Old 03-11-2004, 06:11 AM   #6391
theisgroup's Avatar
Default Re: Re: question for those that have converted to short arms
Originally posted by sands
That is spring pre load flexing the arms. The lever on the droop screws and arms makes it really easy to flex them.
Ray is correct, do what he said.
Only thing I can add is to check ride height before you start with droop screws, then after too,
thanks guys,
I am setting droop that way, but was on the way to checking equal droop with droop guages when I notice the flex. I usually remove the lower spring mounts when I check for equal droop on both sides. and that is when I saw that the arms were being flexed by the spring preload.
So I assume sands, that the arm flex is normal?
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-11-2004, 07:43 AM   #6392
sands's Avatar
Default Re: Re: Re: question for those that have converted to short arms
Originally posted by theisgroup
thanks guys,
Yup, more so with short arms. The droops screw location also creates a week spot in the arm. You'll notice that that is where most of the flex is.
0.5 mm of lift is about a 1/16th of a turn on the droop screw - very sensitive!
sands is offline   Reply With Quote
Old 03-11-2004, 12:40 PM   #6393
Tor Erik's Avatar
R/C Tech Charter Subscriber
Aftermarket chassis for Xray ?
Anyone who could tell me the difference in the following aftermarket chassis for Xray:
*Xtremeracing ( I like this, just becaus of the blue color )
* BMI ( just black, color )
* Warpspeed ( also, just black )
Are there any that can recomend a chassis for me, I race on carpet indoor, using high traction rubber tires.
Or have any had som problems with any of this types of chassis ?
Tor Erik is offline   Reply With Quote
Old 03-11-2004, 02:43 PM   #6394
MartinSorlie's Avatar
@Tor-Erik: Halla, åssen går'e??
The Warpspeed is delivered in blue, the BMI I think can be ordered in just about any color, and the last one I haven't seen
Martin Sørlie, 1985, R/C since 1995.
TLR - Spektrum
www.teamsmallsize.com
MartinSorlie is offline   Reply With Quote
Old 03-11-2004, 04:15 PM   #6395
RCchica's Avatar
Send a message via AIM to RCchica
Do I know you John?
RCchica is offline   Reply With Quote
Old 03-11-2004, 04:25 PM   #6396
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
The BMI is a 3mm thick chassis and I think a 2mm toplate. It also move the batteries in closer to the middle on the chassis and I think also forward just a little.
The Extreme is colored and everything is pretty much like stock setup but you can get colors.
Not sure on the Warpspeed.
For me I think the BMI is the nicest overall.
ST Racing Concepts (STRC)
Old 03-11-2004, 04:54 PM   #6397
weidjd's Avatar
Just got my warpspeed chassis. Very stiff compared to stock get that and the warpspeed top plate. Ray is a great guy and will help you out.
weidjd is offline   Reply With Quote
Old 03-11-2004, 05:18 PM   #6398
protc3's Avatar
the BMI is a 3mm chassis and top plate.the batteries are moved forward 1/8 inch for a little more front bite and toward the center 1/16 inch.it is incredibly stiff.i also offer front bumper brace and shock towers.i will be making the new style shock towers real soon.all chassis are available in blue,black and titanium colored carbon fiber.
here is a pic of the black with shock towers,bumper brace,chassis and engraved upper brace.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-11-2004, 06:26 PM   #6399
Neil Rabara's Avatar
Will the batt slots be angled to fit the batts? Great looking chassis and towers. Love the bumper brace.
Neil Rabara is offline   Reply With Quote
Old 03-11-2004, 06:48 PM   #6400
protc3's Avatar
yes i do champher the battery slots,however,it is optional for cutting to be flush with bottom of chassis due to having to use foam tape under the battery straps.thanks for the compliments buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-12-2004, 01:01 AM   #6401
arn671's Avatar
Trader Rating: 15 (100%+)
Default xray chassis pricing?
That chassis looks awesome! I wanted to get an idea of what the kit would cost (chassis/upper deck/shock towers/bumper brace) and how long it takes to get a kit from you. Thanks
arn671 is offline   Reply With Quote
Old 03-12-2004, 01:24 AM   #6402
Tor Erik's Avatar
@ Martin Sorlie : Joda alt OK her i Indre ser'u
Ad. color on aftermarket chassis, after talking with the people at Warpspeed ( makes only black chassis now, and blue are sold out ) BMI also only makes black chassis
I am wondering about buying the new Factory car, maybe I should just try the stock chassis before I buy me an aftermarket chassis.
Old 03-12-2004, 01:50 AM   #6403
diesel's Avatar
Default Bumper Upper Holder
Hi guys, i just broke my 2.5mm graphite bumper upper holder (301212). I am thinking of replacing it using the composite one (301217) that comes with the T1 Raycer kit. My question is: Are they compatible? Or are there any other stronger aftermarket options to recommend? Thanks.
diesel is offline   Reply With Quote
Old 03-12-2004, 04:27 AM   #6404
protc3's Avatar
BMI makes a blue,black and titanium colored chassis.they are 79.99 per kit.pair of shock towers is 39.99 and bumper brace is 24.99.all pieces are made from 3mm carbon fiber.again,BMI does not just offer black.feel free to call at 352-544-0463.we have them ready ship today.all colors are in stock.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-12-2004, 04:34 AM   #6405
protc3's Avatar
here is aqua blue
Jason Breiner
BMI Racing
Team Associated
J Concepts
