Xray T1
Old 05-03-2004, 11:04 PM
  #6886
Neil Rabara's Avatar
Originally posted by SalvadoriRacing
what's the smallest spur gear that fits the xray??? (by rising up the motor, the belts can touch the can)
With the new factory kit, you could go as low as 124 64dp. With the standard evo2 pulleys, 116 64dp.
Neil Rabara is offline
Old 05-03-2004, 11:10 PM
  #6887
SalvadoriRacing's Avatar
neil,
i'm running the old Xray T1 with 48 pitch gears....
SalvadoriRacing is offline
Old 05-04-2004, 01:06 AM
  #6888
NKriptD's Avatar
Could someone explain the difference between a ball diff and a one way. And what are the advantages/disadvantages of each. Sorry i am a retard!
Thanks!
NKriptD is offline
Old 05-04-2004, 03:17 AM
  #6889
evaa's Avatar
Originally posted by gido
I believe you can use the AE Springs. However, the Xray springs are the most appropriate.
tried on the ae springs, yep they fit, the losi springs too, but they are kinda large.
x-ray springs cost a bundle here, will probably stick to ae ones.
evaa is offline
Old 05-05-2004, 12:48 AM
  #6890
oldnwise's Avatar
Thanks!
Have a read of http://www.rccaraction.com/rc/articles/oneways.asp.
This article provides a good summary of one way diffs.
oldnwise is offline
Old 05-05-2004, 05:16 AM
  #6891
That's good! At least you don't have to worry that other Xray owners will copy your spring set-up.
gido is offline
Old 05-05-2004, 09:58 AM
  #6892
AdR|aN's Avatar
Anyone have tried a set up with foams on asphalt?
Mind sharing the set up with me?
AdR|aN is offline
Old 05-05-2004, 10:39 AM
  #6893
1shnot's Avatar
Default rear belt
hi guys.....
i've changed to 1.77 pully set and now my rear belt is really loose...............
I've changed the rear bulk to make it tigher but still way too loose
what's up? please help!!!!!!!!!!
1shnot is offline
Old 05-05-2004, 11:34 AM
  #6894
Default Re: rear belt
Originally posted by 1shnot
hi guys.....
This might be a stupid question, but did you also change the pulleys on the center layshaft, too?
Headbanger is offline
Old 05-05-2004, 12:34 PM
  #6895
1shnot's Avatar
YUP..... i did
so what gives?
1shnot is offline
Old 05-05-2004, 12:35 PM
  #6896
rayhuang's Avatar
If youve got a good Carpet/foam set-up-then go down a few lbs on spring rate- add a thin rear sway bar and go from there.
Ray
rayhuang is offline
Old 05-05-2004, 04:31 PM
  #6897
NKriptD's Avatar
Arrow HELP!!
I am trying to build one of the ball diff's on my T1R but am having trouble with the part where you put the set screw(#305040) into the long diff shaft and then you place a small allen wrench through the aligned holes in both pieces.
My problem is when i am threading the long diff shaft down onto the short diff shaft, the two shafts will not come together all the way so that the both the diff washers (#305082) are just touching the diff balls.
The diff pully is wobbly between the shafts and I cannot tighten it any more for some reason. If anyone understands what I am talking about please help me out!
Thanks!
OK one more question...Should the set-screw meet resistance before it is fully threaded into the shaft? When I am threading down it becomes very hard to keep going but is not in the proper position. So do I keep on screwing harder (<~~~ hehe) until its right??
**edit** Yeah, I'm offically stupid!!! Problem Fixed!
NKriptD is offline
Old 05-06-2004, 12:09 AM
  #6898
Default Re: HELP!!
Thanks!
Glad you fixed it. I was going to recommend looking at the thrust washer.
Old 05-06-2004, 05:51 AM
  #6899
oldnwise's Avatar
Default Spare Parts
I'm going to order some spare parts for my Factory Team kit so I have a small stock to cover breakages.
What parts are known to have problems with breaking and needing replacement?
oldnwise is offline
Old 05-06-2004, 06:36 AM
  #6900
theisgroup's Avatar
i would go with front arms, steering knuckles and c-hubs
theisgroup is offline
