Xray T1
Old 02-04-2004, 06:45 AM
  #6046
Thumbs up
Antoniop, you tha man thank for the info
again, I realy need to follow the up and up with the Xray but not enough time in a day for me to do that, so I appreciate your help with my questions.
Dr Smooth is offline
Old 02-04-2004, 06:47 AM
  #6047
Rob Hochberg's Avatar
Quick question- Where the servo mounts, with the 2 holes closest to the centerline of the car (the only place mine will fit because of the width) it makes the steering link look like this: / not quite that angle though. I don't think it will be a problem, but I have a lot of ackerman. is anyone else experiencing this problem with a more narrow servo? I'm running the Hitec 925. also, my springs and swaybars are getting here today, where should i set my front swaybar? and what springs to use for carpet? thanks.
Rob Hochberg is offline
Old 02-04-2004, 06:50 AM
  #6048
which sway bar?
True R/C Racing is offline
Old 02-04-2004, 07:08 AM
  #6049
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
3.5 - 4mm? WOW!!! That is thick.
dr_hfuhuhurr is offline
Old 02-04-2004, 07:09 AM
  #6050
Yea it is Really thick. It looks even thicker than that. I held it in my hand and it was Nice. seeing that factory kit built the bulk heads are real nice. But Its made for Carpet though.
Old 02-04-2004, 07:41 AM
  #6051
Nothing wrong with it being made for carpet here...
Carpet is made for munching
and racing
Old 02-04-2004, 07:43 AM
  #6052
if i had a cam i would take pics but no cam....
Old 02-04-2004, 09:45 AM
  #6053
sands's Avatar
Mine does the same, but if you do the geometry math, the angles are too small to really impact the overall throw length or progressivness of the throw. At any rate the apparent change in length of the turnbuckle will be the same for left and right turns. In other words - don't worry about it.
If you have a blade bar - most seem to run from 45* to 90*. Play with it to fix corner over and under steer. Sways are only really good for smooth track (carpet on hardwood/concrete etc). Sways generally don't work well on bumpy tracks though.
See prior post by me and a reply by KMW on the spring topic. I run stiff, but i have a problem with a sometimes twitchy car. (last weekend I ran two laps prior to the race to run off some traction compound and that helped - perhaps I was saucing wrong. I also was running a short wheel base - but went to as long as you can get, that helped as well. I also moved to 2* rear toe per side from a 1* rear toe) Some run soft - but hard cornering may lead to traction rolling.
(as I said in my prior post - this is my 1st season on carpet in like 10 years - lots to re-learn)
BTW, Thanks KMW. I agree with what you said - my other problem is that I am almost always too late to the track on Sundays to get in much practice time - but that's just my lazy fault. LOL
This weekend I'm going to run with one battery pack moved one spot more forward. This should reduce the amount of weight transfer to the front as I transition to power off. Counterintuitive, but if you start with more mass up front, there is less to transer up front when the car de-accelerates. I should be smoother on the transitions. I suspect this will require that I change other stuff too. We'll have to see.
sands is offline
Old 02-04-2004, 10:25 AM
  #6054
MartinSorlie's Avatar
Hey!
I am a noob Xray driver, but I made a nice debut with my Evo2...
Read about it here:
http://www.mytsn.com/publ/publmem.asp?pid=9576
MartinSorlie is offline
Old 02-04-2004, 10:55 AM
  #6055
sands's Avatar
congrats on the win!
sands is offline
Old 02-04-2004, 10:56 AM
  #6056
Thanks Sands!
Old 02-04-2004, 11:05 AM
  #6057
howard hudson's Avatar
Originally posted by MartinSorlie
Thanks Sands!
very nice Martin.. U da man!!!!
howard hudson is offline
Old 02-04-2004, 11:08 AM
  #6058
Thanks again! Too bad I'm not running the Demon anymore, but I guess a Warpspeed Xray kit might find it's way to my workbench
Old 02-04-2004, 11:24 AM
  #6059
kentech's Avatar
Arrow Xray Shock Towers
I see that the new Xray Factory Kit might include some new rear shock towers that I have to say look very much like some that are already available...
Check http://www.atheenaprojects.com to see the original...
kentech is offline
Old 02-04-2004, 11:28 AM
  #6060
Hi Kentech, I met you at the Nordics didn't I?
Those shocktowers look brilliant!!
