Like Tree3Likes
Xray T1
Old 03-21-2004, 11:09 PM
  #6496
AdR|aN's Avatar
Originally posted by Scrad
Also I thought that the Factory kit was going to have a stiffer chassis. It looks like it will be the same as the Evo2. I thought I saw one with only the 6 cells cut out.
IMHO, the 6 cells chassis was a prototype factory drivers was using/testing during the Bird's. The chassis that comes with the FK is the same as the EVO2. As it now comes with the STIFF upper deck, its a good welcome.
AdR|aN is offline
Old 03-21-2004, 11:32 PM
  #6497
Neil Rabara's Avatar
Originally posted by AWOLsoldier
do not buy directly from serpent usa. they are horrible to deal with.
Then try your LHS. Generally, Serpent will fill the Hobby Shops who have been on the wait list for parts. Also keep in mind Xray is producing new cars and is probably pretty busy.
Neil Rabara is offline
Old 03-22-2004, 05:50 AM
  #6498
dontfeelcold's Avatar
Trader Rating: 22 (100%+)
the only new parts for the factory kit are the bulkheads, everything else is hot up parts that now come with the car so you dont have to buy them seperately. Its a shame they dont come with swaybars
dontfeelcold is offline
Old 03-22-2004, 06:13 AM
  #6499
Scrad's Avatar
Trader Rating: 16 (100%+)
Will the blade type sway bar work on the short arms?
Scrad is offline
Old 03-22-2004, 07:27 AM
  #6500
theisgroup's Avatar
blade does not work on short arms
theisgroup is offline
Old 03-22-2004, 07:39 AM
  #6501
wannabee's Avatar
Originally posted by 2000xp8
Is there any other place to get xray parts other than Mytsn?
10 bucks shipping regardless of what is purchased it highway robbery. What are they adding bricks to the package.
www.ashfordhobby.com
Robert is a good guy and will take care of you!
Good luck,
Kevin
wannabee is offline
Old 03-22-2004, 07:44 AM
  #6502
seaball's Avatar
kevin,
where you been? i thought you were gonna run the natty's. jbrake and switzer were doggin' ya. no, not really, they just wanted me to give you hell.
drop me something.
seaball is offline
Old 03-22-2004, 07:57 AM
  #6503
SpeedTech's Avatar
Hi Guys,
We got more Xray spare parts and hop-ups back in stock and we also have the Xray T1R on sale this month for only $199.99
The new T1 Factory kit is due to arrive this Wednesday, and all of you that have pre-ordered should have received your comfirmation email last week
Lastly, I want to thank you guys for your support and helping us get started in carrying the Xray product line
Steve Wang
SpeedTech is offline
Old 03-22-2004, 08:09 AM
  #6504
wannabee's Avatar
Originally posted by seaball
kevin,
drop me something.
YGM brother man!
wannabee is offline
Old 03-22-2004, 11:58 AM
  #6505
Formula1fan's Avatar
I was just reading RC Nitro about the serpent 950r (Man if I won the lottery!), it said that the shocks were up granded and the click was more positive. Did they do the same thing for the Xray?
Formula1fan is offline
Old 03-22-2004, 12:56 PM
  #6506
going to short arms
Hey Motorheads, I am going to the short
arms finally, what should I do with the shock springs should I go softer with the short arms or just run it the way I am running it now with the original arms,
next I run indoor mainly but I am thinking
of running outdoors this summer, what
arms is best for outdoors original or short
thanks Guys.
Dr Smooth is offline
Old 03-22-2004, 05:51 PM
  #6507
Default Re: going to short arms
thanks Guys.
By changing the arms, you are changing geometry. With the geometry changed, your shock setup will be different on the new arms. Just going softer may or may not bring you back to a setup you are accustomed to. In fact, the car will be different with the new arms and you will need to learn the car again anyways.
Old 03-22-2004, 06:29 PM
  #6508
Rob Mincey's Avatar
Default Need help with setup diagnosis... ;)
Sorry for the crosspost. Also posted in "Talkin' to Josh Cyrul."
Here's what's happening:
The car is really planted during right hand turns, but the rear end swings around when turning left, but only about 2 minutes into the race (and keeps swinging out for the remainder of the race during left turns.) Here's what I've checked so far:
Droop is equal right to left in the front and rear.
No bent hinge pins.
No bent shock shafts.
Car is not tweaked according to John Watt's laser tweak board.
Tires are not coming unglued on one side or the other.
Toe and camber are equal right to left.
The only other thing I can figure is that the tires (I'm currently running Take Off 22's) are heating up and getting greasy about 2 minutes into the race. But, if this were the case, why would it only be while turning left? I'm going to switch to 27's this weekend, but I'm not anticipating that this is going to fix the problem.
Any suggestions? I'm about ready to pull my hair out.
Rob
Rob Mincey is offline
Old 03-22-2004, 08:35 PM
  #6509
Default Re: Need help with setup diagnosis... ;)
No bent hinge pins.
Rob
Check your front universals and front one way.
Old 03-22-2004, 10:26 PM
  #6510
Oasis's Avatar
Trader Rating: 38 (100%+)
On the arms I thought that the short arms were for the carpet(I could be wrong)I know from running another car I did not like the short arm setup,made the car way to twitchey on asphalt.
Oasis is offline
