gear ratios a try tom. also, when i ran the 93 and 24 combo i managed only 17 laps, whereas with the 90 and 29 i was able to get 19 laps and make it to the a-main.
#7053
Hi guys! Got some q's about the short arms, I've installed it on my EVOll FOC last night, I noticed that the servo is extending out of the chassis now by 10mm (approx.). Is it supposed to be like this? I'm using a KO PROPO PDS 2143 servo if that helps.. Thanks in advance!
#7054
rcprix, you are probably using the wrong holes. You should be able to find another set closer to the center. My servo hangs out about 5mm.
#7055
#7056
On my car my servo is out 8mm, Is this normal? If I go next hole in the Arm of the steering will be at a angle....
#7057
True, You could be okay as long as the travel is not binding and you get the full range right and left. On my setup, I have 2mm shims between the servo tabs and the mounting posts to free up the movement and move the servo inward.
#7058
Hey guys, a few FT questions. I just sold my Evo 2 and placed my order for FT kit. I'm definatly going to need a front ball diff since the FT kit doesn't come with one and I'm trying to figure out which one I need.
305002 - Ball Diff. With Labyrinth Dust Covers - Factory kit
or 305001 Ball Diff Spring Steel Set
Which is better? According to the X-Shop information 5001 comes with carbide diff balls, new axial ball bearings with larger balls. The facotry team diff comes with all the same stuff right? The FT diff is cheaper as well, but I just wanna make sure I order the best parts....
#7059
The spring steel diff is a little on the heavy side.
#7060
Cell phone pics of my new "whip". BMI staggered Chassis.
#7062
#7063
It looks like 305002 (FK) will has the lightened outdrives and will match the rear one. The other is made with the spring steel and is more stronger and heavier than the FK one.
Any other parts I should pick up while I'm ordering things? I hope Ashford has the diffs in stock, but if they don't I'm going to be ordering direct from serpent and with their outragous shipping fees I wanna make sure I cover everything! I just sold a Evo2 with short arm conversion so I think I have most of the spares covered, but is there anything odd I should pick up?
#7064
Thats what I was thinking, thanks. Does the 305002 include the carbide diff balls and thrust bearings? I want to copy the rear diff exactly to make this car smooth as butter. Considering how good my Evo 2 was with just the normal diffs, I have a feeling that its going to make me happy.
#7065
