Old 02-06-2004, 03:29 PM   #6091
KMW
KMW's Avatar
Originally posted by sands
on the evo - you could just stick a 3mm spacer in the front pin holder, then insert or take away spacers from the rear pin holder for the same effect. You need to run with 4 of these though.
http://www.teamxray.com/teamxray/pro...&kategoria=450
Wait... wouldn't this change the rear track width?
KMW is offline   Reply With Quote
Old 02-06-2004, 03:53 PM   #6092
Rob Hochberg's Avatar
Send a message via AIM to Rob Hochberg
Here's my setup I'm trying for tommorow and sunday:
Front:
Light-Red springs
40 wt oil, 2 holes open
about .5* toe out
TRC double purple
outermost mounting holes
Rear:
Light-Purple springs
40 wt oil, 1 hole open
2* toe in (yes, I figured it out!)
TRC purple
Almost the outermost shock mounting hole ( I really want this car to rotate in the corner)
93 spur
25 or 26 pinion
Alfa 2.0 body
Anyone have any idea how that's going to feel/how well it's going to work?
Rob Hochberg is offline   Reply With Quote
Old 02-06-2004, 04:33 PM   #6093
Registered User
Default xray factory
hey guys where are you finding info on the factory xray thanks
J FAST is offline   Reply With Quote
Old 02-06-2004, 05:22 PM   #6094
sands's Avatar
Yah, about 4-6 mm or so - but I think the T1R suspension mounts will do the same.
If real car handling carries over, it will loosen the rear end slightly. How much? I don't know. You could put offset spacers in the rear hubs to compensate. Some wsc cars run rear tracks several inches narrower then the fronts.
Any way - when you find the rear toe you like, how hard it is to change doesn't really matter. There are other settings that have a similar impact on over/understeer that toe has.
sands is offline   Reply With Quote
Old 02-06-2004, 07:36 PM   #6095
Default Steering Expo
Hey guys I wanted to give you an update from my testing. I softened the oil to 35 frt. 30 rear shortened the rear camber link by mounting it on the bulkhead rather than the bridge. I set the droop to 2mm front 2.5mm rear ( up travel ).
But one of the best changes I made was adding positive expo on the steering. I ended up with 26% positive. Without it the car did not seem to have much steering response around the neutral point. Is this a Xray thing?? Normally I don't run any expo but two other guys drove the car and said to try it so I did and it really improved the lap times. I know what your thinking " his servo must be slow " but, I run an airtronics 94151 which has an .08 trans @6.0 volts and I believe 90 oz torque so I don't think it's a servo problem. I would really like to know how many of you ( if any )run positive expo. Thanks again for the help. Chris
ccm399 is offline   Reply With Quote
Old 02-06-2004, 07:47 PM   #6096
Default expo
Chris...I never ran any positive expo and I had an Airtronics digital or the KO digital....the Airtronics is .06 and the KO is .07 or .08. I never felt like my car was lazy. Can I ask what you were doing to the monster motors? Send me an email if you want.
[email protected]
Joneser is offline   Reply With Quote
Old 02-06-2004, 08:11 PM   #6097
Default Expo
Hey Eric
I just talked to Wayne and he feels the car isn't setup right. Also, I had to run 90% steering throw to get the car around the tight corners. I don't know whats up with this thing. Oh well talk to ya later.
Old 02-07-2004, 04:18 PM   #6098
The car worked very well with that setup, except i went way softer in the rear, I changed to white springs. The track is very small, and the carpet is too new to have that much traction to stiffen it up. I also got a GREAT deal on aluminum C-hubs, $40 for the entire set! Front and rear! Tell me that's not a good deal!
Old 02-07-2004, 04:57 PM   #6099
Matt04's Avatar
Default Re: xray factory
yeh im woundering the same thing?
Matt04 is offline   Reply With Quote
Old 02-07-2004, 07:52 PM   #6100
scmicromike's Avatar
Send a message via AIM to scmicromike
I dont know where the rest of these guys got their info from but it is all corect. I live like 20 min from I-drive in orlando where the snow birds are and the factory drivers from the UK are there and I spoke to the owner of x-ray,( who I thought was mario, but was told it isn't, it is someone whose name I cant spell) and all of this info has been confermed. Cant wait for the kit.
I will get picks of alex lopez's car up as soon as I can
scmicromike is offline   Reply With Quote
Old 02-07-2004, 08:03 PM   #6101
Matt04's Avatar
is there any actual place where it has all the spec's of the car? and everything listed that is included with it cause by the sound of it so far i want to get it for my second car.
Old 02-07-2004, 08:24 PM   #6102
here is alex"s car. enjoy
Old 02-07-2004, 08:38 PM   #6103
Matt04's Avatar
on my computer it sayd that hte file is corrupt. does anyone else have this problem?
Old 02-07-2004, 09:34 PM   #6104
Oasis's Avatar
Trader Rating: 36 (100%+)
Mine said the same..
Oasis is offline   Reply With Quote
Old 02-08-2004, 12:42 AM   #6105
Schumie's Avatar
The owner of our LHS which is the sole distibutor for xray says the factory xray car is comming soon, in fact few hobbiest here took the reservation already.
Schumie is offline   Reply With Quote
