Old 11-17-2003, 05:50 AM   #5161
sands's Avatar
go to www.mytsn.com for setups
sands is offline   Reply With Quote
Old 11-17-2003, 06:12 AM   #5162
hellangel's Avatar
i tried... dun seem to haf wat i'm looking for...
hellangel is offline   Reply With Quote
Old 11-17-2003, 07:30 AM   #5163
sands's Avatar
Try this...
Old 11-17-2003, 07:31 AM   #5164
sands's Avatar
Or this...
Old 11-17-2003, 04:45 PM   #5165
hellangel's Avatar
thanx dude...
did u compile these list urself?? good job!!!
Old 11-17-2003, 05:58 PM   #5166
sands's Avatar
I put it together from a bunch of public web sources. If you dig some you can find the same stuff.
One thing that is annoying, some of the sites will say opposite things. Also, different cars will also behave differently to setting changes.
Bottom line is you'll need to refine those quick sheets for yourself.
Old 11-17-2003, 05:59 PM   #5167
Scrad's Avatar
Trader Rating: 15 (100%+)
AWOLsoldier, you can use the new evo2 springs on the T1 no problem.
Scrad is offline   Reply With Quote
Old 11-17-2003, 06:50 PM   #5168
JusBox's Avatar
Ok thanks. I'm trying to get a feel for what the must have upgrades are. It's tricky with so many parts available but I think i'm making some headway. Suggestions would be helpful.
JusBox is offline   Reply With Quote
Old 11-17-2003, 07:04 PM   #5169
Well, another week gone by and another day of running mod sedan and testing the durability of my radius rod modification. I have to say, so far it's a resounding success. Didn't break a single plastic C block, steering knuckle, or A arm, even after smacking the walls HARD 3 times on one lap. (serious brain fade) The tie rod from the bellcrank to the servro did pull apart, but that was my rookie mistake, it wasn't long enough to begin with and had only a few threads in each ball cup.
I now have a heck of alot more confidence that I will be able to survive the Indoor Champs with far less breakage. Now I can punt those wussy TC3's and XXX-S's and watch them shed graphite chunks like confetti
Stealth_RT is offline   Reply With Quote
Old 11-17-2003, 07:08 PM   #5170
rayhuang's Avatar
YOu were pretty darn fast yesterday Stealth. YOu should be fine at Champs!!
Old 11-17-2003, 11:16 PM   #5171
Matt04's Avatar
hey, can u guys help me cause im stumped with this.'
im getting alot of noise from my car when i am just goinig forward. ive changed the spur and ive changed the motor and ive changed the pinion and it doesnt look like anything is hitting the belt.
has anyone else had this problem?
Matt04 is offline   Reply With Quote
Old 11-17-2003, 11:18 PM   #5172
Send a message via AIM to ZER01
Nope, sounds to me like the only thing is a loose diff slipping.
ZER01 is offline   Reply With Quote
Old 11-18-2003, 07:39 AM   #5173
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
what type of noise and where does it sound like its coming from.
dontfeelcold is offline   Reply With Quote
Old 11-18-2003, 01:25 PM   #5174
JusBox's Avatar
Hey i'm running in my car and it's kinda noisey... the layshaft (where the spur attatches) is making all kinds of racket. Is this normal?
Old 11-18-2003, 04:34 PM   #5175
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
It's probably your layshaft bearing(s). They go bad sometimes.
BigDogRacing is offline   Reply With Quote
