Xray T1
#5761
True R/C Racing-It is just better all around to use the low ratio pulleys.Make the car freer.I really never noticed a downside/
#5762
#5763
Alright. Alex u running plaids n purples? Or tans...double pinks? those are the choices ive heard.
#5764
True R/C Racing-At the January Jam race last weekend(which i Tqued)I started off with Plaids and Purples.But i decided to try Cyans and Magentas,im glad i did that because i thought that choice of tire was the best.
#5765
alright Man. GRacias Alex.
#5766
I just got my T1R last week and am loving it. I'm running an MVP and it screams! Anyways, i ran it on a small and low traction track, but lack on power steering and the rear breaks loose very easily. Any suggestions on set up? Right now, it has the stock set up.
#5767
Cutting teeth off pulleys and belts?
Alex,
Have you tried cutting teeth off of the belts and pulleys? I saw where Cyrul did this to help free up the car. Any thoughts on this?
Thanks,
Thanks,
#5768
hay whats up crash.........................john malin did that to his car and man for a belt drive car its really free and it did not skip the belts in mod so i think that it will be safe to try..........................if i ran that car i would do it but i still have him covered with my warpspeed demon
#5769
is this possible?
Originally posted by paulc
Again my layshaft bearings siezed up on me. This time on both ends, I ended up melting both plastic bearing holders.
Any remedies? The belts arent that stiff to cause much stress on the layshaft.
#5770
Re: is this possible?
Originally posted by rcprix
i just got an idea, but i'm not so sure if it's gonna work.. has anyone tried to replace the plastic bearing holder on the center layshaft with a flanged bearing? it'll be something like the T1, only with bigger outer diameter flanged type ones. atleast the one next to the motor endbell. if anyone had tried this before, can you give the size of the bearing? i know someone will come up with "bigger rotating mass issue" because of the bigger size bearing, but i don't care! as long as it fixes the melting problem.. thanks in advance!
#5771
Re: Cutting teeth off pulleys and belts?
#5772
#5773
Alex Lopez, I tried your setup that you (Pucho) posted earlier in the thread on my T1R and it worked pretty good. Best carpet setup I've tried yet.
I broke my only set of 6 degree hubs, so I put the 3 on instead and left the dive at 0. I changed the front spring to the dark blue. The car is very good, but running mod so I would like more on power steering mid to exit. The rear end could be a touch better. I was thinking about moving the front links up a hole or moving the rear link. Or possibly going to 6 degrees by adding 3 dive.
Please let me know what you think. I just want to try something small since the car is so close already. Thanks.
#5774
ok guys,i just wanted to let you know that my new chassis kit has been tested and proven.it is unbelievable.they are going to be available friday.the price is going to be $79.99 plus shipping.here is a pic of the aqua kit.it is going to be available in standard black,titanium color,blue and aqua.other colors will follow.
#5775
Scrad-For more on power steering,stand your shocks up.Try some kick-up in the front as well.You might want to try different springs as well.Let me know what you think.
