Xray T1
#4606
Re: Swaybar Question?
Originally posted by CRASH
If your are running pivot ball do you have to use the blade type sway bar or can you use the new front swaybar? I keep hearing the new sway bar is for c-hub only.
Thanks,
Thanks,
//Stu
#4607
I guess the other secret XRay was a 1/18 scale shaft drive car.
Check this out:
http://www.mytsn.com/publ/publ.asp?pid=8902
Check this out:
#4608
Check this out:
Check this out:
#4609
Originally posted by Hatebreed
How do you mount your speedo and reciever in the T1R chassis? got the car yesterday, and i cant figure out how to get the things in in a neat way, I`m running a Vega V2 speedo and a KO reciever, any pics?
I must say that i`m surprised by the chassis, quite stiff with the upper deck, before i got the kit o thought that i was going to get something between std pro3 and evo2 stiff...
Its going to be intresting to compare the Raycer and the evo2 on the track this weekend
As for the electronics, I've had no problems fitting a Keyence Zero-V Extreme and Sanwa reciever, neither of which are particularly small.
#4610
Pivot Ball vs C-Hub
According to the suspension setup guide that XRAY has Pivot Ball is listed as being the best for high bite carpet. Has anyone had any experience comparing the two. I hear the C-Hub is faster then the Pivot Ball but have nothing to base this on.
Thanks,
Thanks,
#4611
I have run piviot ball on carpet. Was much faster using the c-hub suspension.
#4612
Ditto.
I thought that the c-hub kit was the 'Carpet Conversion' renamed?
#4613
Neil- Amen for those five minutes
#4614
BTW, do I know you?
#4616
What is the motor you are going to run?
#4617
Does anyone else run pivot ball on the rear and c hub up front? I just ran mine for the first time today and I like being able to adjust my rear toe in without buying all the hubs.
#4618
buying all the Hubs? All I do is put the adjusters on the inside of the front arm holder and I can get 0, 1, 2, 3, 4 degrees of toe in on each side.... of course you never want more then 3 per side.
#4619
So anybody running a brushless motor in there xray looking for a setup for mine every setup I've tried ether pushes in or off the corner thanks for any help.
