Old 03-12-2004, 04:33 PM   #6421
Neil Rabara's Avatar
Originally posted by John Fontaine
Neil - I broke one as well, bought another and this one is holding up. I think it's due to the aftermarket bumper I put on (the silver one, well, it was silver when it started...now its got dirt and grime soaked into it..LOL) Now there is no shock into the bumper brace and has hold up for over a year now. If this one breaks, I'll get a nice BMI one.
I've resorted to the composite brace. Woven graphite is pretty and all, but a material with more rebound is better in that area.
Neil Rabara is offline   Reply With Quote
Old 03-13-2004, 07:49 AM   #6422
Default asphalt set up?
Does anyone have a decent setup for asphalt? Im using the long arms, and cs-27 take off's.
jiggamacdaddy is offline   Reply With Quote
Old 03-13-2004, 02:55 PM   #6423
littledog's Avatar
R/C Tech Charter Subscriber
Default Re: asphalt set up?
Indoor or outdoor?high or low bite(traction)?The t1r box stock set up does well on low traction,outdoor asphalt.If that helps.
littledog is offline   Reply With Quote
Old 03-13-2004, 07:14 PM   #6424
JKA
Anyone having a problem with the steering wandering on an EVO2?
In the middle of a race my car started pulling right slightly. I corrected the trim on my radio and it was fine. 5 laps later it starts pulling left... so I take my trim back to where it was to begin with. Then back to pulling right after awhile. Very odd.
I've changed servos and servo arms, nothing worked. I'm guessing that its something in the Servo saver assembly. The only heat (main luckily) that the car didn't act erratic was after I "worked" the servo saver back and forth while holding the servo linkage.
I'm going to tear it down to see what I might see, but thought I would ask if anyone has had similar experiences.
JKA is offline   Reply With Quote
Old 03-13-2004, 07:20 PM   #6425
the track is out door and the traction is mid grip. Also im using the evo2 and running a 19 turn in the car.
Old 03-13-2004, 08:01 PM   #6426
Rob Hochberg's Avatar
Send a message via AIM to Rob Hochberg
My Evo2 FOC actually came with the composite one, and not the woven cf one. Weird...
Rob Hochberg is offline   Reply With Quote
Old 03-13-2004, 08:46 PM   #6427
littledog's Avatar
I've run into that problem and what I ended up having to do is to shim the servo saver to be a little bit more tighter.To do that I removed the 'e'clip and placed a shim in and placed the 'e'clip back in place.This tightens the servo sever tighter.
Old 03-14-2004, 03:00 PM   #6428
Formula1fan's Avatar
Can anyone tell me where to get a 132 or 134 spur gear.
Formula1fan is offline   Reply With Quote
Old 03-14-2004, 04:41 PM   #6429
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
You can get the new PRS prolite gears for TC through www.precisionracingsystems.com I think they have a contact link there and they can direct you to the right place.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 03-15-2004, 08:57 AM   #6430
Default Stick Packs
Hi! I am thinking about getting the Team Factory Kit. I only run stick packs. I am wondering how does the car (TFK or the Evo) handles on asphalt with med bite in the stick pack battery configuration layout.
Thanks in advance for your input.
Supra66 is offline   Reply With Quote
Old 03-15-2004, 12:16 PM   #6431
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
It will handle better then any other cars using stick packs.
But would handle better with saddle packs.
Just my 0.02
AdR|aN is offline   Reply With Quote
Old 03-15-2004, 12:17 PM   #6432
AdR|aN's Avatar
Btw, Supra66, you are better off if you convert all your cells to saddle packs. This way, you could do more stuff with your cells :- ie maintaince and etc.
Just my 0.02
Old 03-15-2004, 01:42 PM   #6433
I would want a council, I want to buy of rubbers for XRay TR1. I must use these rubbers on asphalt, with one inferior temperature to
the 30 degrees.
I would want to buy of the Teams Sorex - Competition SlickTire (24R),
these rubbers I can myself be compared to the Take Off CS22
Chutzpah is offline   Reply With Quote
Old 03-15-2004, 02:05 PM   #6434
AdR|aN
I do understand the benefit of not running stick packs. However, since I do not intend to participate in any sanctioned races and I am just having fun with friends racing on parking lot, stick packs serve the purpose well. Plus my main car is a Tamiya F201 that only accepts stick packs. So it is a big plus to have a tourer that also accept stick packs, like my current Tamiay 414MII. But parts for the 414MII, especially the stock chassis, are hard to come by lately. In addition, I am quite amazed by the quality of the xray kit and with the introduction of the TFK, it may be a good time to switch.
Old 03-15-2004, 02:08 PM   #6435
JusBox's Avatar
Originally posted by Supra66
AdR|aN
If you build it right, the saddle pack can be used as a stick pack.
JusBox is offline   Reply With Quote
