Old 04-07-2004, 05:50 AM   #6721
sands's Avatar
Originally posted by TC3Racer67
does anyone have a pic of what the xray servo saver looks like? I never got one with my kit and i'm just using a servo horn from my tc3.
The servo saver is built into the pivot bell crank. Your tc3 horn will work just fine.
sands is offline   Reply With Quote
Old 04-07-2004, 09:34 AM   #6722
Send a message via AIM to Profoxcg
Default thanks for answering my question !!
=) It only takes 2 minutes at most to look up a part number is it even exists.
feel free to post questions on the nitro forum.
Profoxcg is offline   Reply With Quote
Old 04-07-2004, 10:14 AM   #6723
nutfluff's Avatar
Send a message via AIM to nutfluff
Does anyone need a front oneway that I used in my Raycer for approx 12 mins????
I bought the car with thoughts of getting into onroad but can't find the time....
nutfluff is offline   Reply With Quote
Old 04-07-2004, 10:29 AM   #6724
raving-monkey's Avatar
Send a message via MSN to raving-monkey
heres the servosaver/bell crank thingy
(hope it works)
raving-monkey is offline   Reply With Quote
Old 04-07-2004, 07:54 PM   #6725
i want to know if someone can help me with my question!!
i have buy the new Xray FK and it come with a 1-way....but i race on carpet with foam and i need a complete diff for my car....
the part number on the sheet is: 30 5002
i want to know if i ordered that part i will receive a complete diff like the one that come in my box (light outdrive, carbide diff ball, trust bearing and low ratio pulley)??
i really like it and i can't wait to put it on the track!!!
Pace
Pace72 is offline   Reply With Quote
Old 04-07-2004, 08:08 PM   #6726
that part number is for the completed diff...gears, balls and all....at least that is my understanding.
Joneser is offline   Reply With Quote
Old 04-07-2004, 08:09 PM   #6727
stankulas's Avatar
yes you will but i don't know if the set is available
RC America
Xray
Hudy
stankulas is offline   Reply With Quote
Old 04-07-2004, 08:17 PM   #6728
Rob Hochberg's Avatar
Send a message via AIM to Rob Hochberg
Question about the stock blue shield bearings, there is a little plastic thing that holds in all the balls inside the bearing, if I soak these in laquer thinner, will they dissolve? I know that laquer thinner dissolves some plastics, and I don't want it happening to this piece. That would be pretty bad..
Rob Hochberg is offline   Reply With Quote
Old 04-09-2004, 06:07 AM   #6729
RandyB's Avatar
I am not sure if I would soak bearings in thinner! I use lighter fluid it might be a little less ummm hhmmm corrosive??
Has anybody run the new FK kit out doors asphalt yet looking for a set for a long track low bite rubber tires
RandyB is offline   Reply With Quote
Old 04-09-2004, 06:38 AM   #6730
sands's Avatar
It's a metal race, so it won't dissolve. No guaretee on the plastic shields though! You should probably use a less aggresive cleaner or remove them.
Old 04-09-2004, 08:11 AM   #6731
They were ok in the laquer thinner, must be a teflon composite or something I am in need of a good high traction asphalt setup, long arms. THanks for the help in advance!
Old 04-09-2004, 08:23 AM   #6732
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
if those bearings are brand new, why are you flushing them out?
If they are dirty, soak them in metholated spirits, wont hurt them at all.
dontfeelcold is offline   Reply With Quote
Old 04-09-2004, 09:51 AM   #6733
I was cleaning them because I hadn't all carpet season, and they had started to become a little dirty. The laquer thinner works fine, but for anyone about to try it, don't leave the shields on there, I would imagine that they would dissolve.
Old 04-09-2004, 10:02 AM   #6734
I just put a factory kit togetherand the bearings are amazing.
how bad does the lint get when racing on ozite
Old 04-09-2004, 10:42 AM   #6735
RandyB's Avatar
Not bad at all the seals are real good. I ran my evo2 on carpet last year
