Xray T1
Old 02-19-2004, 02:05 PM
  #6211
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Default T1M
Why the blue chassis...why?
dr_hfuhuhurr is offline
Old 02-19-2004, 03:08 PM
  #6212
sands's Avatar
so long as you keep it right side up - who will know? Better then the butt ugly prissy metal flake that the Barracuda R3 boys are running.
sands is offline
Old 02-20-2004, 03:23 AM
  #6213
Default Sway Bars
Do you guys use the pre-cut bumper foam with transponder space on your Xray Evo2? How do you install the front sway bar when using the precut bumper brace and bumper foam? On the stock bumper brace, there is a groove where you can hold in place the sway bar.
Any help would be appreciated.
Thanks!
gerrych is offline
Old 02-20-2004, 06:20 AM
  #6214
sands's Avatar
I use the blade anit-roll bar. I'm not sure that your idea will work without some modifications. The transponder might not fit either.
sands is offline
Old 02-20-2004, 07:10 AM
  #6215
I hear that...things could always be worse.
Old 02-20-2004, 09:52 AM
  #6216
John Fontaine's Avatar
I wonder if Xray made a switch in bearing producer for them?
History - When I first bought my xray evo 2 after it first came out, the shields popped off very easily. Ralph Burch sent me some high speed bearings as a replacement for free, those shields popped. I switched to Acer (those popped off) than decided on some new xray high speed again. After 10 race days, the bearing shields haven't popped off on any of the bearings. I hope it stays that way. Good props to xray to finally get the problem solved on the popping shields.
John
John Fontaine is offline
Old 02-20-2004, 10:13 AM
  #6217
Trader Rating: 17 (100%+)
Heck, I thought I was the only one who had bearing shields just flying off. LOL!
429racer is offline
Old 02-20-2004, 11:12 AM
  #6218
Andreas_Myrberg's Avatar
Default Ball bearings
Hey,
At Xray we always try to make better products so also with the ballbearings. Are happie that the new ones works better for you.
/Andreas
Andreas_Myrberg is offline
Old 02-20-2004, 11:30 AM
  #6219
rayhuang's Avatar
Andreas-I met your son at the Birds and I gotta say he was very helpful. he pointed me in the right direction on set-up for the Xray w/ short arms as I had no idea what to start with their and he did so willingly-no attitude!!
Doh-Sorry Andreas-you ARE the son!! Thanks for the advice!!
Ray
rayhuang is offline
Old 02-21-2004, 10:03 AM
  #6220
You are more than welcome with the small advice I gave you and I'm happie to do that also next time.
And also, don't worrie, your not the first one that mistaces me for my dad and vice versa
/Andreas
Old 02-21-2004, 11:17 AM
  #6221
KMW
KMW's Avatar
Default Re: Sway Bars
Thanks!
Look back a few pages for a photo of Alex Lopez's car where he's using the plastic brace, new sway bar, and the pre-cut foam bumper with the PT mounted inside--it works fine. Your other option is to cut out the front center of the stock plastic brace so it resembles the pre-cut graphite brace. That would make the PT more accessible, but the plastic may flex too much.
If you're not using a PT then you'll need to mount if somewhere else... Xray has a plastic transponder holder that comes with the T1R, for example.
KMW is offline
Old 02-23-2004, 11:14 AM
  #6222
theisgroup's Avatar
what is the part number for the drive shafts for the c-hubs?
thanks
theisgroup is offline
Old 02-23-2004, 11:41 AM
  #6223
pucho's Avatar
Default Re: Re: Sway Bars
Actually that was not a pre cut bumper that was a custon job
pucho is offline
Old 02-23-2004, 11:47 AM
  #6224
rayhuang's Avatar
pucho-you said you needed to talk to me a few days ago. hers my number!! 1-440-735-0554
rayhuang is offline
Old 02-23-2004, 12:28 PM
  #6225
Does Horizon carry the X ray line of cars?
Homer Allman is offline
