Old 01-28-2004, 04:26 AM   #5941
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
do you need different hingepins and servo posts for the short arms conversion aswell as the swaybar?
dontfeelcold is offline   Reply With Quote
Old 01-28-2004, 04:30 AM   #5942
im trying to get the short arms but it isnt easy.
Serpent USA wont ship overseas.
Ashford Hobby hasent replied to me yet as to overseas orders.
who else sells the short arms?
Old 01-28-2004, 09:04 AM   #5943
Hi, I've changed to short arm version. Here are the list that I've to add in to install the short arm:
1. Lower suspension holder (#302040) x 1
2. Alu Nut (#302032) x 2
I replaced the front wishbone pivot pin bottom with a new pair of Rear Wishbone pivot pin bottom (#307310). Please see if this help or not.
octavone2003 is offline   Reply With Quote
Old 01-28-2004, 09:08 AM   #5944
About the servo post, really depends on the size of servo you are using. This is how I installed my servo. I'm using KO servo.
Old 01-29-2004, 02:01 PM   #5945
Neil Rabara's Avatar
If anyone here is going to the Nurnberg show, please take lots of photos of what will be in the Xray booth.
Neil Rabara is offline   Reply With Quote
Old 01-30-2004, 03:24 AM   #5946
university_dave's Avatar
There are no short wishbones in the UK, I'm not impressed...
The best way to get them to fit is to run the original T1 chassis, as this puts the servo more to the rear of the car.
university_dave is offline   Reply With Quote
Old 01-30-2004, 10:03 AM   #5947
Smile
Would like to ask all of you how to do the droop measure in T1 EVO2? Thanks!
Old 01-30-2004, 04:12 PM   #5948
kickind's Avatar
Guys - My T1R is coming along slowly, and I have a question about batteries. I just got 2 pcks of Fukayama cells, and built one pack last night. How is everyone doing their connections? I have extra deans bars to bend over the last cell, but the brace doesn't allow for that to work. Am I better to run deans plugs or corally style posts? Anyone with pictures of their batteries installed?
kickind is offline   Reply With Quote
Old 01-30-2004, 04:33 PM   #5949
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
I use the corally style plugs. Work perfect on the XRay
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 01-30-2004, 04:34 PM   #5950
pucho's Avatar
Send a message via AIM to pucho
You got to get creative but they will fit.
pucho is offline   Reply With Quote
Old 01-30-2004, 04:57 PM   #5951
sands's Avatar
bend it closer to the end so the solder tab is smaller and it stands up taller. Or bend it at a 45* angle.
sands is offline   Reply With Quote
Old 01-30-2004, 07:45 PM   #5952
Scrad's Avatar
Trader Rating: 15 (100%+)
I've been measuring my droop by letting the car rest at right height and then pulling up on the rear tower while holding the tires down. I usually have 1.5mm roughly I think. I'd have to check to be sure. It is the difference between ride height and the height you can pull the car up too. You could also use a associated gauge or hudy, but I've found that it doesn't work too good when running foams because of the tire wear.
Scrad is offline   Reply With Quote
Old 01-30-2004, 11:23 PM   #5953
Default Rear tire size
What is the maximum front and rear tire width that can fit on the T1R.... 24,26, 28, 30mm.....?
vadn1 is offline   Reply With Quote
Old 01-30-2004, 11:36 PM   #5954
Jeff Brown's Avatar
I run JACO 28mm tires front and rear and the rear wheels hit the shock bottoms unless you grind them.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 01-31-2004, 10:17 AM   #5955
sands's Avatar
yup - what he said. I run from 1.2 to 1.5 rear droop. Be carefull doing this - that difference is about a 1/8 turn on the droop screw.
