Old 09-01-2003, 09:43 PM   #4531
Accord's Avatar
Send a message via AIM to Accord
Default Re: 1.77 Pulleys
Originally posted by volav
Thanks Accord. Never thought to look there.
Appreciate it
Ross
Glad I could help.
Accord is offline   Reply With Quote
Old 09-01-2003, 10:25 PM   #4532
Default T1R
Hey guys....just wanted to let you know that I have a raycer kit for sale in the forums. Kit has been run about 3 races and has the 1.77 pullys, 3mm belts, graphite front and rear shock towers and shocks have been mounted using the hardware from an evo2 (mounted on balls instead of screwed into the shock tower). Keeping the evo2 but there is no need for both cars. ITs like new!
Joneser is offline   Reply With Quote
Old 09-01-2003, 11:02 PM   #4533
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I got some X-Ray parts for sale Cheap in the for sale section. E-mail me if you are interested.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 09-02-2003, 09:08 AM   #4534
Neil Rabara's Avatar
Default Xray T1M Mini
Looks like the T1M won't be available to the public until christmas time. Hopefully, some people will get it early to promote the car.
Neil Rabara is offline   Reply With Quote
Old 09-02-2003, 07:38 PM   #4535
Scrad's Avatar
Trader Rating: 15 (100%+)
How often are you guys rebuilding your diffs?
Also how long do the stock diff balls usually last and do you ever replace the small balls and washers in the factory installed thrust part.
I have a EVO2 that has only seen about 7 races and the rear diff is gritty, but the front is fine. I also rebuilt my T1 that I got used and the diffs feel like crap. So I was wondering what some of you guys are replacing and and how long some stuff will last.
Thanks.
Scrad is offline   Reply With Quote
Old 09-02-2003, 07:41 PM   #4536
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I've ran mine almost 2 months and i havent had to rebuild them yet, still smooth as glass
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 09-02-2003, 09:31 PM   #4537
I went for months before my first rebuild. If your rear diff is gritty, you may have a problem with assembly, or dirt is getting past the labyrinth dust covers.
Old 09-02-2003, 09:34 PM   #4538
what are the effects of running tighter or looser front diff?
thanks
fReShJiVe is offline   Reply With Quote
Old 09-03-2003, 12:20 AM   #4539
Jimmy Fukuyama's Avatar
thanks
Tighter, more rotational resistence = better acceleration.
Looser, less rotational resistence= better grip or traction.
Bare in mind, your front diff has to be in proportion to your rear diff as this will increase or decrease chassis roll due to resistence. Having a balanced front and rear diff will allow you to gain corner speed which is one of the most important thing in RC racing. If its a big flowing track, then adjusting it tigher will definately benefit you while on technical surfaces, you might want to gain traction for hard left or right. Tire is another thing that coincides with your diff setting. Less traction tires will do good with with loose diff (loose meaning not too tight but not loose where it'll constantly slip), and high traction tires can needs tigher diff or else you will most likely experience some scrubbing off speed.
Jimmy
Jimmy Fukuyama is offline   Reply With Quote
Old 09-03-2003, 07:29 AM   #4540
jimmy - thanks for the clarification...just wondering cause i'm running slightly looser setting on my front(no slipping)...so i was wondering what would happen if i were to tighten the front slightly(as tight as the rear)...as of now i really like how the car handles so i'm not going to touch it without knowing what it will do to the handling of the car...any more comment regarding this would be really appreciated
thanks
Old 09-03-2003, 07:35 AM   #4541
Scrad's Avatar
Jimmy, I e mailed you about some parts I needed.
So what parts are you replacing when you do rebuild. Because with my trucks I'd normally just replace the washers and replace the balls about once a year.
Old 09-03-2003, 08:48 AM   #4542
rayhuang's Avatar
thanks
For me in and my testing-I always use these simple rules and it works for me every time.
TIghter front diff for more on-power steering out of corner. Might hurt turn in somewhat. Car feels very direct, but may be harder to be consistent from corner to corner, but FAST. Yu can jump on throttle sooner.
Looser rear diff for more aggressive turn in, might hurt acceleration (speed out of corner) just a tad.I dont stray away from those principles because thats the extent of my testing and experimenting.
I would always try to start with both diffs the same tightness (Well-as cose as you can feel), tight enough to not slip-but not locked.
If car pushes on exit-tighten that front diff. if car is lazy turning in-loosen rear diff. Or a combination of the two.
ALSO-and I thnk this is the key to testing-dont go battery pack to battery pack when doing this type of changes. RUn 5 or 6 laps-come right in-make the change and go right back out. Try and drive as consistent as you can.
Old 09-03-2003, 09:29 AM   #4543
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Are you guys still using the stock grease that came with the xray or did you make a switch? I have mugen super grease that is a tad too heavy but works well on my 705 centax clutch thrust bearing. I have tried Associated black grease that seems to work well. Using it sparingly is the key though.
John Fontaine is offline   Reply With Quote
Old 09-03-2003, 11:33 AM   #4544
I still use the stock grease that came in the syringe. I hadn't had any problems with it, in fact I use it sparingly. Devin, why would you switch to another type of grease?
Old 09-03-2003, 12:03 PM   #4545
Accord's Avatar
I used the syringe up until it ran out, then I switched over to Trinity Joel Magic Johnson silicone on road diff oil. Supposedly it's "specially formulated for on-road racing" . It does work pretty well and I reccomend it to everyone.
