Old 10-02-2003, 08:25 PM   #4861
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Does anyone have a very good Mod Foam setup for high bite carpet. I am using the pivotball suspension.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 10-03-2003, 06:59 AM   #4862
CRASH's Avatar
Trader Rating: 26 (100%+)
Default mike_Webb
Yes, same shock tower I have. Could not get the proper ride height with it. Switched to the kit one and I was back in business. Maybe there is something else that needs to be changed or modified to make it work?
Anyone else have this problem? If so how did you correct it?
Foam tires 63mm or less and C-Hub Suspension setup.
Later,
CRASH is offline   Reply With Quote
Old 10-03-2003, 08:36 AM   #4863
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I think the Team AE Spring Ends are the ticket... I can 58mm last year at Snowbirds with the shock tower and I don't remember having this problem
mike_Webb is offline   Reply With Quote
Old 10-04-2003, 11:23 AM   #4864
Trader Rating: 17 (100%+)
I run 59mm foam tires and with the shock collars all the way up, I could not get below 6mm until I went to the stock shock tower. I was thinking of triming down the bottom shock eyelet to let the spring reataining clip drop down. Anyone tried this?
429racer is offline   Reply With Quote
Old 10-04-2003, 04:35 PM   #4865
mike_Webb's Avatar
Team EA Spring Ends are the ticket/...works great for me.
Old 10-04-2003, 06:48 PM   #4866
Matt04's Avatar
you guys know hoe you can turn your front ball diff into a oneway, by holding the spur and turning the layshaft on an xray evo 2.
would there be a difference if i bought a one way diff for the car, would i get more corner speed or would it just be a waste of money?
Matt04 is offline   Reply With Quote
Old 10-04-2003, 06:58 PM   #4867
Moderator
Personally, I hate one ways and never went faster with one. It is too inconsistent, and provides too much offpower steering for myself. I like the center option though. When its loose it seems to make the car have a little more rollspeed and a slightly better entry into the corner.
SMC Racing
Old 10-04-2003, 08:23 PM   #4868
JoshR 85's Avatar
HeY!!!
TrinityRacinNut you told me that you only like tried it like 2-3 runs and didn't like it and will never try it again. and yeah did you try it again and not like it or are you goin from the time when you tryed em out when you first got the car???
JoshR 85 is offline   Reply With Quote
Old 10-04-2003, 08:43 PM   #4869
Moderator
tried it out, i like the center shaft, but not the front.
SMC Racing
Old 10-04-2003, 08:50 PM   #4870
Carbon_Fibre3's Avatar
hey matt, buy a one way, they are very good! :-)
Carbon_Fibre3 is offline   Reply With Quote
Old 10-04-2003, 09:22 PM   #4871
Scrad's Avatar
Trader Rating: 15 (100%+)
I personally don't like oneways either. I do like the a spool though. I need brakes to drive a car deep into the corners.
Does anyone make a 64 pitch spur bigger than 128. I have to run such a small pinion with the low ratio pullies, like 22 and my motor touches the belt even with the belt tighter.
Also with the motor out, does your drivetran spin better with the low ratio pullies or the stock. My experience seems like the low ratio pullies don't spin for quite as long compared to the stock setup.
Scrad is offline   Reply With Quote
Old 10-04-2003, 09:46 PM   #4872
Does anyone know the proper gear ratio for T1R? I am using a 13 turn motor with 26 pinion 93 spur which came out with a final gear ratio of 7.6 Is this a proper gear ratio?
If I go for 23 turn stock motor, what's the gear ratio I should start with? Thanks!
discus18 is offline   Reply With Quote
Old 10-04-2003, 09:53 PM   #4873
mike_Webb's Avatar
Discus18-
It all depends. After your run wzs the motor too hot to touch? Are the Brushes burned up? How did the speed down the straight feel? How did the punch in the corners feel? There are a ton of variables to look at. I was running a 18 rollout on a carpet track with my 8x2. The motor was coming off the track pretty cool....I could hold it in my hands. I kept going up and up and up and now I am running a 22 rollout...which in my TC3 would have burned up the motor..so it all depends.
I know rollout is important (gear ratio)..but I am finding that if I can get more out of the motor and run it without going out of control or burning it up then I can do some insane gear ratios that some people would never think about doing. Try going up 1 pinion until the motor is too hot to handle or the brushes are burned up...you will know that is too high and go back down a tooth or two and you should be set.
Depending on the Track start with a 6.25-6.50Gear Ratio and go up or down depending on how the motor feels.
Mike Webb
Old 10-05-2003, 03:12 PM   #4874
Default Xray Car Stand
Do you like it?
Michael
siebenelch is offline   Reply With Quote
Old 10-05-2003, 03:44 PM   #4875
mike_Webb's Avatar
Nice
