Old 03-17-2004, 10:01 AM   #6451
sands's Avatar
Originally posted by DYNO94
Neal, what pitch gear are you running, how about a starting point for pinion for stock? Thanks.
Neil is correct.
Are you on foams or rubber?
For foams, a good starting point it about a 1" rollout for a Monster. About 1.2" for a torque motor. About .95"-.98 for more bottom end on a monster.
I try to gear for punch, top end and motor temp. the motor should be warm but not hot after the run.
I posted rollout tables are a few pages back. (maybe 10ish?)
sands is offline   Reply With Quote
Old 03-17-2004, 11:59 AM   #6452
Default shock tower
Hi racers, I have the ev02 foc with the stock shock towers and run foams, what
would you suggest do I stay with the shock towers that comes with the kit or
get the other shock towers, what is the
difference in handling? if not what is it for?
I am lazy to stroll through this large list
thank you.
Dr Smooth is offline   Reply With Quote
Old 03-17-2004, 01:10 PM   #6453
Default ceramic bearing
Hi again racers, did any of xray racers try
the ceramic bearing what is your opinion
on these bearing is it worth getting a set
for $114.00.
Old 03-17-2004, 01:57 PM   #6454
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
I bought a used XRay that had them in there. They definately are smooth. Keep them clean and they will run perfect.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 03-17-2004, 02:15 PM   #6455
Originally posted by Neil Rabara
The spurs I use are 64 pitch. I like 64 pitch rather than 48 pitch because of better fine tuning of gearing. As far as a good starting point for stock motors, it depends mainly on two factors: 1) Type of stock motor. Stock motors are generally categorized into three types; torque, midrange, rpm. You would gear up for a torque motor (ie P2K), gear down for a rpm motor (ie monster, outlaw), and somewhere in between for midrange motors (ie P2K2, core). 2) Track size. If the track is short and twisty, then you may want to gear down for better acceleration. If the track is more wide open, then add a tooth or two for better top end speed.
I run the Putnum stock monster, and the gearing would fall between 7.3-7.6 FDR (track dependent).
You figure out the pinion, here is the formula:
[spur/FDR] X IDR = pinion
DYNO94 is offline   Reply With Quote
Old 03-17-2004, 02:19 PM   #6456
I run a monster stock with take offs, I really don't get into rollout, or dr just wanted a pinion & spur for 64 pitch. If you could help, thanks, if not thanks anyway .
Old 03-17-2004, 02:21 PM   #6457
theisgroup's Avatar
Default Re: shock tower
thank you.
for the front, xray sells a foam shock tower. It is made so that you can run your foams smaller. With the stock one, you will not be able to get the right height down to what you would normally run on carpet once your tires get small.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-17-2004, 02:22 PM   #6458
theisgroup's Avatar
even running takeoff rubber, you will want to know final drive. So use the equation that was posted
yang lai
Old 03-17-2004, 02:33 PM   #6459
I don't want to know the final drive, just a starting point.
Old 03-17-2004, 04:06 PM   #6460
sands's Avatar
OK then - what pullys are you running? We need to know or we can't help you. (especially if you won't do the math yourself )
Old 03-17-2004, 05:00 PM   #6461
Neil Rabara's Avatar
If you don't know what type of pulleys, then which car is it? T1R, or Evo2 Freedom of Choice?
Neil Rabara is offline   Reply With Quote
Old 03-17-2004, 05:35 PM   #6462
theisgroup's Avatar
Or if that info is not able to be gotten, then a good starting point for any stock motor on any track would be the recommendations in the xray books you got with the kit.
yang lai
Old 03-17-2004, 06:28 PM   #6463
[QUOTE]Originally posted by Neil Rabara
[B]If you don't know what type of pulleys, then which car is it? T1R, My car is one of the first ever made, updated to evo2. Thanks for your help as it was the only one I solicited. I do not run 64 pitch and was just trying to get a starting point, with out too much trouble, thanks again.
Old 03-17-2004, 06:35 PM   #6464
Default re: final drive
how many tooth 64 pitch are you using? Also, are you running outside bashing or on a track? If your running on a track is it large or small?
jiggamacdaddy is offline   Reply With Quote
Old 03-17-2004, 07:00 PM   #6465
sands's Avatar
Awww hell, run with 128/30.
We're just trying to help. If you answer our questions, we can do better than this.
