Old 03-27-2004, 11:54 PM   #6571
Neil Rabara's Avatar
Default Re: NR
Originally posted by Dr Smooth
Neil, what up my man, I have a question
you had or have the evo2 with the short
arms now you have the factory kit, what is the difference in handling if there is any
the reason why I ask is I just went to the short arms on my evo2 but did not get the time to test it yet, but if there is not much difference in either kit I will not get
the factory, thanks man.
I ran the Factory Kit for the first time tonight in a club race, the car is more stable around corners with less body roll. The new hinge pin locations changes the roll characteristics of the car so be careful for the first lap or two during practice. It is really easy to tune yourself out with all the new modifications (ie 9 positions for roll in front, and 9 more in the rear). The new front linkage position on the bulkhead gives just enough steering while maintaining proper geometry. Love the milled out bulkheads, outdrives and universals. If you are fortunate to have this car, you will be pleasantly surprised at it's "out of the box" performance.
Neil Rabara is offline   Reply With Quote
Old 03-28-2004, 01:39 PM   #6572
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Congrats to Josh Cyrul and the Factory XRay!!! Way to bring it home!
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 03-28-2004, 10:50 PM   #6573
Johnny J's Avatar
I just received me Factory Kit thanks to Speedtech today.
I was just wondering should I soak the bearings? Will it do any damage to the blue bizzo's.
Any other tips, this is my first X-ray and I am impressed.
Johnny J is offline   Reply With Quote
Old 03-28-2004, 11:29 PM   #6574
The blue bearings don't require soaking. You could if you like but it isn't needed.
The servo placement is similar to the T1R. The newer short arms and their holders prevent you from using one of the mounting positions.
Old 03-29-2004, 12:03 AM   #6575
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
By soaking, what do you mean? Wat kinda solution are u using to soak the bearings? And what kinda benefit do you get?
Usually the bearings that come with the kit is already super duper smooth. No work need to be done on the bearings. But you can always service the bearings on a regular basis.
Just my 0.02
AdR|aN is offline   Reply With Quote
Old 03-29-2004, 09:30 AM   #6576
RandyB's Avatar
Soak them in lighter fluid trust me you will be impressed let them sit for about 24hrs
RandyB is offline   Reply With Quote
Old 03-29-2004, 09:46 AM   #6577
AdR|aN's Avatar
IMHO, wont lighter fluid dries up?
What the point if it dries up and there is no lube left on inside the bearings?
It sounds logical and nice, but is it practical?
Old 03-29-2004, 09:49 AM   #6578
RandyB's Avatar
put the bearing in a jar fill jar up with fluid just over the bearings and put the lid on let soak for 24 hrs and presto you got clean bearings.
Old 03-29-2004, 09:52 AM   #6579
Can you please give more details?
Or give a URL for a webpage that has more details?
Glenn Cauley
Ottawa, Canada
GlennCauley is offline   Reply With Quote
Old 03-29-2004, 09:56 AM   #6580
rayhuang's Avatar
Guys,
Dnt forget-if you buy the Factory Team kit and want to run the ultra stiff chassis like Burch, Cyrul, Lopez, etc. check out BMI and Warpspeed on RCtech.
The BMI is 3mil with 3d cutouts to place the bulkheads at stock roll center. The car is stiff as a brick and has batteries moved forward-just like the Factory kit . Actually-BMI had it before XRay did it in production!!!
Ray
Old 03-29-2004, 09:57 AM   #6581
AdR|aN's Avatar
Is this the way to CLEAN bearings or to LUBE bearings?
I usually use Petrol to clean my bearings. Soak it for a few hours and removed it and dry it up. Later add bearing oil to them.
Just my 0.02
Old 03-29-2004, 09:58 AM   #6582
rayhuang's Avatar
Default ULtra stiff Chassis
Again-another pic of the BMI ULtra stiff chassis. Also-for a spell-MIke PUlfer had the Warpspeed Xray conversion in the Top Ten at Nats last week.
Ray
Old 03-29-2004, 10:54 AM   #6583
RandyB's Avatar
Both really I dont usually lube my bearing just use the lighter fluid treatment about once a month works for me.
Old 03-29-2004, 11:35 AM   #6584
forty6's Avatar
Originally posted by rayhuang
Guys,
Ray
I thought Cyrul was running the stock Factory kit at the Nats, wasn't he?
forty6 is offline   Reply With Quote
Old 03-29-2004, 02:22 PM   #6585
How much are the BMI chassis?
They (Cyrul Burch) were running Xray chassis' at the nats.
