Old 12-14-2003, 12:34 AM   #5371
pucho's Avatar
Send a message via AIM to pucho
I really can't think of any aditional ones.... it is a straight up swap; and yes it's whaky you have to download the C-hub instructions from the site (mytsn) It will be under publications.
pucho is offline   Reply With Quote
Old 12-14-2003, 01:18 AM   #5372
hi there, i plan on getting the Xray T1 EVO 2 FOC and was wondering what servo i should run, i will be using a JR xr3 transmitter if it helps any.
blue micro is offline   Reply With Quote
Old 12-14-2003, 07:58 AM   #5373
Oasis's Avatar
Trader Rating: 36 (100%+)
On servos it's like everything else..how much do you want to spend,but your buying a hi dollar car so I dont think you really want to put a low performance servo in your car.For a touring car you should have some performance levels,#1.Torque: you should look for at least 80 oz/in.#2.Speed,alot of how fast is up to you,but most racers want a "fast" servo,because speed = responsive.My picks would be,Airtronics: 94758z(digital)94757z(digtal)94357(that's what I use in my xray)94358.but these are not cheap($104 to $109).JR's,DS8417(digital)Z8450(digital)and not cheap($114)Z4750($89)Z590($39)good servo for the money.hitec(alot of people dont like hitec servos,due to centering problems,but these dont have centering problems)HS5975,HS5927(both digital,fast and hi torque)$82 to $89,HS925mg.I hope this helps on the servos.
Oasis is offline   Reply With Quote
Old 12-14-2003, 11:07 AM   #5374
yup that helps alot
Old 12-14-2003, 10:40 PM   #5375
Don't get Hitec servos. Theyre bad. I've heard of many people having them die for no reason. And I also had that problem. And it didn't make me happy because it was kinda like throwing 60 bucks down the drain. I also didn't even have it for over 6 months before it died. I'm running only Airtronics servos now with no problems at all. The one I have in my x-ray is pretty old and I bought it used from a guy I know the day my Hitec servo died a while ago. And I still don't have any problems with it. I've also heard that JR makes really good servos that very rarly die on you. You can't really go wrong with airtronics or JR. Just my 2 cents.
racerdx6 is offline   Reply With Quote
Old 12-15-2003, 12:35 AM   #5376
xray racer's Avatar
Trader Rating: 22 (100%+)
hey,
im possible putting some evo2 parts on my t1 and was wondering if you need the new shocks for the c-hubs and the foam shock mounting thing, and also the rear ultra tune tower
thanx for ne info in advance
robbie lloyd
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 12-15-2003, 07:36 AM   #5377
JusBox's Avatar
Can't believe noone suggested KO Propo servos. These are some of the best in the biz.
JusBox is offline   Reply With Quote
Old 12-15-2003, 07:38 AM   #5378
JusBox's Avatar
Originally posted by xray racer
hey,
robbie lloyd
If you go with the new xray shocks you will need a new front tower. I have the ultra tune front tower and ultra tune rear tower. I would definately buy the new shocks if you're going to upgrade the car.
Old 12-15-2003, 12:30 PM   #5379
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
What are the equivalent oils for the X-Ray Oils?
XRay 20wt = Losi (or Associated or Trinity)?
XRay 30wt = ?
XRay 40wt = ?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 12-15-2003, 12:34 PM   #5380
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
XRay 30wt = ?
XRay 40wt = ?
I was told they were the exact same wt as all the others.
BHenderson is offline   Reply With Quote
Old 12-15-2003, 06:52 PM   #5381
I think they're pretty close in weights. Probably close enough that an average racer couldn't tell. Mabey even a pro.
I ordered the foam front graphite shock tower and the graphite ultra tune rear shock tower for my t1r. Is there anything else that I would need to get to mount the shocks and camber links? Thanks
Old 12-16-2003, 02:17 AM   #5382
Trader Rating: 14 (100%+)
Pucho:
should I buy the front foam shock tower?? also pplease have Alex e mail Mini. PM me for his e mail.
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 12-16-2003, 06:22 AM   #5383
pucho's Avatar
Tim - I would go with it You can mount the bory lower over it and it has an additional shock mounting hole that would allow you to stand up the shock more than the regular one.
Old 12-16-2003, 09:33 PM   #5384
Regional Moderator
BHenderson's Avatar
pucho,
in regards to that setup you posted from Alex Lopez's car from the US nats, which top plate did you use?
Old 12-16-2003, 09:46 PM   #5385
pucho's Avatar
Im sory I neglected to elaborate. It was the solid top deck. Some of the mod guys where using a solid plus a medium on top, but you have to run the medium one backwards(berign holder side to the back) to get it to work (so belt won't rub on it).
