Old 11-18-2003, 04:38 PM   #5176
Default Team Xray T1 EVO2 for sale
Team Xray T1 EVO2
Item on Ebay. Item number: 3157589869
Also check this link:
http://www.rctech.net/forum/showthre...647#post595647
XrayEye is offline   Reply With Quote
Old 11-18-2003, 05:08 PM   #5177
JusBox's Avatar
Originally posted by BigDogRacing
It's probably your layshaft bearing(s). They go bad sometimes.
So where do you guys get your parts from anyway? My local shop doesn't carry anything so it's pointless to go there. I'm going to try the xshop but if you can recommend any place, let me know.
JusBox is offline   Reply With Quote
Old 11-18-2003, 10:04 PM   #5178
Neil Rabara's Avatar
You should support your LHS, ask if they can order the items for you. The xshop is good place to go if you are in dire need for parts.
Neil Rabara is offline   Reply With Quote
Old 11-18-2003, 10:09 PM   #5179
Matt04's Avatar
Originally posted by dontfeelcold
what type of noise and where does it sound like its coming from.
it sounds like it is coming from the back of the car bit i can't figure out if it is the diff or the layshaft.
what could i do to rule out one of these?
Matt04 is offline   Reply With Quote
Old 11-18-2003, 10:15 PM   #5180
Take the motor out, spin the drive train slowly using the belt. Listen carefully for the noise.
Old 11-18-2003, 10:17 PM   #5181
pucho's Avatar
Send a message via AIM to pucho
I would check all berrings and take apart the diff to make sure it was asembled correctly. A while back aggo Xray had some problems and some of the diffs where not built corectly from the factory. Make sure your belts are not tight remember they should have some deflection about 1/8" is good.
pucho is offline   Reply With Quote
Old 11-18-2003, 10:25 PM   #5182
Describe the noise.
Old 11-19-2003, 07:11 AM   #5183
JusBox's Avatar
Ended up buying a few parts from the xshop...
305502 Solid Alu Central Layshaft Set 1 18.00 18.00
305550 Low Ratio Pulley Set (ratio 1.77) 1 29.95 29.95
305442 High-Performance Kevlar Drive Belt Rear 3x180mm 1 10.50 10.50
308300 XRAY Shock Absorber - Set 4-Step (2) 2 26.75 53.50
397313 XRAY Sticker For Body - Purple
Anything else that's viewed as a must have?
Old 11-19-2003, 11:56 AM   #5184
jzone's Avatar
anyone gotta good setup for an EVO2 running touring stock class on foam tires. track is 98'x46'
thanks
Jesse Galang
Northwest R/C Club - VP
OverGeared Racing OG
Team Associated | Reedy | Orca
jzone is offline   Reply With Quote
Old 11-19-2003, 08:39 PM   #5185
sands's Avatar
I found a bunch of 6x10x3 bearings on ebay cheap. After every race I tear it down and check on the layshaft bearing for any play. I replace the bearing if it feals bad.
sands is offline   Reply With Quote
Old 11-19-2003, 08:52 PM   #5186
XRaycer's Avatar
I was wondering if any body runs the 1.77 pulley set up in mod it seems I cant get to a low enough ratio/ rollout, I'm running a 10x2 and it's fast I haven't ran mod with my T1R until now any input would be appreciated. Track is about 80'x35' kinda small and decent traction 2nd season on the rug, again any help would be greatly appreciated.
XRaycer is offline   Reply With Quote
Old 11-19-2003, 10:10 PM   #5187
Scrad's Avatar
Trader Rating: 15 (100%+)
I run the low ratio pullies when I run mod and 19t. To me the pullies work better in mod than stock. I may not have had it geared right in stock though. I think I ran about a 32 pinion and 128 with a 12x2 with about 62mm foams. I'll check the gearing on my 19t tomorrow and let you know for sure.
Scrad is offline   Reply With Quote
Old 11-19-2003, 11:02 PM   #5188
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
i'm using the 1.77 pullies w 48dp gears, usually pinions needed are around 19t to 23t with a 96t spur, just my s$0.002......
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 11-19-2003, 11:34 PM   #5189
JusBox's Avatar
Well i'll say one thing about the T1... a real pain in the ass to use deans plugs on the batteries and keep the wires out of the belt.
Sadly i'm not going to hard wire due to convenience... maybe down the line i will. Things sure are tight though.
Old 11-20-2003, 01:20 AM   #5190
HYDRAMATIC99's Avatar
Send a message via AIM to HYDRAMATIC99
You could use the tube and plug style connector from corally/orion/trinity.
HYDRAMATIC99 is offline   Reply With Quote
