Old 04-09-2004, 10:45 AM   #6736
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
I was suprised at how little the carpet really got around that stuff compared to the TC3 I drove last year.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 04-09-2004, 11:12 AM   #6737
RandyB's Avatar
yeah those tc3 bearing blow!!! they will grab all the dirt, fuzz, and grim they can find
RandyB is offline   Reply With Quote
Old 04-10-2004, 05:01 PM   #6738
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
bump
BHenderson is offline   Reply With Quote
Old 04-11-2004, 12:02 AM   #6739
centax error!'s Avatar
Default FT
does the FT kit includes swaybars and the turnbuckle tool?
CE!
centax error! is offline   Reply With Quote
Old 04-11-2004, 07:16 AM   #6740
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
no swaybars unfortunatly, turnbuckle tool yes.
Factory Team is excellent. ran mine last saturday, kit setup was faster than previous setup on evo2, and nearly 1/2 sec quicker a lap than everyone else. i ran stock.
dontfeelcold is offline   Reply With Quote
Old 04-11-2004, 11:05 AM   #6741
RCchica's Avatar
Send a message via AIM to RCchica
I really like my factory team kit.
I think it was even easier to build than the FOC evo2.
RCchica is offline   Reply With Quote
Old 04-11-2004, 11:17 AM   #6742
RCchica:
how was the bearings? it says degreased and re-oil with shell???
tnx
Old 04-11-2004, 01:33 PM   #6743
dontfeelcold...are you running on carpet or asphalt??
i run mine this past saturday...and i miss a lot of steering...after some change the car was better but not enought for a feel that i have enought steering i don t have enought steering off power when i m going in a turn...i m running carpet with foam.
and i have some problem issue with the chassis tweak when i hit the bord....i don t have to hit really hard to tweak the chassis....maybe if i put a stand off in the middle of the brace like the T1R it will be better for my twaek problem....what you think about that?
but for the power and overall performance of the belt i was really surprise if i compared to my TC3.....
Pace
Pace72 is offline   Reply With Quote
Old 04-11-2004, 03:45 PM   #6744
sands's Avatar
Pace
Xrays tweeking and needing more turn in is kind of unusual. Most people need to take away steering, not add it. What are your droop settings? Should be about 1-1.5 mm front and 1.2-1.7mm rear.
If the front end is not transitioning fast enough, try thinner front oil or opening more holes.
What is your dual rate at? End points set right?
What is your ackermann set at? Should be inside on the servo saver and in the back holes for the carriers.
As for the tweek - did you bend something? Are all the bulkhead screws tight? What top deck - should be the stiff one. I've never seen a xray tweek before - well, I did break a shock tower once...
sands is offline   Reply With Quote
Old 04-11-2004, 04:49 PM   #6745
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Question for you Xray guys. Which arms does the T1R come with? I heard somewhere they were the 'short' arms, but wasn't sure if that was true or not.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 04-11-2004, 05:00 PM   #6746
Brian, the T1r comes with the long arms, only the new Factory kit comes with the short arms.
TC3er is offline   Reply With Quote
Old 04-11-2004, 05:04 PM   #6747
Thanks. That's what I thought.
USVTA Member #211
Old 04-11-2004, 08:35 PM   #6748
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Pace
i also ran my FK last sat, with t1r tub chassis. now the car is too fast for my slow hands lol
and i need to take away some steering in front too. the rip out of corners is also better than my pro 4 too..
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 04-11-2004, 09:17 PM   #6749
kuanseng1981's Avatar
Trader Rating: 15 (100%+)
Default X-Ray T1 FK
I agree the FK is 1 of the best car X-ray got.
I just change the camber link to the most inside hole and the car rocks the rest of the setting is stock.
And i use this setting for 2 diffence track and the car feels fast and out of coner speed is also the same as a shaft drive car.
But i am scare of 1 thing. the car seems a bit fraglie cause got too many holes but i thing it is not a problem cause it is A X-RAY
Friends come and go,
who's your friend nobody knows,
till the time than it will show,
who is friend who is foe.
kuanseng1981 is offline   Reply With Quote
Old 04-11-2004, 10:42 PM   #6750
new92's Avatar
I decided to race my T1R Friday night at the last minute. I originally went to the track just to break the diffs in and hang out then decided to race it.
My first full pack through it was the first qualifier lol. Box stock it had a HORRENDOUS push....on and off power it was unreal. I swapped one step lower front springs for the 2nd qual and it was marginally better. For the main (B) I went to the yellow springs (softest) and added 2mm of rear droop. It still had a slight push to it but it was manageable. Other than that the car is rock solid and smooth as all get out.
Even with the handling the way it was I ran faster than I have in the past month and a half with my TC3. I am going out some more this week to try and find the set up for my track but overall I am very happy with the car. I think once I hit the setup it is going to be FAST.
Put it through the stress test too with 2 big hits. Either one of which would easily have snapped an arm on the TC3 among other damage. Didn't even throw a setting off on the X Ray. Cracked a TakeOff wheel is about the only thing that happened.
Can't wait to get more into the guts of it and try it out. Going to take some toe out of the rear and possibly stiffen it up a bit to see how that goes.
new92 is offline   Reply With Quote
