Xray T1
Old 04-26-2004, 12:50 PM
  #6841
JDXray's Avatar
I will post the setup alittle later, its alot i guess.
But you think that i should go to harder compund?
JDXray is offline
Old 04-26-2004, 12:51 PM
  #6842
theisgroup's Avatar
Default Re: Question
Originally posted by JDXray
I need help with my spring setup. I am running on carpet with my Xray T1R.
Everytime i take a turn i flip over I put soft springs in the back (White) and Harder in the Front (Blue/Purlpe). Is that setup correct?
Should i add an anti-roll bar?
I even tried fixing it, put everytime i flex the springs the front is softer than the rear, which shouldn't happen. Can someone help me?
Jon
I would try a stiffer setup. Most of the guys here are running light purple to purple spring(xray) and we are running plaid up front and purple in the rear.
theisgroup is offline
Old 04-26-2004, 12:53 PM
  #6843
JDXray's Avatar
Light Purple and Purple Springs? I am not sure what you are talking about. Blue/Purple?
JDXray is offline
Old 04-26-2004, 01:11 PM
  #6844
theisgroup's Avatar
xray springs are color coded. light purple is 30lbs, and purple is 33lbs.
But you could go to xray vip room and look up a setup for josh or alex. these are ususally a good setup to start from.
Old 04-26-2004, 01:19 PM
  #6845
JDXray's Avatar
alright thanks.
JDXray is offline
Old 04-28-2004, 06:24 AM
  #6846
Top of the day to all drivers, I have a problem with my rear shock,
I went to the short arms on my evo2 foc and the shock mount on
the rear arm the outer of the two will not fit the shock end it rubs on the wheel, the factory manual shows to put the shock on the
outer hole what are you guys doing to get it working.
Dr Smooth is offline
Old 04-28-2004, 07:24 AM
  #6847
Johnny J's Avatar
Either move the shock in one hole , or cut the rims down if they are not the right size
Johnny J is offline
Old 04-28-2004, 07:38 AM
  #6848
fatdoggy's Avatar
berger - Orange-Purple/Purple and Orange-D.Pink/D.Pink is pretty much what people run on carpet/ozite in the US. High grip, High wear, Stiff setup, Very fast.
fatdoggy is offline
Old 04-29-2004, 12:05 PM
  #6849
JDXray's Avatar
Default Question
After awhile, can the belt snap?
I see some wear, and fraying on my belts already.
JDXray is offline
Old 04-29-2004, 02:09 PM
  #6850
Neil Rabara's Avatar
The belts will fray along the edges. I haven't seen or heard of anyone breaking a belt.
Neil Rabara is offline
Old 04-29-2004, 02:44 PM
  #6851
JDXray's Avatar
alright i was just curious.
JDXray is offline
Old 04-29-2004, 05:07 PM
  #6852
pucho's Avatar
On the short arms the inner hole is the same as the middle hole on the long arms. To make the outer hole you have to do some surgery with the dremel. You have to cut off the nub and then go into the arm about 1mm you basicaly will end up with a cut out sort of like this \___/ You will also need to trim some material off the hub. You may want to get an additional set of arms to do this to. I hope you understand and I didn't confuse you much.
pucho is offline
Old 04-30-2004, 06:29 AM
  #6853
Thumbs up
Pucho, thanks for the info I thought that the hole was the one that match the middle on the long arm, in the factory instruction
they have the shock mounted on the outer hole but it might
be a error in the printing, did you tried the setup you gave me?
what was the difference in handling?.
Old 04-30-2004, 08:38 AM
  #6854
pucho's Avatar
Im no longer running the Xray but I am still working on them, this was done at the snowbirds to move the shock to a more vertical position and make the rear end more reactive.
pucho is offline
Old 04-30-2004, 10:54 AM
  #6855
Default Personal Transponder
Hi guys! I have an FOC and would like to know where is the best place to mount a personal transponder.
Thanks in advance for your inputs.
gido is offline
