Xray T1
Old 10-20-2003, 10:55 PM
  #4996
Neil Rabara's Avatar
Oh I see how you did that. I couldn't do that with my Quantum, the lights and buttons would be covered.
Neil Rabara is offline
Old 10-21-2003, 04:28 PM
  #4997
N4S
N4S's Avatar
Has anyony had any problems with the hubs ???? I have run ae for years , and just went with x-ray after i drove one. After one race , both front hubs were notched in two places , and i had to bend them with pliers to get the bearring off . Is this a common problem with the alu hubs ? I went through the car , and cant find any reason for it , they matched on both sides of the front , but the rears are perfect
N4S is offline
Old 10-21-2003, 04:33 PM
  #4998
rc-zombies's Avatar
Yes this is common for the Aluminum hubs.
the front hubs take alot of abuse.... Highly recommend switching to the Spring Steel hubs...you'll have no more worries....
rc-zombies is offline
Old 10-21-2003, 04:40 PM
  #4999
I was told to switch to the spring steel front hubs when I first got my t1r. And I've had no problems since .
Here's a problem I have had, my rear diff is always gritty. I've rebuilt it twice two since the first time i built it. But It just gets gritty right away. I've cleaned it out with motor spray too and used plenty of lube. Any ideas? It's getting annoying, especially because the first time i built the diff it was awsome, than it got gritty. My front one is still awsome. Thanks.
racerdx6 is offline
Old 10-21-2003, 04:52 PM
  #5000
rc-zombies's Avatar
stop racing in the dirt.. j/k and with all that rain up their.. you better waterproof your car... I'm an ex Husky alumuni and Wash. Resident..... I miss the rain.
Have you taken your diff apart and totally cleaned it out? Spraying the diffs will not remove all the dirt and grime that could be stuck inside where the Diff Balls sit. I've had 3 racing days on mine...never had a problem with dirt getting in...
Old 10-21-2003, 04:58 PM
  #5001
N4S
N4S's Avatar
Guess i better get em' on order . Thanx for the help
N4S is offline
Old 10-21-2003, 06:25 PM
  #5002
Aluminum hubs...yes they will wedge-out from the bone striking it during hits.
Gritty rear diff...my is ultra-smooth but it's had plus minus 9 hard runs and doesn't slip. You did assemble and break it in right didn't you?
ZER01 is offline
Old 10-21-2003, 08:16 PM
  #5003
littledog's Avatar
I had the same problem on an earlier ray that I used to own.Turned out that the trust balls had flat spots or the brass ring surounding them had squished.Any ho,I replaced the thrust bearing (balls)and all should be good.
littledog is offline
Old 10-22-2003, 07:12 AM
  #5004
Default T1R gear ratio for 23 turn motor
Hi, I am looking for the right gear ratio for my Yokomo T-MAXX LR 23 turn motor. Does anyone know what's the FGR for this setup? Some say 6.x and some say 5.x The club track is a medium size track.
ps: drivetrain ratio is 2.125
Thanks!
discus18 is offline
Old 10-22-2003, 08:16 AM
  #5005
university_dave's Avatar
Sounds like the thrust race needs rebuilding. If you want ultra smooth diffs though, get some of the Acer ceramic-nitride balls...
university_dave is offline
Old 10-22-2003, 08:47 AM
  #5006
sands's Avatar
Try this. Polish all of the diff rings, thrust plates too, with car polish or buffing compound. This will remove any burrs on them.
Then sand the disks with 600 grit wet dry. (Yes, SAND them!) this is a trick that 1/12 scale and oval guys use to allow for no slip with less compression on the diff. The end result is a smoother diff.
Also replace the balls with carbide or ceramic, and replace the cone washers. If they loose their springiness, they won't work right and your diff will feal gritty.
sands is offline
Old 10-22-2003, 10:14 AM
  #5007
Accord's Avatar
This is a little off topic, but are there any XRay drivers in here that own 1/5 scale cars? Here is mine... http://www.rctech.net/forum/showthre...threadid=16745
Wouldn't it be cool if XRay/Hudy/Serpent made a 1/5 scale car? At the IFMAR 1/5 scale world championships a few weeks ago there were TONS of XRay and Serpent banners posted on the borders of the track and whatnot, so obviously XRay/Serpent/Hudy is interested in 1/5 scale.
Accord is offline
Old 10-23-2003, 01:56 AM
  #5008
hey what the xray evo 1 with heap stuff worth theses day i got two car evo 2 and evo 1 i am looking to buy a monster truck want to know what the evo 1 worth with heaps stuff with it
TheRaven is offline
Old 10-23-2003, 03:18 AM
  #5009
Default Is front one way and anti-roll bar useful?
I am considering to get a front one way and anti roll bar for my T1R. I have seen many people using it on club track. Actually, how does front one way and anti roll bar help stalize the car? Thanks!
discus18 is offline
Old 10-23-2003, 06:57 AM
  #5010
CRASH's Avatar
Trader Rating: 26 (100%+)
The one-way does not help stabilize the car, it alows you to maintain more corner speed.
The anti-rollbar does help keep the car stabilized. Eliminating the car from oversteering(front anti-rollbar) and understeering(rear anti-rollbar). But if you run on a slick or bumpy track then rollbars are not needed. Really only needed for high bite tracks.
Later,
CRASH is offline
