Old 08-05-2003, 02:02 AM   #4276
RBLove's Avatar
Trader Rating: 72 (100%+)
EVO2 does come with the same composite plastic arms/hubs/c-blocks. For any rubber tire racing I would recommend the T1R. If your weather conditions are EXTREMELY hot I would get the EVO2. The guys at the Nats switched to the EVO2 and their cars were much better. It was about 100 degrees there.
If your weather and track temp is not crazy hot I would get the T1R. More traction and saves money........
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 08-05-2003, 07:44 AM   #4277
RandyB's Avatar
I beleive the solid top deck comes with the bearing holder
RandyB is offline   Reply With Quote
Old 08-05-2003, 08:01 AM   #4278
Suspended
Trader Rating: 28 (100%+)
Default t1r and carpet
Would you guys think that the t1r with the solid top deck would be stiff enough?I tried it and it seemed more then stiff.At least as stiff as an evo2.
racenut123 is offline   Reply With Quote
Old 08-05-2003, 08:52 AM   #4279
Neil Rabara's Avatar
Default Re: t1r and carpet
The car is just as stiff as the Evo2 with a force applied to the car front to back. But the car is more flexible than the Evo2 with a transverse force (twist), even with the graphite solid top deck.
Neil Rabara is offline   Reply With Quote
Old 08-06-2003, 12:51 AM   #4280
What type of tires do all of you run with your Xray? Just curious.
Old 08-06-2003, 01:10 AM   #4281
RBLove's Avatar
Neil,
I run carpet/foams only. Mainly TRC and Jaco.
TRC:
Plaid front 26mm
Cyan front 26mm
Lime front 26mm
Magenta rear 30mm
Tan rear 30mm
Purple rear 30mm
I often cut the rear widths down to 28 and 26 depending on track and conditions.
Jaco:
Purple/Orange front 28mm
Purple rear 28mm
Double pink rear 28mm
Paragon traction compound or Jack the Grippa by Corally. Prefer Paragon when allowed.
Old 08-06-2003, 06:16 AM   #4282
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
RBLove,
What procedure do you use to cut down your widths. I have some 28mm that need to be cut down to 26's. Do you slap them on your lathe, spin and cut through with the bit? Or use an external cutter, xacto or someother thing? Im curious as I need to do this. I have a Hudy with carbide bit.
John Fontaine is offline   Reply With Quote
Old 08-06-2003, 08:56 AM   #4283
i use an xacto knife to cut the tire down to the width i like. u might want to try that method.
jiggamacdaddy is offline   Reply With Quote
Old 08-06-2003, 09:24 AM   #4284
rayhuang's Avatar
Default HELP!!!
Hey guys,
I am building my third generation of Xray for testing and racing!!! This one is a original Xray T1, but with the 1.77 PUlleys. Here are my two very important questions.
1. Is the Center Steering POst of the Old style steering different than on the EVo2?? One looks offset and the other looks centered.
2. The old T1 front bulkheads do not have a belt tensioner eccentric. Anybody know what setting it is as comprared to the EVO2 bulkheads?
Thanks in advance,
Ray
This car is going to be PB front and c-hub rear. Hope its fast in stock class on foam/Carpet!!!
Old 08-06-2003, 10:40 AM   #4285
Neil,
TRC:
Plaid front 26mm
Cyan front 26mm
Lime front 26mm
Magenta rear 30mm
Tan rear 30mm
Purple rear 30mm
Jaco:
Purple rear 28mm
Thanks RB, I'll keep this in mind if ever a carpet track opens up here in sunny southern cali.
Old 08-06-2003, 01:06 PM   #4286
c-lyon's Avatar
Ray, on the original T1 with the non-flex top deck the bearing insert is offset to the left. With either of the flex top deaks the insert hole is larger and centred, and the bearing holder itself is larger and offset.
Can't help with the other.
c-lyon is offline   Reply With Quote
Old 08-06-2003, 11:12 PM   #4287
RBLove's Avatar
Ray,
The steering hole may be centered, but I "believe" the plastic cup that hols the bearing is off set??????
As for a set up with pb? I "think" at Cleveland I ran the same piston and spring, no sway bar, and car was money. I can try to help you Tuesday. Between myself, Pulfer, Junior, maybe Ian, and you we have no excuse but to be DIALED...........
Old 08-06-2003, 11:23 PM   #4288
RBLove's Avatar
Devin,
I put the tire on my truer and spin it in the opposite direction, then I use a utility knife to make the cut. I use the utility knife over an exacto because it is much stiffer and does not flex. IF the exacto starts to flex you're screwed
Old 08-06-2003, 11:25 PM   #4289
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Been there... did that
Had a tire that was 28mm then down to 18mm then back to 29mm then down to 22mm then back to 25mm then a big slash all the way to the outside wall
Be very careful
mike_Webb is offline   Reply With Quote
Old 08-07-2003, 10:13 AM   #4290
Maybe it's not a good idea to try to cut it that way. Wouldn't it be better to just get the rims in that size?
