Xray T1
Old 12-22-2003, 09:31 PM
  #5446
Good call 429 racer. I was gone and missed that one...
ultragraffics is offline
Old 12-22-2003, 09:32 PM
  #5447
Regional Moderator
BHenderson's Avatar
Default Re: Xray Carpet Setup
Originally posted by Bobby Llantin
I am getting an Xray for Christmas and was wondering if anyone has a setup for indoor carpet. Also, should I use the adjustable or locked pistons?
Thanks for the info.
I agree with 429racer. I ran pucho's setup for Alex Lopez's car two weekends ago and it felt great.
BHenderson is offline
Old 12-22-2003, 09:35 PM
  #5448
Bobby
I sent you an email
rangulo is offline
Old 12-22-2003, 09:47 PM
  #5449
rayhuang's Avatar
For you guys running Carpet/Foams at Snowbirds-you should look into getting a super stiff chassis and upperdeck for the car. It will pay off bigtime in highbite situations like the Bird and Nats and Champs. It will make the car carry more corner speed and will also help you find that dialed set-up. INstead of trying to equate chassis flex into your set-up.
Check this custom baby I had made for a local buddy of minewho runs Xray in Modified on carpet/foam tires.
Ray
rayhuang is offline
Old 12-22-2003, 09:49 PM
  #5450
rayhuang's Avatar
Its a 3mm chassis and 3mm topdeck cut-out of super stiff Ice Blue Carbon Fiber. It has the minimum cutouts in it-it can to keep it stiff. Its way stiffer than even the original t1 chassis.
rayhuang is offline
Old 12-22-2003, 09:57 PM
  #5451
Nice work Rayhuang. Looks very professional. Just curious, how much would you charge to make a single peice upperdeck? Just regular graphite as I dont need the bling bling blue...
Old 12-22-2003, 10:01 PM
  #5452
Registered User
Default '04
Just wondering, what Xray going to do in year '04 for T1? Are they coming out with new spec.? Or is it possible, the Evo3?
Aku-Man is offline
Old 12-22-2003, 10:11 PM
  #5453
I am new to Xray. I got the setup from Pucho. What is considered the "standard hole" for the camber link on the front and rear?
I think thats the only question I have...
Thanks in advance...
Old 12-22-2003, 10:32 PM
  #5454
Default right hole
you could prob. go to the event section on the home page and look at the cleavland pics, josh cyruls car should be in one of those pics
jiggamacdaddy is offline
Old 12-22-2003, 10:53 PM
  #5455
I did look at those. I just didnt know if mounting it to the bulkhead was considered standard.
Can someone verify this?
Old 12-23-2003, 05:21 AM
  #5456
pucho's Avatar
Victor from Warpspeed cut it out for him, you could contact him about it. Alexe's dad tryed one and it was so prety that everione wanted to buy it.
When I say standard holes I refer to those holes used in the standard set up, middle hole on tower fro the fromt and hole on bulhead for the rear.
Not mayor changes, just some changes to the arms (short) and the bulkheads (more options for rollcenter, anti dive, and anti squat.) everithing else is the same.
Bobby: I hope to se you and your dad down here for the birds and you guys can come get practice at our ne track.
pucho is offline
Old 12-23-2003, 06:34 AM
  #5457
CRASH's Avatar
Trader Rating: 26 (100%+)
Check out these custom chassis,
http://www.xtremercracing.com/X_RAY_3500.cfm
They look top notch, and talk about SWEET LOOKING!
Later,
CRASH is offline
Old 12-23-2003, 07:16 AM
  #5458
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Anyone know if the Losi thrust set that has the enclosure like the X-Ray will work with the EVO2?
dr_hfuhuhurr is offline
Old 12-23-2003, 07:17 AM
  #5459
AdrianM's Avatar
Default Xray in 2004
There are so many things on Giles', Josh's and other team drivers cars that you cant buy right now or don't come in the kit that they have 2004 coverd as far a new updates/hop ups...lol.
AdrianM is offline
Old 12-23-2003, 07:45 AM
  #5460
It's been floating around that Xray might have a shaft car in the works. My sources are good and usually correct. Don't be surprised!!
PhatPat is offline
