Old 11-30-2003, 06:27 AM   #5266
theisgroup's Avatar
Originally posted by lee82gx
hi guys,i just got the t1R ..do we discuss the T1R here?
have some questions,
The gearing chart i got fromt the nice booklet seems incomplete.
Does it not accept standard spurs(kawada 64p 100-106T)?
what spurs does it accept?
you can figure it out your self using the following:
for stock setup: spur / pinion * 2.125 = final ratio
for 1.77 pulley: spur / pinion * 1.77 = final ratio
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 11-30-2003, 06:38 AM   #5267
lee82gx's Avatar
yes i understand that...
but what brand of spurs does it accept?
normally it is 4 screws(to form a square) but it's now 3 screws.
my present spurs do not fit....??
lee82gx is offline   Reply With Quote
Old 11-30-2003, 07:08 AM   #5268
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
For 1.77 pulleys we use the Kimbrough 128T 64P spur. It allows a large enough pinion to get the motor away from the front belt.
BigDogRacing is offline   Reply With Quote
Old 11-30-2003, 07:40 AM   #5269
sands's Avatar
Kimrough spurs. I keep 128, 120, 124(?), 116 in my box. Depending on tire diameter, they will all fit to maintain a 1"-1.2" rollout.
sands is offline   Reply With Quote
Old 11-30-2003, 07:55 AM   #5270
lee82gx's Avatar
Thanks.got it.Kimbrough 128-116.
BTW ...how long does it take to get registered in mytsn??
Old 11-30-2003, 12:24 PM   #5271
Send a message via AIM to ZER01
lee82gx, you can use RRP spurs with that pulley but you will have to tap out another hole for the bolt pattern to fit.
ZER01 is offline   Reply With Quote
Old 11-30-2003, 06:07 PM   #5272
sands's Avatar
The center shaft that the spur fits on will locate the spur just fine. The bolts really just hold it on, they don't locate the spur. Drilling fresh holes will work fine. (Going to do this on a HPI 125 spur)
Old 11-30-2003, 08:42 PM   #5273
lee82gx's Avatar
do u guys mean tap a hole in the spur or the spur holder?
Old 11-30-2003, 09:11 PM   #5274
sands's Avatar
in the spur
Old 12-01-2003, 05:02 PM   #5275
protc3's Avatar
hey guys,i am jason from BMI Racing.i have had alot of requests for a stiff chassis for the xray.i have alot of thoughts on different parts for the car being that i have driven one and seen plenty of them.i do not own one.what i am asking is what would you guys like to see in a chassis that would be perfect for carpet?any input would be greatly appreciated.
protc3 is offline   Reply With Quote
Old 12-01-2003, 05:21 PM   #5276
sands's Avatar
Better mounting locations for the ESC and receiver. It always seams as though the "battery" slots are right where I want to put one. I haven't seen anybody run a battery outside of the stock locations. (3 per side, all the way back)
The little black bearing holder for the servo saver bellcrank gets loose, a tighter fit would be good.
The battery posts are very tight for a GP3300 pack, slightly longer with a matching battery holder strap would be cool. They don't need to be centered on the battery either, diagonal or offset to get the carbon strap away from the battery tabs for those that solder on as well.
Stiffer is always cool, though the stock chassis with stiff top deck is pretty stiff already.
Old 12-01-2003, 05:31 PM   #5277
To stiffen the stock chassis on the T1R you could use the stiff carbon fiber upper deck. Than drill a hole in the upper deck so you could use the center post for the stock solid upper deck. I think that's what I'm going to try for this next weekend. Sound's like it will work to me .
This doesn't have to do with stiffening the chassis, but it would be really really cool if someone made a front bulkhead that extended and screwed into the top of the front bumper. You may also need to design a new front bumper and bumper brace. But it would help prevent the chassis from breaking right infront of the bulkheads. You could also make a wide front bumper like the one RPM makes for the tc3, that might help against breaking those weak little c-hubs.
Here's another way to stiffen the car without stiffening the chassis. Would be to make all the suspension parts (c-hubs, rear uprights, steering blocks, suspension arms) out of a graphite material like the material associated uses for their graphite parts. This might also help with durability.
Sorry that a lot of my suggestions for new parts dont really have to do with a stiffer chassis. But I just wanted to throw my ideas out there !
racerdx6 is offline   Reply With Quote
Old 12-01-2003, 05:43 PM   #5278
Trader Rating: 17 (100%+)
I would like to see the battery slots moved a little more forward, the slots angled so the batteries can sit lower with out having to file them, chassis made stiffer and the front carpet shock tower (I think the 4 hole) should be made taller to fit taller tires.
429racer is offline   Reply With Quote
Old 12-01-2003, 06:09 PM   #5279
protc3's Avatar
thanks for all the suggestions.i dont know if you guys are familiar with my work or not but i make a nitro and electric chassis for the tc3.you can check out my products at bmiracing.com
i do have some xray parts already.they are just for cosmetics though.nut much performance enhansements.i am not happy with that.i was just asked to copy the stock stuff but make it blue.i have never made any products that did not have any functional purpose until that.now its time for me to redeem myself by improving this car.the xray is an excelent car to begin with,but everything needs improvement.
when i first worked on my nitro tc3 chassis i was trying to make a more rigid,lower center of gravity,lighter chassis.not only did i do this,but it also made the car much more predictable and more durable.i would like to do the same here by using all of your input and combining it with my experience to make a strong affordable,unbeatable machine.i am thrilled that you guys are supporting me on this and you will not be disapointed.thanks again.
jason
Old 12-01-2003, 07:30 PM   #5280
sands's Avatar
I like the idea of bracing the front end more. I haven't broken a chassis yet, but I've seen people do it.
Or that part can be made separate and sacreficial (spelling?). So you break an $8 part rather then a $70 part. Make the chassis end right under the front bulkhead, then bolt a separate bumper holder to the bulkhead. So that breaks, not the chassis.
Want me to try a prototype? LOL
