Old 02-16-2002, 11:08 PM   #691
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by Buster Bennett
Congrats Trip!
But, You are missing a screw on the front bumper, the one that is underneath the car. I have Xray vision you know
What batteries are those? I know they are SMH, but what brand?
Buster- are you viewing the post on a black n white monitor? the cells look blue to me!! jk
dtm is offline   Reply With Quote
Old 02-17-2002, 12:15 AM   #692
Joe
Joe's Avatar
Originally posted by dtm
RCCadet...... did you ever recieve that 'prize' everyone was supposed to get for filling in that questionaire??? I'm still waiting for mine!!
Hmm, I'm still waiting for mine too...
Joe is offline   Reply With Quote
Old 02-17-2002, 12:56 AM   #693
Buster Bennett's Avatar
Send a message via AIM to Buster Bennett
Black and White Monitor? What is that? I thought gray was the only color, just different shades.
Actually my flat screen monitor is not the best at displaying proper colors. Guess I need to figure out how to get it to.
As far as the Xray prizes, there is still one more Big Prize that needs to be giving away, and there are still people entering the prize thingy, so after that, you all should start seeing your prizes show up.
Buster Bennett is offline   Reply With Quote
Old 02-17-2002, 05:46 AM   #694
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Originally posted by Trips
DG, you probably remember that I worked with Ralph for a couple of months at Mike's in Carrollton before he left to go to Serpent USA... we're still in touch, but I haven't told him that I got the car yet... I'll be talking to him after the Ft. Myers race this week, maybe we can come up with a good "low grip crappy old carpet" setup for the car... LOL
Trips
LOL!! So you will need the WornOutCarpet Nationals Setup. I have never run on carpet so I need a winning setup for when I do go to KinetixRC is Austin.
I do recall many faces during the RB era at Mike's. Hard to keep track any longer. I can walk in there today and he has new faces and talent.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 02-17-2002, 06:02 PM   #695
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Buster-
You got the Piston Parts for the X-Ray Shocks that get stripped out sometimes? I was building my car this weekend and my Wifes Hafl Brother and Friend (6 years old) had Fun changing the piston numbers but didn't know not to turn it less then 3 times so they stripped out two of the pistons. I wish I never showed them that part about the shocks. Also I lost the part that goes on the end of the Shock Shaft. I guess it would be a ball end. Coming in tomorrow to stock up .
Mike Webb
mike_Webb is offline   Reply With Quote
Old 02-17-2002, 08:02 PM   #696
Peter Busch's Avatar
R/C Tech Charter Subscriber
Are you guys doing anything to your blue seal HQ bearings before you put them in. They seem to roll pretty hard or do they just need to break in.
Peter Busch is offline   Reply With Quote
Old 02-17-2002, 08:10 PM   #697
Mike, I should have them. I will see you tomorrow. I am there from 2-9pm.
spongebob,
Remove the seals, they "pop" out VERY easily! I am soooo glad they do! Then soak them in motor spray, and then spray them out afterwards. Then replace ONE of the seals, put a drop of a light weight bearing oil and spin the bearing. Then you can replace the other sheild.
I personally run both shields on the Diff Block bearings, but I do not use the shieds on the INSIDES of the front steering block and the rear upright.
If you want them to be REALLY free, you can remove 6 of the balls. Every other one. But this should only be done for big races, or if you don't mind replacing them more frequently. I SURELY WOULDNT MIND!!! hehehe Just Kidding!
Let me know if anything is not clear.
Old 02-17-2002, 08:33 PM   #698
Ok, thats what I thought, just wanted to check.
Another question, How do those aluminum shock seals go on the shocks? Is the bladder supposed to fit inside the seal because if it is it needs to be trimmed down.
Old 02-17-2002, 08:38 PM   #699
Trips's Avatar
Trader Rating: 16 (100%+)
I had the car working REALLY well on the carpet today, TQ'd by a lap and won the main even tho my motor went real soft on the third lap...
I used to race at FinishLine, "David F". I always pitted alongside the little white building with Neil... I was running a Shumacher Axis and then a Corally AGLE that summer.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-17-2002, 08:51 PM   #700
Another question, How do those aluminum shock seals go on the shocks? Is the bladder supposed to fit inside the seal because if it is it needs to be trimmed down. [/B][/QUOTE]
Still probably the best place to read about the shock building.
http://www.ashfordhobby.com/tech02.h...ock%20building
Old 02-18-2002, 12:14 AM   #701
Thistle's Avatar
Send a message via MSN to Thistle
Well, I received and built my car, and had my first race with it today. Overall, I'm very impressed. I did have a couple of problems though...Has anybody else encountered this:
1> No tire inserts???
2> Top portion of shock piston fits too loose. (No external adjustment is possible on my rear shocks. Both piston halves spin on the shock shaft)
Thistle is offline   Reply With Quote
Old 02-18-2002, 08:14 AM   #702
mike_Webb's Avatar
Thistle-
The X-Ray does not come with Inserts for the Tires. The shocks not being able to adjust is a good sign that you stripped out the Male Piston on the shocks. It is no big deal if you don't mind opening and redoing your shocks every tiem you want to change how many holes are open or you can do like this website suggest
http://www.ashfordhobby.com/tech02....hock%20building
and super glue only the male part only to the shock shaft.
Mike Webb
Old 02-18-2002, 03:50 PM   #703
mike_Webb's Avatar
Buster-
Thanks for the parts and the Set-up Board.
Anyone have a setup for Carpet track with Foams racing Stock Motors?
Also Anyone here from Manila? Any good tracks around there? I am going to be there for two weeks. Also is it pretty safe for Americans to be walking around Manila if I were to bring my car?
Mike Webb
Old 02-18-2002, 04:43 PM   #704
Thanks for the link to the shock site. I figured out how they are supposed to go together, (aluminum shock seals) but there is no way to get the plastic shock top to fit inside the rubber bladder with the aluminum seals in. Has anyone actually put these in?
Old 02-18-2002, 07:07 PM   #705
Trips's Avatar
My Xray felt pretty dialed on the carpet this past Sunday, I TQ'd by nearly a lap over the guy who had been out-qualifying me in my Losi for the past 3 weekends, and won the main.
I built the kit to the standard setup in the manual except the following differences:
front anti-dive: 0 degrees
rear toe: 2 degrees
Corally 20wt shock oil f&r
Associated Red (22lb.) TC3 rear springs
Center oneway: loose
Camber: -1.5 R, -2 F
Tires: TRC Plaid F, TRC Purple R
Batteries: rear
I think the car can get faster, this setup still felt very easy to drive, and I notice that my cars tend to feel a bit more hectic when the setup is really fast.
MARSHAL!!
