Xray T1
#5191
Hey thanks guy's I'll stick with the 1.77 pulleys, does the motor get into the belts? with small pinions?
Hydramatic- I use the tube style connectors and it works well all clear of any belts. And IMO as good as hard wiring. Tight is good
#5192
Xraycer >> With 1:77 pulleys i use 132 spur and 29 spur. Total gearing of 8.06.
On a Orion Revolution Touring 12x2
#5193
I didn't know spurs can go that high. The highest I've seen is a 128 64P.
#5195
Originally posted by AWOLsoldier
Yah i'll go with the trinity/corally style connectors. Does anyone have any to spare that I can buy? Also looking for any xray upgrades, spares as most places seem to be out of stock.
#5197
#5198
Sparx- I'll look into getting one of those RW spurs I think schumacher USA corries them, Thanks again.
#5199
Originally posted by jzone
anyone gotta good setup for an EVO2 running touring stock class on foam tires. track is 98'x46'
thanks
thanks
#5200
When using Deans plugs and the side by side layout I wire my battery packs as in the attached photo. The wires will not interfer with the belt and it makes a nice compact configuration. Be careful when installing the packs to prevent any shorts.
#5201
When using Deans plugs and using an offset layout I wire my battery packs as in the attached photo. The wires will not interfer with the belt and it makes a nice compact configuration.
#5202
Hey guys what's the differance in handling between the carbon fiber chassis and the composite?
#5203
I heard that there will be a new Xray T1 EVO 3 coming out soon. How true is this?? Is there any website that have a sneak preview on this???
#5204
Trader Rating: 22 (100%+)
plastic chassis will flex more than the graphite chassis.
#5205
CHassis
The composite is generally used for the asphalt because it is a little more flexy and the carbon fiber for the carpet, as it is stiffer. However, many have good luck racing the T1r on both carpet and asphalt...
Hey...I got a Evo2 for sale if anyone is looking for one:
Evo 2 Xray FS
Evo 2 Xray FS
