Old 03-15-2004, 04:32 PM   #6436
Rob Hochberg's Avatar
Send a message via AIM to Rob Hochberg
If you're that set on using stick packs, then I would have to say that the Xray isn't for you. They do sell a conversion, where you can use side x side packs on one side, but to me, that just seems hypocritical, sice the saddle packs give you the best weight distribution, not to mention that the car was designed with saddle packs in mind in the first place.
Rob Hochberg is offline   Reply With Quote
Old 03-15-2004, 04:43 PM   #6437
Originally posted by AWOLsoldier
If you build it right, the saddle pack can be used as a stick pack.
Not a stick pack that will fit in a F201 mate.
I believe there is a stick pack conversion available from Xray, if it is just for bashing you will not know the difference in handling
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 03-15-2004, 09:49 PM   #6438
Schumie's Avatar
yup! xray release a stick pack conversion for those stick pack racers . . . . .
xray stick pack
..... but again not much batt maintenance can do with stick pack.
Schumie is offline   Reply With Quote
Old 03-16-2004, 07:28 AM   #6439
Wow. That battery mounting kit sure ain't cheap. I guess quality parts do cost a lot....
I will look forward for your reports on the TFK when it finally arrives.
Thanks all for your input.
Supra66 is offline   Reply With Quote
Old 03-16-2004, 08:21 AM   #6440
sands's Avatar
Default Re: Stick Packs
Originally posted by Supra66
Hi! I am thinking about getting the Team Factory Kit. I only run stick packs. I am wondering how does the car (TFK or the Evo) handles on asphalt with med bite in the stick pack battery configuration layout.
Thanks in advance for your input.
If you are just bashing, a TC3 would be a better choice - parts are more available and it will take sticks without a problem.
sands is offline   Reply With Quote
Old 03-16-2004, 08:45 AM   #6441
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
Default Re: Re: Stick Packs
But TC3 aint as tough as XRAY.
Durability aint there to make it a good bashing car.
Just my 0.02
AdR|aN is offline   Reply With Quote
Old 03-16-2004, 01:52 PM   #6442
Default Spur gear
Hi motorheads, question I notice where
I race most guys use 128 spur gear
with stock, what if I am running mod
should I use the same 128 spur? if not
what spur do you suggest with a 12t motor.
Dr Smooth is offline   Reply With Quote
Old 03-16-2004, 01:58 PM   #6443
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
I use a 128 in both mod and stock. Just change your pinion accordingly to the motor and track.
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 03-16-2004, 02:16 PM   #6444
Thanks, will do.
Old 03-16-2004, 06:47 PM   #6445
rough512's Avatar
Default .
xray stick pack
wouldn't that stick pack conversion put the battery rearwards too much? If it is installed such that the stick pack is more forward, would it interfere with the belt?
rough512 is offline   Reply With Quote
Old 03-16-2004, 08:56 PM   #6446
Neil Rabara's Avatar
Default Re: Spur gear
You can use either a 128 or 124 spur for stock or 19T. For modified, I'd recommend only a 128. Why you ask? In order to achieve certain gear ratios, you will have to decrease your pinion size (turn dependent). The smaller the pinion, the closer you need to get the motor to the spur. The closer you get to the spur, the closer your will be to the layshaft pulleys. If too close, both belts may/will rub on the motor. Or worse, the pulley itself rubbing the motor.
Neil Rabara is offline   Reply With Quote
Old 03-16-2004, 10:55 PM   #6447
AdR|aN's Avatar
Default Re: .
The chassis is already prepared to accept either saddle packs or stick pack aka Pro4/TC3. But if your using a stick pack conversion the position of the cells would be something like from a TAMIYA Ta04. If you would want to position the cells a little but more forward, i think the space is sufficient that the belt wont be touching it.
Just my 0.02
Old 03-17-2004, 06:20 AM   #6448
Hay Neil thanks for the info, the reason
why I ask is when running say 12t motor
I would go up on the pinion and with such a large spur I thought that it will not
fit, but I guess not, the next is that the bigger the spur you will get more torque for stock motor, I think I will try different
spur, pinion to find what I am looking for.
Old 03-17-2004, 07:15 AM   #6449
Neal, what pitch gear are you running, how about a starting point for pinion for stock? Thanks.
DYNO94 is offline   Reply With Quote
Old 03-17-2004, 09:43 AM   #6450
The spurs I use are 64 pitch. I like 64 pitch rather than 48 pitch because of better fine tuning of gearing. As far as a good starting point for stock motors, it depends mainly on two factors: 1) Type of stock motor. Stock motors are generally categorized into three types; torque, midrange, rpm. You would gear up for a torque motor (ie P2K), gear down for a rpm motor (ie monster, outlaw), and somewhere in between for midrange motors (ie P2K2, core). 2) Track size. If the track is short and twisty, then you may want to gear down for better acceleration. If the track is more wide open, then add a tooth or two for better top end speed.
I run the Putnum stock monster, and the gearing would fall between 7.3-7.6 FDR (track dependent).
You figure out the pinion, here is the formula:
[spur/FDR] X IDR = pinion
