Old 01-14-2002, 06:43 PM   #556
Peter Busch's Avatar
R/C Tech Charter Subscriber
one more thing, the wheels do not hit anything.
Peter Busch is offline   Reply With Quote
Old 01-14-2002, 06:43 PM   #557
yellow porous rectangle, I noticed the same thing when I built mine. Everything felt smooth, but the belt definately bounced. After a few runs on the track, it's not as bad, but still does it some. I don't know if it's just the angle of the pullys in relation to each other, or the belt itself, or what, but it doesn't seem to hurt anything on the track.
Think you'll be at TCHR on Wednesday? I hope to make it, have to try some stuff out.
JeffC is offline   Reply With Quote
Old 01-14-2002, 07:23 PM   #558
My belt was coiled quite tightly in the package and exhibited some movement o the pulleys when new but it has only been a couple of runs and seems to have stretched out properly
Besercoe is offline   Reply With Quote
Old 01-15-2002, 05:26 AM   #559
Default Hey
Hey Guys,
Dont worry about the belt bouncing. What you are seeing is the elastic action of the belt. I doubt under load you will see it bounce.SpongeBob does it go away when you put it under load?
SWG
simulatedwood is offline   Reply With Quote
Old 01-15-2002, 06:06 AM   #560
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Has anyone taken a bicycle wheel, spun it really fast, and while holding it by the axle tried to turn it a different direction? The gyro effect isn't that different for what a TC might experience.
That is where the load originates from, causing the belt to mediate between the power supplied and the resistance offered by the wheels turning off its original axis. Running the car off the surface on a car stand is a dramatic way of witnessing the unavoidable inefficientcy of the drivetrains mechanical physics. 1:1 scale cars are affected the same way.
Are you using a tensioner, I experienced less bounce with a tensioner.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 01-15-2002, 07:45 AM   #561
Send a message via AIM to Dave Kurschner
This is just theory buy try both locking the topshaft one-way and then running it freely and seeing if that makes a difference. You also might be experiencing a slight on-power/off-power change which tensions and de-tensions the front belt. That would of course change when the car is on the racetrack as well.
Also, how far were you turning the wheels?
Dave Kurschner is offline   Reply With Quote
Old 01-15-2002, 02:09 PM   #562
The wierd thing is that it only does it when the wheels are turned. When they are straight its perfectly smooth. I'm not going to worry about.
Old 01-15-2002, 04:04 PM   #563
Greg Amendola's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to Greg Amendola
Talking Unbeatable huh???
Just joking with you Dave. The Losi has managed to put 1 in the loss column for you, now I'll have to do it with the TC3
For anyone who doesn't know Dave, he has a very good understanding of the performance changes setup tweaks will do to the car. He knows, because he spends allot of time working on setup which shows up in his results.
Just remeber, you can run but you can't hide....bwah ha ha ha
Team AE Rulz or something like that...
Greg Amendola is offline   Reply With Quote
Old 01-15-2002, 08:22 PM   #564
Does anyone know if the new HQ bearings, or the rear lower alum. shock mounting brackets are available anywhere?
thanks...
sizzler is offline   Reply With Quote
Old 01-15-2002, 08:34 PM   #565
Buster Bennett's Avatar
Send a message via AIM to Buster Bennett
Sizzler, Call me tomorrow after 3pm EST, I should have everything by then.
703-430-2202
Buster Bennett is offline   Reply With Quote
Old 01-20-2002, 08:11 AM   #566
Hey everyone.
On a tight carpet track, what kind of tires do you guys use/recommend? I was thinking CS22 with the default inserts or the Take-off medium hard inserts? I would like excellent traction but not at the cost of a very short lifespan of the tire. I am using white springs all around. Thanks
MULDER is offline   Reply With Quote
Old 01-20-2002, 08:18 AM   #567
CS22, Sorex 20, or Pit 24 with a medium/hard insert should work fine. Be sure to review the new setups recently posted in the VIP room.
V-Dezign 4.0
Old 01-20-2002, 08:43 AM   #568
I give up, I have spent the last half hour trying to register for the vip room. It wont take my vip number. What is with all the secrecy, I dont see why this so called secret info isnt posted for the public to see.
Old 01-20-2002, 09:02 AM   #569
GregH's Avatar
Send a message via AIM to GregH
spongebob, I had problems too. I got it figured out though and everything works. mytsn.com has been slow since I started going there. Try it again, I'm sure you can get it to work.
GregH is offline   Reply With Quote
Old 01-20-2002, 10:14 AM   #570
HYDRAMATIC99's Avatar
Send a message via AIM to HYDRAMATIC99
It takes a few days for your registration to go through. You should get an email from tsn in a few days.
HYDRAMATIC99 is offline   Reply With Quote
