Xray T1
Old 02-23-2004, 12:54 PM
  #6226
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
They are supposed to but they have been very slow getting the parts.
dr_hfuhuhurr is offline
Old 02-24-2004, 10:35 PM
  #6227
Default max tire width
Can 30mm foam tire fit the T1R rear end with out griding on any parts, like the lower shock mounts....?
What about 26mm on the front without grinding parts...?
vadn1 is offline
Old 02-24-2004, 10:53 PM
  #6228
tel
Jaco 28mm foamies fit fine both front and rear so the 26mm up fron are no problem. Not sure you could clear the shock bottom in the outer hole with 30mm wheels.
tel is offline
Old 02-24-2004, 11:13 PM
  #6229
Default tire width
Is wider better on an outdoor track, not parking lot racing, but black top set up for RC racing only. Would 26mm front and 30mm rear if they fit be over kill, or is 24mm front and 28mm rear good enough. Tires will be for a T1R with novak SS4300 brushless.
vadn1 is offline
  #6230
Tel, get the 30,, with +2mm offset and you absolutely will be fine...
BTW: I just got an EVO2 FOC car with both suspensions for a steal!!! I got to race it last weekend with the C-hub suspension and I love it!!! but I still won't part with my G+'s......
IMPACTPLAYR is offline
Old 02-25-2004, 02:51 AM
  #6231
B4
B4's Avatar
Default Low Ratio Kit
I just ordered the 1.77 low ratio kit. This is for the Evo2 I thought i also needed to replace the centre oneway. I was only able to get this part 305514 and not the solid layshaft. Will that be ok or do i really need the solid shaft.
B4 is offline
Old 02-25-2004, 03:03 AM
  #6232
AdR|aN's Avatar
Default Re: Low Ratio Kit
305514 is the solid layshaft.
CNC-machined solid alu central layshaft. Standard on T1R
AdR|aN is offline
Old 02-25-2004, 03:18 AM
  #6233
B4
B4's Avatar
Default Re: Re: Low Ratio Kit
Just checked Xray's site again and noticed that 305514 doesn't come with any pulleys. This is ok because the one's i need are in the low ratio kit. 305502 is listed as a solid aluminium layshaft on the Xray site.
B4 is offline
Old 02-25-2004, 07:41 AM
  #6234
Does anyone know if X-Ray has a low ratio center one-way pulley out yet, or will they have one.... I kinda like the center one-way myself......
Old 02-25-2004, 09:33 AM
  #6235
SpeedTech's Avatar
Hi Guys,
We have the X-ray Titanium screw kit listed on our website now, and also parts from X-ray should be coming in end of this week. I'll also check with them to see if they have a more updated ETA on the Facotry kit for those of you that pre-ordered
Steve Wang
SpeedTech is offline
Old 02-25-2004, 10:09 AM
  #6236
AdR|aN's Avatar
There isnt any low ratio center one-way pulley. Don think XRAY have any plans for it though. But you could try to email to XRAY and ask them yourself.
You will be surprise sometimes.
AdR|aN is offline
Old 02-25-2004, 10:10 AM
  #6237
AdR|aN's Avatar
Originally posted by SpeedTech
Hi Guys,
Steve Wang
Hi. I am from Malaysia. If i would like to order stuff from your website, how long usually does it take to arrive here?
TIA
AdR|aN is offline
Old 02-25-2004, 08:21 PM
  #6238
Does anyone have a line on a store that has the short arms in stock?
stevent
stevent is offline
Old 02-25-2004, 08:50 PM
  #6239
Ashford Hobby
vadn1 is offline
Old 02-25-2004, 09:00 PM
  #6240
Andrew Swanson's Avatar
To all wondering i talk to hudy on a daily basis and the only parts they were waiting for was the rear shocktower and they got those in today so they will begin packaging the new factory kits most likely the end of this week or start of next week.
Hope this helps inquiring minds!!
Andrew Swanson is offline
