Old 01-22-2004, 11:42 AM   #5821
rayhuang's Avatar
Alex-okay-I was confused by the post on mytsn of your set-up. IT said shims in frnt of rear arms was 4mm/3mm.
Either way thats still 2mm short of the 9mm total so I assumed you meant 7 up front and 2 behind......no bother. HOw many shims in front then-please!!
See ya in a couple weeks!!
Ray
Old 01-22-2004, 11:52 AM   #5822
CRASH's Avatar
Trader Rating: 26 (100%+)
No shims up front. The car can only be shimmed from the rear. 4mm + 3mm in front of the rear arm 2mm shim behind the rear arm. 9mm total 259mm wheelbase.
Hope this helps.
Later,
CRASH is offline   Reply With Quote
Old 01-22-2004, 12:06 PM   #5823
pucho's Avatar
Send a message via AIM to pucho
Originally posted by rayhuang
pucho or Alex-did you guys run the Xray with 7mm of shims in front of rear arms at Cleveland? If yes-thats almost exactly the same as the wheelbase on the Tc3.
Ray
3mm in front of the arm On an other note, the blue just dosn't look right with the gold, you should try and get a hold of some T1R bulkheads. See you soon!
Originally posted by TimXLB
Pucho:
Hi,
have you gotten your Pro4 yet?????? Jason says Hi, he got a snow day today so. he's playing online (XBox) racing all day so far. good luck with your weight loss.
No Pro4 But lot's of work The track is near completion (minus store) tell Jason I said hey! and thanks for the encorangement.
How are you guys doing with the car?
pucho is offline   Reply With Quote
Old 01-22-2004, 12:43 PM   #5824
Alex or pucho, I notice that alot of the
guys use the swaybar, when and why
should I use the swaybar, I am new to
electric racing and any info will help.
Dr Smooth is offline   Reply With Quote
Old 01-22-2004, 01:17 PM   #5825
Send a message via AIM to Alex Lopez
Dr.Smooth-It prevents the car from wanting to oversteer.I highly reccomend you to ge the wire sway bar.
Alex Lopez is offline   Reply With Quote
Old 01-22-2004, 01:37 PM   #5826
JCB
JCB's Avatar
Should we use a sway bar for the rear too? I always use one in the front.
thanks,
JCB is offline   Reply With Quote
Old 01-22-2004, 02:00 PM   #5827
Send a message via AIM to True R/C Racing
I* dont believe but im not always right
True R/C Racing is offline   Reply With Quote
Old 01-22-2004, 03:06 PM   #5828
Default ball cups
Can anyone help me?
Every time i try and pop off or reconnect my ball stubs i either pull a muscle or break my finger tryin. Anyone have a suggestion on how i can make it a little easier???
DoN
ADDRacer36 is offline   Reply With Quote
Old 01-22-2004, 03:08 PM   #5829
it also causes me not to spell i meant ball cups not stubs
Old 01-22-2004, 03:21 PM   #5830
pucho's Avatar
Default Re: ball cups
Originally posted by ADDRacer36
Can anyone help me?
DoN
I use a plyer.
Actually a sway bar is ment to prevent execesive roll. Most carpet racing situations will call for a sway bar because you want your car to be "flatter" through the turns, this in terms will help your car maneuver quicker through the turn. To a point a sway bar will help you reduce the rection of the stering but like everithing the best way to lern it is to experience it.
Old 01-22-2004, 03:24 PM   #5831
JCB
JCB's Avatar
Default Re: Re: ball cups
Originally posted by pucho
I use a plyer.
thanks,
Old 01-22-2004, 03:35 PM   #5832
Pit-racer's Avatar
Where can I get all that nice color chassis for my ride?
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 01-22-2004, 03:40 PM   #5833
Pit-Racer i believe BMI or Warpspeed Offer them? Don't know anything else.. Hope that helps
Old 01-22-2004, 03:42 PM   #5834
Pit-racer's Avatar
I need the site so I can get there and look. Thanks
Old 01-22-2004, 03:44 PM   #5835
froghead's Avatar
Send a message via Yahoo to froghead
Pit, try this
bmiracing.com
froghead is offline   Reply With Quote
