Old 10-15-2003, 07:33 PM   #4981
R/C Tech Charter Subscriber
Originally posted by proudwinner
Cool Nis but was that the first time you've ever run a spool? Gonna make any change to your car? Was there anything you thought could be better?
Naw I ran a spool with my tc3 but it was tearing too much up. I drive faster running a tighter diff than a spool.
NismoSkyline17 is offline   Reply With Quote
Old 10-16-2003, 05:56 AM   #4982
university_dave's Avatar
Arrow
Originally posted by Barry White
Does anyone know when the proto parts from the Japanese Championship will come out?
Look at the JMRCA tread.
The arms are off the T1M 1/12th car, so they'll be out as soon as the car is.
As for the diff, you could make one of those with a dremel...
university_dave is offline   Reply With Quote
Old 10-16-2003, 10:54 PM   #4983
has anybody tried running the low ratio pulley set but leave the stock 34t pulley on the spool?
barnacle is offline   Reply With Quote
Old 10-16-2003, 11:04 PM   #4984
Send a message via AIM to ZER01
barnacle, that will under-drive the car. I tried that once with my xxx-s and to me the car was overall slower.
ZER01 is offline   Reply With Quote
Old 10-17-2003, 01:55 AM   #4985
You could try that in the back, Barnacle. That would overdrive the car which should make it pull even better out of corners.
Old 10-17-2003, 05:56 AM   #4986
sands's Avatar
Chaging just the layshaft pully changes the internal tranny ratio. Just need to adjust the spur/pinion to compensate.
With 34/18, you'd be at 1.88, with 32/18 your at 1.77, 32/16 - 2.0, 34/16 - 2.125. Rollout tables will change to suit.
The larger diff gears do supposedly provide more drag on the belt and more rotational intertia. Both of these will make acceleration a bit more difficult.
sands is offline   Reply With Quote
Old 10-18-2003, 01:04 PM   #4987
Is there any companies that makes the spool for the T1 in stronger versions or in other materials than aluminium? i have destroyed 2 spools this weekend, and that was from quite small impacts, nothing serious, but the outdrives keeps on breaking, and i have not made any full speed impacts, just bumped into other cars...
Hatebreed is offline   Reply With Quote
Old 10-18-2003, 01:27 PM   #4988
psmart2's Avatar
You can make a spool out of a oneway by flushing all of the oil from the one way bearing and using epoxy to secure the outdrives. This has worked very well over the last few months I have been using it. The outdrives show no wear at all. Kind of expensive to waste a oneway, however it's cheaper than replacing aluminum spools.
psmart2 is offline   Reply With Quote
Old 10-18-2003, 02:51 PM   #4989
PS, I've thought about that with the tamiya evo3 since I could not get my hands on a custom made spool and I wanted the outdrives to be steel so they would not wear out like aluminums since the bones do not have blades or a flat pin. I ran a locked up diff made out of the steel AE outdrives and no diff balls with the stock bushings on my tc3 and it was very good as it didn't wear out the outdrives.
Old 10-18-2003, 10:19 PM   #4990
Hey guys since I'm rewiring my esc I figured I'd throw this pic up of my esc, the capacitor are removed from the board and the cap is mounted on top to save precious room. If you're not experienced with soldering on circuit boards I highly advise you to not do this, but it was fairly simple to remove the cap wires off the board, key is to have a hot iron and be very good with your hands. You can also run the switch wire out the side to help configure the GT7.
Old 10-19-2003, 02:58 PM   #4991
Regional Moderator
Send a message via AIM to Mike F
looks good Jesse
Mike F is offline   Reply With Quote
Old 10-19-2003, 03:00 PM   #4992
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Hey guys.. I have a EVO2 with T1R Chassis for sale in the FORSALE section on this board. Also I have about $175 in C-Hub Parts Lot for sale there also.
mike_Webb is offline   Reply With Quote
Old 10-20-2003, 08:02 AM   #4993
Elk666's Avatar
Thumbs up
hi guys, i have a 1 way pro i want to get rid of
check it out:
http://www.rctech.net/forum/showthre...threadid=26276
Elk666 is offline   Reply With Quote
Old 10-20-2003, 10:02 AM   #4994
Neil Rabara's Avatar
Great idea, however adjusting the speedo maybe difficult.
Neil Rabara is offline   Reply With Quote
Old 10-20-2003, 09:20 PM   #4995
RCinfinity, there's no problem getting to the setup button with the cap on top of the case. The LED's aren't covered up either.
