Xray T1
#6766
Trader Rating: 22 (100%+)
thanks for that, the other guys at the track i race at are going to s%it themselves when they see how fast my car will be. hehehehe.........
#6768
now that would be telling.............here you go
FRONT
springs: xray RED
oil: xray 30wt
no kickup
0* toe
middle hole on shock tower
1 hole closed on adjustable shocks
2mm wire swaybar
2mm droop with 63mm tyres
3mm ride height
plastic c-hubs
upper arm on shock toweruter most hole
ackermann standard
short arms
42 shore 26mm wide rears. ellegi (GRP) brand. LIME's should be the same
REAR
springs: xray RED
oil: xray 30wt
no kickup
2* toe in
3rd outermost hole on shock tower
2mm wire swaybar
4mm ride height
plastic c-hubs
inner lower shock position
standard position for the upper arm
short arms
40 shore 26mm wide rears ellgi (GRP) brand. Purples should be the same(i looked at the trinity site to match the shore to the colour)
this setup is very fast at my track, i have fastest lap by about 1/2 a second, 1 of 2 to do 20 laps, but i hold fastest overall time.
next things to change will be, heavier springs, longer wheelbase, 1* toe in on the rear, stand front and rear shocks up a hole. balance the car if its a bit taily or a bit stuck to the track with the rear shock adjustment.
give that a try and let me know what happens
FRONT
springs: xray RED
oil: xray 30wt
no kickup
0* toe
2mm wire swaybar
3mm ride height
plastic c-hubs
ackermann standard
short arms
REAR
springs: xray RED
oil: xray 30wt
no kickup
2* toe in
2mm wire swaybar
4mm ride height
plastic c-hubs
short arms
#6769
this is on a factory kit aswell. if you have an evo2 the only thing different is the rear shock tower, in that case stand them right up. if you dont have them, try the short arms, makes the car easy to drive, you could also then try the long arms one race then the short arms the next to see whats faster and or easier to drive.
#6770
What frame on the shock absorbers on the Xray do you guys recomend ? I have both aluminium and nylon, but I have heard som people saying that the nylon are the best ?
What do you think ?
What do you think ?
#6771
Does anyone have a link for Alex Lopez's set-up sheet for the Nats in Cleveland??
Thanks in advance!
Kevin
Thanks in advance!
Kevin
#6772
I dont have a link but he drove his car AWESOME!! It was really cool to watch.
#6773
does anybody here know of any rc online shops that currently have the xray factory kit in stock?
thankyou
thankyou
#6774
I still have one left. I am not a hobby shop. email me and I can give you the specifics.
[email protected]
[email protected]
#6775
Thanks in advance!
Kevin
Thanks in advance!
Kevin
https://www.mytsn.com/setups/setup.asp?sid=2219
#6776
thankyou
thankyou
http://www.stormerhobbies.com/
#6777
Lopez was using the long arms in that setup? I've heard rumo'rs he doesn't care for the short arm setup much.
I also noticed Cyrul's setup doesn't appear to be using the short arms? Also, what's up with the battery positions and camber?
https://www.mytsn.com/setups/setup.asp?sid=2374
#6779
#6780
The asymetric camber is used to compensate for different types of corners. Most tracks have one high speed sweeper which will require a different setup then the slower speed stuff.
All setups are a compromise between low / medium / high speed, turn radius, driving line, traction and surface smoothness. It might be perfect on one part of the track, but not on another. good setups are better on most parts of the track while sacraficing as little as possible on the other parts of the track.
The staggared batteries move more mass to the front. This will reduce the amount of weight transfer at throttle lift. Makes the handling more consistent from power on to power off and takes away a bit of steering on entry. If you don't run a BMI chassis - the staggared batteries are the way to go for carpet - makes the car more predictable.
