Old 11-23-2003, 04:18 PM   #5206
JusBox's Avatar
I'm having trouble mounting my saddle packs to my T1... how do you guys build yours to fit? Actually I might want to go with the evo 2 chassis and try stick packs with the car. What do you guys think about that?
JusBox is offline   Reply With Quote
Old 11-23-2003, 04:31 PM   #5207
war11x's Avatar
Trader Rating: 17 (100%+)
i threw all me deans connectors out and converted all me packs to Corrally connectors this eliminates all bar 1 wire , if you take about 2 inch of 12 gauge , noodle wire and solder the packs together with the wire this allows plenty of clearance from the belts including mounting batteries into your car and allows easy storage in your battery boxes
sorry i dont have a pic of mine but i am sure lots of other Xray owners know what i am talking about and may have a pic
to post for you
war11x is offline   Reply With Quote
Old 11-23-2003, 04:36 PM   #5208
Regional Moderator
As war11x says, just solder a short wire between the cells. I wouldn't go with a straight pack. One of the reasons the XRay is so good is weight distruibution, and using the inline packs will mess it up.
Try working a bit more with the saddle packs, and throw the deans out, well at least for the batteries.
volav is offline   Reply With Quote
Old 11-23-2003, 04:55 PM   #5209
JusBox's Avatar
I think I finally got it to work. What I was trying to do was get the packs so they could be straightend for use on an equalizer...
Old 11-23-2003, 06:02 PM   #5210
Cool Hot Set-up
I need some ideas on a good set-up. For a high grip open asphalt track
(stock class TIR)
flbugboy is offline   Reply With Quote
Old 11-23-2003, 06:17 PM   #5211
JusBox's Avatar
Default Re: Hot Set-up
(stock class TIR)
Here's one for socal off mytsn.com
Chassis:
Brand and type: T1 RAYCER
Track conditions:
Track (if not listed): so cal
Air temperature: 70
Track temperature: 65
Traction: high
Track surface: aspahlt
Race condition: mixed
Results:
Qualifying result: TQ
Qualifying position: TQ
Best laptime: 10.4
Final result: 2
Final position: 2
Best laptime: 10.3
Suspension geometry Front:
Type of suspension: c-hub suspension
Downstops: 2 mm
Camber Left: -.5
Camber Right: -.5
Ride height mm: 4.5 mm
Upper link location on shock tower: long
Toe-in: 0
Steering block type: composite
Anti-dive (0 or 3 degr.): 3
Ackermann position: 1
Steering block mounting position: back
Caster: 3
Caster Block Type: medium
Front Arm Type: medium
Suspension geometry Rear:
Downstops: 4 mm
Camber Left: -.5
Camber Right: -.5
Toe-in: 2
Anti-squat (0 or 3 degr.): 0
Upper arm position in upright: long
Roll Center Position: low
Rear Arm Type: medium
Wheelbase settings:
Wheelbase length: 258 mm
Clips used in front of arm: 4 + 2
Length of the adjustable ball in the bulkhead: 1 mm
Shockabsorbers Front:
Springs: blue
Spring length: stk
Spring pre-load: 0
Oil: 30 W
Holes: 2 opened
Upper shock position: 3
Lower shock position: 2
Shock body : aluminum
Shockabsorbers Rear:
Springs: light blue
Spring length: stk
Spring pre-load: 0
Oil: 30 W
Holes: 2 opened
Upper shock position: 5
Shock body: aluminum
Anti-roll bar front:
Thickness:
Anti-roll bar rear:
Thickness:
Balancing of Chassis:
Additional weights left front:
Additional weights left rear:
Additional weights right front:
Additional weights right rear:
Additional weights center:
Transponder placement: front bumber
Tires Front:
Make: Sorex
Compound: 36r
Insert: yokomo thin firm
Diameter:
Width:
Traction compound: paragon
Tires rear:
Make: Sorex
Compound: 36r
Transmission:
Pinion: 18
Spur gear: 93
Final drive ratio: 9.15
Roll-out (mm):
Front axle:
Type: one way
Diff. setting:
Rear axle:
Type: differential
Diff. setting: medium
Aerodynamics:
Body: Losi Alfa
Wing: stk
Electrics:
Battery: gp
Battery capacity (mAh): 3300
Electric motor brand: peak vantage
Armature: vantage
Winds: 7
Strands: 2
+ Spring: hard
- Spring: hard
Brush face: serrated
Brush compound: sprint
Speed controller: lrp quantam
Limiter (A):
Drive frequency (Hz): punch #3
Initial Brake (%): #1
Drag brake (on/off): on #1
Remarks:
Chassis performance: This is my standard setup for so cal. I also use the thick solid graphite top deck and .060 washers under the rear hub link.
Old 11-23-2003, 07:44 PM   #5212
JusBox's Avatar
Man, i just took apart my front diff... feels like the diff balls are square! Talk about rough. I think it's time for some carbide.
*update* just bought 24 carbide diff balls from Acer. Man they have great prices!
Old 11-23-2003, 09:21 PM   #5213
RBLove's Avatar
Trader Rating: 72 (100%+)
Just wanted to give my boy Alex Lopez a little shout out. His car is money. I will ask him to get on here after the US Indoor Champs and post his set up. It is very good..........
X-Ray has some really cool things in store.
Good luck Alex..
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 11-23-2003, 09:38 PM   #5214
JusBox's Avatar
Good luck Alex..
Good things that can be used with current T1/evos?
Old 11-24-2003, 02:26 AM   #5215
JusBox's Avatar
Well I tore apart both my diffs... turns out the roughness was due to a bad thrust bearing. That's all I can think off as I swaped so many parts to trouble shoot. I'm going to replace the front diff with a one way though i'm confused. What's the difference between these two parts???
Alu Solid Axle Hard Coated - Set (About $20)
http://www.teamxray.com/xshop/show.p...deda99f57588a6
One-Way Differential PRO - Set (About $50)
http://www.teamxray.com/xshop/show.p...e46a0942138ad6
To me they're exactly the same except the more expensive one looks nicer. Which one should I get???
Old 11-24-2003, 03:47 AM   #5216
The one way should free spin when you let off the trigger, the solid axle is just that, a solid axle with no diff action.
Snobeast is offline   Reply With Quote
Old 11-24-2003, 04:16 AM   #5217
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
oneway gives the car alot more turn-in, solid axle is like a oneway out of corners but you get a little less turn-in but you can use the brakes without spinning out.
dontfeelcold is offline   Reply With Quote
Old 11-24-2003, 12:11 PM   #5218
JusBox's Avatar
I imagine it's easier to dial out turn in than it is to get it without a one way... Maybe I should pony up for the one way.
Old 11-24-2003, 05:18 PM   #5219
JusBox's Avatar
I just got my new xray shocks... I'm finding that the original length for the front shocks (67mm) is too short for these new shocks. The lowest I can go is about 70mm. I have the original T1... do I need to get the evo 2 shock towers or will I be ok?
Old 11-24-2003, 05:50 PM   #5220
Cool Parts Availability !
I was told today at my LHS that Horizon hobby will be distributing
Xray parts and cars.If true it will make parts and cars easier to get!
