Xray T1
#5041
The front shocks from the old T1 (serpent shocks) might just do it, i have seen and talked to some drivers and they liked it better than the std assoc shocks. the good thing is that the shocks are waaay easier to get right, and without bubbles left in them, and you dont have to take the shock apart to change hole/piston..just good things!
#5042
Regional Moderator
Graphite upper plate
can anyone help me out. I'm looking for the item number for the top plate for the T1R, graphite, stiff. Thanks
#5043
So has anyone actually tried any other shocks on the Xray. I really would hate to buy AE shocks just to find they want work. Anyone?
#5044
hey mike, I dont' think they make a graphite upper plate specificly for teh t1r, but you can use the woven graphite from the evo 2, which works with all xray's. here's the part number: 301161.
here's a link http://precisionrc.com/cgi-bin/cart.pl?BR=XRY&DT=2
#5045
Regional Moderator
cool, thanks TC3Racer67
#5046
Hey Mike you got a T1R. Thats 8. And HobbyTown says that Xray isn't that popular.
#5047
#5048
that was the same thing i was thinking, i guess he "broke" a shock somehow.
#5049
Lets see they leak, aluminum on plasticis a bad idea and the shock adjustments are all cocked and twisted, dont like the bottom piece of the shock body at all. Look I like the car just dont like the shocks and wanted to try something else thats all.
#5050
Trader Rating: 22 (100%+)
get the alloy shock bodies
they look smick
they look smick
#5051
I just ordered some alloy bodies. Any idea how to get the bottoms off without the "special tool" I got it used. Thanks for the help. Kevin Mac.
#5052
I havnen't seen the alloy ones, I think you're right about the whole plastic/metal idea. Can you tell me where i can see the alloy ones? thanks
#5053
The plastic caps on the bottom will be a biotch if you dont have the special tool. They will fit real tight on the aluminum bodies. You may even have to file the botton flange part of the body a bit to fit properly. The aluminum bodies are a lot better than the plastic once built. No leaks, very smooth and consistent.
#5054
#5055
I havent seen them yet just ordered from Ashford hobby should be here in a few days I will post a pic when I get them finished. Thanks for the help guys I got the bottoms off minus a skint knuckle. Kevin.
