Old 03-30-2004, 12:51 PM   #6601
rayhuang's Avatar
Hey-you guys with the FTXrays already-please shoot me a part number for the bulkheads please!!! I just dont have the time to drill and tap my stock bulkheads for vertical ballstuds, etc.
Thanks,
Ray
Old 03-30-2004, 01:23 PM   #6602
can someone help me with my question...
i want to know if i buy the new short arm for my Xray T1R i will be able to use the droop screw in the rear with this arm??
i heard that with the T1R and the short arm you have to shim de shock for playing with the droop??
i m running on carpet....and with the tire wear i don t really like to shim my shock everytime!!
Pace
Pace72 is offline   Reply With Quote
Old 03-30-2004, 02:09 PM   #6603
Andrew Swanson's Avatar
Send a message via AIM to Andrew Swanson Send a message via Yahoo to Andrew Swanson
the part # for the new bulkheads is
#302001 = new factory kit bulkheads
Pace 72:
i'm not 100% sure on your question but maybe a carpet guy will post something for you.
hope this helps
Andrew
Andrew Swanson is offline   Reply With Quote
Old 03-30-2004, 02:30 PM   #6604
sands's Avatar
Pace
You don't need to use shock shims to adjust droop. You can use the droop screws with the short arms. The droop adjustment is very sensitive. Something like 1/32 a turn for 0.5 mm droop adjustment.
sands is offline   Reply With Quote
Old 03-30-2004, 02:51 PM   #6605
RandyB's Avatar
how come the ft is so expensive on xray site?
RandyB is offline   Reply With Quote
Old 03-30-2004, 03:10 PM   #6606
Ray,
Just go to the Xray homepage and click on the new car. And look for the download stuff and there are a ton of downloads for the Factory Kit that include the manual, spare parts, option parts, setup sheets and a ton of other useful info.
Brian Anthony is offline   Reply With Quote
Old 03-30-2004, 03:28 PM   #6607
Oasis's Avatar
Trader Rating: 36 (100%+)
Are Xrays slow in stock or is it just mine.. ..same motor/battery combo in different car I'm fast,The guy's at my track renamed my car the slooooray.. what should I check..(it has new bearings,3mm rear belt,1.77 pullys,both belts are run lose)I'm at a loss..
Oasis is offline   Reply With Quote
Old 03-30-2004, 05:29 PM   #6608
XXXkat.....what kind of rollout are you running on the car? One of the knocks on the Xray and the Losi are that they are not as fast in Stock as a TC3. In the last couple of years the Xray has been fast at big races.....Tq'd and won the indoor champs this year...won mod at the snowbirds....won mod at the nats. the car can be fast but you will need to find the setup for it. I went instantly faster with the car and it taught me to drive. Went back to the TC3 when the parts issue was going on and I was faster with the TC3. One of my problems is that I dont know enough yet to understand what changes to make and when. I hate the TC3 so I am looking to go back to the Xray. I want a new chassis though. I want to see what will happen with their testing
I think its funny to see how Ray is getting a little greif about the BMI chassis talk. Dont kid yourself.....I had a team driver tell me to my face this weekend that they started testing these chassis when they found out how many of them were being sold. If Ralph was running and Xray chassis then its amazing how much the chassis and top deck looked like a bmi. I for one was a little ticked to see all the unavailable parts were being run on cars at the indoor champs. It is frustrating to see everything they had that I could not get. Now that the Factory team is out....we are talking about chassis. Its obvious by what the team guys are running that the car needs a thick chassis. I know 2 of the guys in the stock A main were running thick chassis and the two guys in mod were as well. One thing nice about the TC3 is that I am running the EXACT same car that Mike Blackstock is running......yeh...you have to spend some time on the diff cases and drivetrain....then mill the chassis to move the batts but then you are done. I hope that the Xray gets to that point at some time. I absolutely loved the Xray and it looks like it is close to being a finished product but as of now it still needs parts that are unavailable to you and me in order to be super competetive.
Joneser is offline   Reply With Quote
Old 03-30-2004, 06:13 PM   #6609
forty6's Avatar
It would be nice if a company uses production cars and not one offs or special stuff. This way we know that our driving is our only limitation.
forty6 is offline   Reply With Quote
Old 03-30-2004, 06:17 PM   #6610
stankulas's Avatar
I at one time taught as you do about team guys running parts that are unavailable to the public but what you have to understand is that they spend a lot off time on development of parts and make sure that they work before they are releset. some of it works and other times it is plan and simple useless here are some examples
Lopez is running super thin belts in his Xray, man are they nice super slick but when he put a 19T in he broke it, for stock it is terrific but that’s it and you may never see those belts I can see a beginner hitting walls and busting them every run
Juraj Hudys car is nothing like you have ever seen i don't think any parts are ones anyone has seen however he is a test pilot and designer of the car if it works it will available but not till proven
Take the Hpi pro4 when it was tested last year i think it was maybe the year before it was a piece of [email protected]@@ i think it was in the c main it wasn't till all the problems were ironed out that it won and now it is a serious competer
Assoc does have i think still a different hinge pin carriers that changed the anti squat on the car, its something to do with it but i don't remember
and Losi is working on the black belt that is now available but not the bearing dog bones that all the team guys are running
The bottom line is that most team guys are guinea pigs for new parts and they help in the development of new parts after they are proven they are available and if you were racing at there level you would have the same
RC America
Xray
Hudy
stankulas is offline   Reply With Quote
Old 03-30-2004, 07:02 PM   #6611
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
I don't know ROAR rules at all but aren't cars supposed to be available to the public for a big race like that? Wouldn't that include the chassis?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 03-30-2004, 07:23 PM   #6612
Registered User
dr_hfuhuhurr I think you're right about that one ,but I am not 100% positive about it though.
Zach P is offline   Reply With Quote
Old 03-30-2004, 08:00 PM   #6613
that rule only applies to stock racing under roar sanctioning
im almost 99.99% sure of it
Old 03-30-2004, 08:01 PM   #6614
KMW
KMW's Avatar
Xray's are not slow in stock! YGPM.
KMW is offline   Reply With Quote
Old 03-30-2004, 08:02 PM   #6615
KMW
KMW's Avatar
The rule is that all parts and accessories used in stock classes must be available at least 14 days prior to the event...
