Old 12-27-2003, 07:18 AM   #5506
pucho's Avatar
Send a message via AIM to pucho
I really don't think there is a compromise if you run the car with C-hubs on asphalt. Hey look at the results from the last nationals, Xray finished second in both stock and mod and both had a very good chance at winning.
pucho is offline   Reply With Quote
Old 12-27-2003, 08:42 AM   #5507
theisgroup's Avatar
Default xray parts
hey guys, looking for some xray parts. where might I look for some online? My LHS has told me that they are having supply issues with serpent on xray stuff. They were pretty good about xray stock until the last month or so.
thanks
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 12-27-2003, 09:38 AM   #5508
JusBox's Avatar
Originally posted by Impulse_racer
Pucho has a setup for c-hub that turned out to be pretty good for pillow ball too. The 6 degree caster blocks don't apply but most everything else does. It is here on page 177. It maybe a good setup for you to start with.
I only see 138 pages on this thread.
JusBox is offline   Reply With Quote
Old 12-27-2003, 09:40 AM   #5509
JusBox's Avatar
Default Re: xray parts
thanks
http://www.stormerhobbies.com is a good place as is http://www.speedworldraceway.com/
Old 12-27-2003, 10:05 AM   #5510
theisgroup's Avatar
Default Re: Re: xray parts
thanks for the info, looks like speedway and stormers is out of the the c-hub caster blocks and the composit c-hub upgrade.
yang lai
Old 12-27-2003, 10:11 AM   #5511
JusBox's Avatar
Default Re: Re: Re: xray parts
They were in stock until christmas, they must have sold a bunch of the c-hub upgrades.
Old 12-27-2003, 12:04 PM   #5512
Impulse_racer's Avatar
Look at the top of this page, we are on 184 now.
Impulse_racer is offline   Reply With Quote
Old 12-27-2003, 12:14 PM   #5513
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
He probably has the number of posts to show on each page set different from yours. I'm on DSL so I set mine for a LOT of posts per page. In fact, I show 138 as well.
BigDogRacing is offline   Reply With Quote
Old 12-27-2003, 01:05 PM   #5514
Send a message via AIM to True R/C Racing
Post Question
Um Do I Have To get The Solid Lay Shaft. When Buying Low Ratio Pulleys??
True R/C Racing is offline   Reply With Quote
Old 12-27-2003, 01:05 PM   #5515
Default Question
Sorry on an Evo2 Foc
Old 12-27-2003, 01:10 PM   #5516
JusBox's Avatar
Default Re: Question
Yes.
Old 12-27-2003, 01:13 PM   #5517
im confused now. because Someone Told me You Didn't... YOu Could Run it Without. Now its Different. Do YOu Have To Or Is it better To Run the Solid Lay shaft... Because I ordered the Pulleys From Stormers and didnt order Layshaft..
Old 12-27-2003, 01:23 PM   #5518
JusBox's Avatar
I'd use the new layshaft but you can probably use the stock one. I guess you'll find out soon enough if it works.
Old 12-27-2003, 01:28 PM   #5519
nutfluff's Avatar
Send a message via AIM to nutfluff
I am new to onroad and just purchased the T1R. I am putting in the 1.77 pulleys and am confused as to which pulley goes where. There were two large pulleys that are the same size, a similary sized one with smaller teeth and the two small ones. (I can figure out the two small ones) I am also putting a oneway on the front...
Help please!!??
Thanks in advance.
Also, is it true that no balls go into the oneway diff?? If so, should I lube that pulley anyway??
nutfluff is offline   Reply With Quote
Old 12-27-2003, 05:45 PM   #5520
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
Help please!!??
Thanks in advance.
in the 1.77 kit there are 2 diff gears and one for a spool/oneway. They are all the same size and stamped with the number of teeth, off the top of my head it think its 32. The one with the bigger opening in the middle and less holes for ball bearings is the one for the spool/oneway. Hope this helps
BHenderson is offline   Reply With Quote
