Old 09-29-2003, 04:48 PM   #4831
The x-ray spurs seem to fit on the car really well .
racerdx6 is offline   Reply With Quote
Old 09-29-2003, 04:50 PM   #4832
mike_Webb's Avatar
Send a message via AIM to mike_Webb
X-Ray spurs are only 48 pitch though
mike_Webb is offline   Reply With Quote
Old 09-29-2003, 04:51 PM   #4833
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
yea 64 pitch baby!!!!!!!! even quieter
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 09-29-2003, 09:47 PM   #4834
XRaycer's Avatar
Cool Club Racing
Hey, just wanted to say My T1R front belt was a bit tight I adjusted it properly and it worked great. I've got the 1.77 pulleys and have been running the layshaft oneway so I had to run the 2.125 pulleys and the chassis worked well but not as fast? So needless to say I put the 1.77 pulleys back in and was on top of the qualifiers and would have won the A if not for that last BIFF. So if there is a question the 1.77 are a better choice (less drag=FASTER) I like Robinson spurs and just drill the extra holes? where do you find the RW spurs? I reside in the Midwest so finding out about the hot stuff is a little slow to arrive? However I'm really looking forward to my next 5 min. TEAM X-RAY
XRaycer is offline   Reply With Quote
Old 09-29-2003, 11:56 PM   #4835
Send a message via AIM to ZER01
Xraycer, the 1.77 pulley set is no doubt better than the stock pulley set. The car is faster with it.
ZER01 is offline   Reply With Quote
Old 09-30-2003, 04:47 AM   #4836
RBLove's Avatar
Trader Rating: 72 (100%+)
I have mixed feelings on the pulley's. For carpet racing on foam tires I "think" the 2.125 pulley's might be a little better. Seems to provide better acceleration. The 1.77 pulley's seem to provide a little more top end. The drive train definitely free spins a hair better with the 1.77's,but the 2.125's seem a little quicker on small tight carpet tracks.
Either way is a win-win situation. It's a good car.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 09-30-2003, 07:02 AM   #4837
CRASH's Avatar
Trader Rating: 26 (100%+)
Kimbrough spur gears fit the solid layshaft the best. With the RW or other brands the holes do not line up properly to get all three screws in.
RW Spur gears are distributed by Schumacher:
http://www.rwracing.co.uk/
Later,
CRASH is offline   Reply With Quote
Old 09-30-2003, 07:09 AM   #4838
The original equipment spur gear (at least those supplied on the original T1) are Kimbrough. If you look carefully at the gear you'll see the name.
calvin is offline   Reply With Quote
Old 09-30-2003, 08:30 AM   #4839
Robinson Racing super mach spurs will fit but only with modification to the spur, you must drill out the other two holes, I used a reamer and it worked perfectly. The spur has absolutely no runout in it.
Old 09-30-2003, 01:52 PM   #4840
I run on a tight carpet track and everyone running x-ray's say the 1.77 pulleys are faster.
Old 09-30-2003, 02:02 PM   #4841
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
See if you can drive their car and tell for yourself. It's hard to tell for speed, but I can assure you, it loosened up my drivetrain a lot.
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 09-30-2003, 09:44 PM   #4842
XRaycer's Avatar
Proud winner- what type of layout do you run on ? It's almost time for our carpet season to start. Just kinda curios?
RBLove- I'll probably do the same and try both pulley sets. What spring and oil set up do you use?
Old 09-30-2003, 09:59 PM   #4843
I'm just going to get the new pully's when I need to rebuild my diff's. So that way I dont have to do it more than I have to.
Old 09-30-2003, 10:04 PM   #4844
mike_Webb's Avatar
Anyone having a hard time getting 5mm ridehieght on their EVO2 with 60mm foam tires and the Foam Front Shock Tower? My Spring Collar is all the way at the top and I am at 6.5mm and cannot go lower unless I use the droop screw to compress the shock.
Also what are you guys running for Droop on your EVO2 for Carpet?
My setup right now is
1.77 Pulley
Med Front Arm
6degree Carrier
AE 50Weight 1hole Purple
Outside on Arm, Third hole from outside on Tower
Camber is upper inside on tower
tight front diff
-1 degree Camber
0 toe-in
Hard Rear Arm
Outside Camber on carrier
Stock Camber on Bulkhead
AE 40 Weight 2 holes Violet
Middle on Arm
Middle on T!R Rear Tower
-1 degree toe-in
-1 degree camber
Med-tight Rear Diff
24/128 Reedy 8x1 KR
Purple Orange Front Tire
Purple Rear Tire
61mm Tire to Start with
no droop screws used...in the arm just backed off on front and rear.. Front has no play on spring and collar, Rear has about 2mm of play beteween Spring and Collar.
Losi Lexus Body Slammed
Old 09-30-2003, 10:13 PM   #4845
RBLove's Avatar
XRaycer
On carpet with foams:
Losi 50 weight front and rear
Typically used 33lb magenta colored X-Ray spring in front and the 30lb pink X-Ray springs in the rear. If an EVO car I like the front sway bar, but on a T1R I liked the car without. I do however like the traditional bar style sway bar better than the blade. It is the bar they came out with for the Raycer.
