Old 04-06-2004, 03:46 PM   #6706
Rob Hochberg's Avatar
Send a message via AIM to Rob Hochberg
Originally posted by sands
i was a goalie too. Got capped once by a guy that was clocked at 110 mph with the ball. I got some knee pads after that... The ones that hurt the most where the glancing shots. Like getting bitch slapped with a baseball bat.
I moved to long stick and took one in the gut. I used to do 300 situps a day - didn't hurt any. I got some respect after that one. hehe. I played outside linebacker in college as well. Most Lax players are soccer wimps - can't hit to save their lives. Kind of fun to clean someones clock once in a while.
Yes! As you all can probably tell from my siggy, I am also a lacrosse player, I play attack, I'm the one who hits goalies in kneecaps and such My shot is about 75... I'm working on it... If I don't go to the away game saturday, I think I'll come.
Rob Hochberg is offline   Reply With Quote
Old 04-06-2004, 06:02 PM   #6707
Default Re: Ok, back to Xrays....
Anybody recomend a good asphalt setup?
I got you covered!!!
hot, south florida setup on asphalt, very good traction
Short arms
Spool (solid axle)
CS27 tires
0 kickup, 3deg caster, 2 degrees of arm sweep
30 wt oil, 2 holes open Front, 3 open in Rear
Front shock pos #2, rear #5, outside hole in arm
Camber link in #1 in Front (long), #1 (short) in rear with 1.5-2.0 millimeter shim under ball, stock pos in rear bulkhead
3deg antisquat, 2 deg rear toe in
low roll center mounts in bulkheads
Blue 22.5lbs springs front & rear
256mm wheelbase
1 deg front toe out
1.5 mil front and rear droop (uptravel)
Mike Dobbs
barnacle is offline   Reply With Quote
Old 04-06-2004, 08:21 PM   #6708
Send a message via AIM to Profoxcg
hi guys,
I wanted to know if this car had CVD in the front, and if you had a part number. I want to know if maybe i can fit them to my S710
thanks !
Profoxcg is offline   Reply With Quote
Old 04-06-2004, 09:04 PM   #6709
sands's Avatar
Default Re: Re: Ok, back to Xrays....
Short arms
Spool (solid axle)
CS27 tires
256mm wheelbase
1 deg front toe out
the front sweep is new to the FT. What does it do for handling?
sands is offline   Reply With Quote
Old 04-06-2004, 09:06 PM   #6710
more entry steering, reacts quicker, gives more high speed on-power steering. all are needed with a spool and rubber tires
Mike Dobbs
Old 04-06-2004, 09:13 PM   #6711
Actually it is not new, you can run it with long arms, just put the shims between the bulkhead and hingepin mount in the rear of the front arm to give you some arm sweep.
Mike Dobbs
Old 04-07-2004, 12:00 AM   #6712
new92's Avatar
Putting together my T1R kit and no problems till I get to the steering rack
Which servo saver do I use for a JR servo? It says to use either 30 2580 or 30 2582 but the savers only have an "F" and a "K" on them?
Thanks guys car is looking awesome so far.
new92 is offline   Reply With Quote
Old 04-07-2004, 12:19 AM   #6713
Neil Rabara's Avatar
You use the one that fits your servo.
Neil Rabara is offline   Reply With Quote
Old 04-07-2004, 12:22 AM   #6714
forty6's Avatar
F = Futaba
K = KoPropo/JR/Sanwa(Airtronics)
forty6 is offline   Reply With Quote
Old 04-07-2004, 12:26 AM   #6715
new92's Avatar
Originally posted by forty6
F = Futaba
Thanks much
Old 04-07-2004, 12:26 AM   #6716
TC3Racer67's Avatar
Send a message via AIM to TC3Racer67
does anyone have a pic of what the xray servo saver looks like? I never got one with my kit and i'm just using a servo horn from my tc3.
TC3Racer67 is offline   Reply With Quote
Old 04-07-2004, 02:39 AM   #6717
Default Factory Question
I just bought the factory kit. I have not received it yet but I have a question:
I believe that the Pivot Balls allow quicker and easier changes in camber and car width. Do you think that using pivot ball supspension on the Factory will eliminate the good handling characteristics mentioned earlier?
Thanks a lot
Alex
alsanico is offline   Reply With Quote
Old 04-07-2004, 04:04 AM   #6718
wrxmy99's Avatar
Factory Kit doesn't come with Pivot balls. And the new FK bulkheads don't have the pivot ball mount points on them anyway so you can't retro fit.
wrxmy99 is offline   Reply With Quote
Old 04-07-2004, 04:49 AM   #6719
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
Default Re: Factory Question
Thanks a lot
Alex
What wrxmy99 is trying to say is get the previous T1 model.
T1 EVO 2 Freedom of Choice.
It comes with both suspension. So you could change to whatever suspension you deem fit.
But since you have ordered it already, test it out.
The T1FK is one hell of a car out of the box.
AdR|aN is offline   Reply With Quote
Old 04-07-2004, 05:50 AM   #6720
wrxmy99's Avatar
Agreed
I just sold my FOC and my Factory Kit is in the mail.
Can't wait
