Old 09-27-2003, 10:08 AM   #4816
CRASH's Avatar
Trader Rating: 26 (100%+)
Yours came with the 3mm? Mine came with the 4mm, I had to buy the 3mm. What a bummer.
Later,
CRASH is offline   Reply With Quote
Old 09-27-2003, 10:32 AM   #4817
Send a message via AIM to ZER01
Yeah the outside of my box also said..."new evolution parts inside".
ZER01 is offline   Reply With Quote
Old 09-27-2003, 09:09 PM   #4818
What am I the only one who talks here...
Now I know you don't get this with stock AE parts/TC3...pics below
Old 09-27-2003, 09:09 PM   #4819
Right
Old 09-27-2003, 09:12 PM   #4820
R/C Tech Charter Subscriber
Nitpicker
NismoSkyline17 is offline   Reply With Quote
Old 09-27-2003, 09:35 PM   #4821
Originally posted by proudwinner
2? My manual stated 3, why did you use 2? I just finished my kit also and my belt is fine-I see no need for a tensioner.
Proudwinner - I put it in the number 2 position because I had a feeling that the belt was going to be a slight big tight in the #3 position, so I put it in the 2. But it was still kinda tight. Did you build a Evo 2 or a raycer? Because from reading this forum I'm getting the idea that the Evo 2 doesn't have a problem with the front belt being tight when you first build the car. But the raycer does.
racerdx6 is offline   Reply With Quote
Old 09-27-2003, 09:45 PM   #4822
Mine came with a 3 mm rear belt too, must be a running change they made to the kits.
I raced/ran my t1r for the first time today. 19t foams baby . It was awsome, all except for the huge rush I was in. I got at the track at 10:00, and had to remove my esc and reciever from my 12th scale, remove my servo from my tc3, change my packs to saddle packs, check ride height, get holes drilled in my tc3 body to mount it on the x-ray, and rewire my cyclone. Those were all the things I did before the 2nd qualifier (racing started at noon, and I missed the first qualifier). The 2nd qualifier was a mess, I shouldn't of run it. First of all my esc was reversed so I had to push the trigger for the car to go forward, and boy was that distracting to drive. I was all over the place, and my camber was all off too. Not to mention that I was 2 teeth undergeared and my diff's were too loose . But the third qualifier was good, I was faster than I was with my tc3, but the car had a lot of steering so I kept stuffing it in the boards. The main was great, I got a motor rebuilt, I got the gearing set right, the camber was good, and it all worked out great. Not to mention that I could drive it. I LOVE THIS CAR ! It is soooo much smoother than the tc3 was, and way nicer to drive. It's also way quieter and accelerates better. I just cant wait to get some stiffer springs for it, the springs that came with it are much to soft for foams.
Old 09-27-2003, 09:45 PM   #4823
It doesn't. I have both and I took the bulkheads, belts, and diffs f the evo and put it on the T1R. They spun freely on the evo but were very tight on the T1R. I'm currently running them in the second position and they feel great. It seems that the T1R chassis is a little longer.
Old 09-27-2003, 09:49 PM   #4824
Trader Rating: 17 (100%+)
My kit came with a 4 mm belt. It is the older Evo 2 before the freedom of choice came out. I also bought the composite C-hubs for it. I am only putting the c-hubs up front for a simple fact that I cannot adjust the rear end with the c-hubs.
429racer is offline   Reply With Quote
Old 09-27-2003, 10:06 PM   #4825
Not trying to be a smarta$$ or anything, but I believe the pivot ball rear end is just as adjustable as the c-hub rear end. You can adjust the toe by using the little spacers, its also much easier to get the toe equal this way unless you have a set up system. But its still faster with the clips. And you can change the legnth of the rear upper links from the two holes on the bearing carrier. And you can adjust the angle of the upper links by adding washers under the outer eyelet. So in my opinion the c-hub rear end is just as adjustable as the pivot ball rear end. But than again I did just get the car.... just my .02
Old 09-27-2003, 10:28 PM   #4826
racerdx6, sorry about the post, I just realized today my friends front belt is also tight and he has a brand new raycer, totally sorry about the confusion, you would think both kits would be the same.
Old 09-28-2003, 10:52 PM   #4827
edited.
Old 09-29-2003, 03:14 PM   #4828
Cool. I did not know you could shim the rear arms. I was told by another that you could not so that is why I did not put them on there. I have only had the car for maybe a week now so I am new to this car.
Old 09-29-2003, 03:24 PM   #4829
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
other than kimbrough, what other spurs will fit onto the solid alum layshaft? (three hole)
BHenderson is offline   Reply With Quote
Old 09-29-2003, 04:47 PM   #4830
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
RW racing, i really like these spurs, they have less runout and are of a harder plastic, delrin
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
