Old 12-27-2003, 05:47 PM   #5521
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
correct, there are no ball bearings in the one way just use the 3 screws and bolt it directly to the oneway. There is no reason to lube the gear, but you have bearings in each one of the outdrives that need to be lubed and maintained on a regular basis.
BHenderson is offline   Reply With Quote
Old 12-27-2003, 05:50 PM   #5522
Regional Moderator
BHenderson's Avatar
Originally posted by True R/C Racing
im confused now. because Someone Told me You Didn't... YOu Could Run it Without. Now its Different. Do YOu Have To Or Is it better To Run the Solid Lay shaft... Because I ordered the Pulleys From Stormers and didnt order Layshaft..
Ive not seen anyone try to run the one way layshaft with the new pulleys. It would be interesting to know if it works or not, but I feel that it will not.
Old 12-27-2003, 05:52 PM   #5523
Regional Moderator
BHenderson's Avatar
Here's Pucho/Alex Lopez's setup from the US Indoor Carpet Nats
Originally posted by pucho
Rob what's up? Hey can you get in contact with Alexe's Dads store they want to get some of the bumpers. TQ hobbies (407) 339-1899.
everione: the bulkheads are not the the 1/12 ones (at least it's not what I was told) they will most likely show up as an option and maybe in a re-incarnation of the car.
here is the set up.
front:
Violete springs
30wt oil
2 holes open
blade sway bar set at 60 deg.
shocks mounted on outer hole on arm
#3 hole on tower (carpet tower)
6deg caster blocks
0 Kick up
standard roll center
1.5 deg camber
droop ser to 2 on hudy blocks
camber link mounted on new hole on bulhead spaced 4mm up. (Andres Mayberg was using the standard hole on tower)
4mm ride heith
Jaco purple/orange at 2.25"
0 toe
diff set medium
Rear:
Violete springs
30wt oil
2 holes open
No sway bar
shocks mounted on #4 on tower and middle hole on arm.
camber link on inner hole on block and standard hole on bulkhead.
0 deg kick up
2 deg of camber
droop set to 4 on hudy blocks
1 deg tow in
4mm ride heith
Jaco purples at 2.25"
Stratus 2.0
Paragon: Hole in rear half in front
the front tires was cut down 1/2 mm so they would not touch the lower shock mount.
they used the stiff upper plate
Old 12-27-2003, 11:15 PM   #5524
Default FYI
Hey fellow Xray owners.....Just wanted to let everyone know that I have 2 brand new still in the box T1R kits that I have for sale in the buy/sell forum. 200.00 shipped for each of them anywhere in the U.S.. I also have a one way that is still in the package, I will sell that for 30.00 shipped anywhere in the U.S. Feel free to email me with any questions.
Eric
Joneser is offline   Reply With Quote
Old 12-28-2003, 01:31 AM   #5525
nutfluff's Avatar
Send a message via AIM to nutfluff
Thanks a ton for the info Porsche!!
One last question about the one way. It came with two small round spacers that I don't know what to do with? Any idea??
Once again, thanks.
nutfluff is offline   Reply With Quote
Old 12-28-2003, 02:30 AM   #5526
The spacers are for inserting between the one way and the outdrive to take out too much play, use them, the driveshaft will not fell out so easily.
Once again, thanks.
fanthom is offline   Reply With Quote
Old 12-28-2003, 09:09 AM   #5527
pucho's Avatar
Send a message via AIM to pucho
Default Re: FYI
Eric
Hey Eric:
Are you swiching cars or are you just redising stock?
Later
Luis
pucho is offline   Reply With Quote
Old 12-28-2003, 09:48 AM   #5528
Default pucho
Not switching cars!!! I love my Xray. I am selling two kits for someone else that wants the evo 2 for some testing.....long story. How is the track coming along? Are you guys going to stock Xray parts? When is the website going to be working?
Eric
Old 12-28-2003, 10:06 PM   #5529
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
In Alex's setup from the Cleveland race, which oil was he using? 30wt seems light. I'm running losi 40wt up front and 50wt in the rear.
Also, I had a wierd thing happen today at the track. I clipped a corner with the left rear and broke a ball cup and a rear shock body. That's it! I've never in my life broken a rear shock body on anything.
Wierd!
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 12-28-2003, 10:09 PM   #5530
pucho are my bodies done
rangulo is offline   Reply With Quote
Old 12-28-2003, 10:33 PM   #5531
pucho's Avatar
Wierd!
Stock out of the kit 30wt, HUMM WEIRD!
Rafi: NO!!! bit my Garage is
Old 12-28-2003, 10:37 PM   #5532
Send a message via AIM to True R/C Racing
cant wait throw this evo on Rpm's speedway's Carpet
True R/C Racing is offline   Reply With Quote
Old 12-28-2003, 10:48 PM   #5533
pucho's Avatar
I can't wait eather.
Old 12-29-2003, 08:48 AM   #5534
Serpent and Ashford Hobby are both closed through the 5th. Anywhere else I can get parts? I'm hoping to get some stuff by the 31st.
Blake
Old 12-29-2003, 10:48 AM   #5535
stormers Hobby has alot of Parts.. well for Xray. I ordered my 1.77 pulleys there they are sold out Almost every hobby shop here in central fl.
