Old 07-28-2003, 03:24 PM   #4201
Default Re: Re: xray rocks
Originally posted by RCInfinity
Find me at the track, I'll give you a good starting point. Next time I'll be there is tues. Find me!
Thanks. I probably won't be out there to race until Aug 9. I will try to get out there to practice during the days between now and then.
I am running my T1R with the stock setup using
Sorex 36r, hpi green insersts
Monster Stock motor
27 pinion, 93 spur
jbackslash is offline   Reply With Quote
Old 07-28-2003, 05:36 PM   #4202
Default Re: Re: Re: Re: Re: Re: xray rocks
PM
I got it, Thanks
milf is offline   Reply With Quote
Old 07-28-2003, 06:15 PM   #4203
Matt04's Avatar
does the evo 2 FOC have the same gear ratio as the T1R(2.125) and if they do does this mean that they would probly perform at the same level. and is there any other way to improve your accelaration other than the pulleys, and what hop ups would u think the T1R would really need to perform against the other top cars in 540(other shatf cars). thanks Matt
Matt04 is offline   Reply With Quote
Old 07-28-2003, 06:28 PM   #4204
Suspended
Trader Rating: 28 (100%+)
Default Matt,Matt,Matt
If you want stronger acceleration then buy the pullies.Use them on either car.It was already explained to you several times why you want the pullies.Both cars have the same ratio in stock form.2.125.So you have not bought a car yet?Your request for info whether or not you should buy the car for 540 or a 2wd class is kind of hard to answer for you as most here race normal classes.Stock or mod.But 2wd?Why even bother?
racenut123 is offline   Reply With Quote
Old 07-28-2003, 10:12 PM   #4205
HYDRAMATIC99's Avatar
Send a message via AIM to HYDRAMATIC99
Hey everyone, as far as rollout goes in stock racing using monsters/p2k2's/core's etc it seems like most are running about 7.2, correct? Is this with the old pulleys or the new pulleys? What rollout should i be shooting for for both sets of pulleys? Thanks in advance.
HYDRAMATIC99 is offline   Reply With Quote
Old 07-29-2003, 03:28 AM   #4206
Carbon_Fibre3's Avatar
Default Re: Matts query
Matt, do not panic about this acceleration mumbo jumbo, your driving will make a bigger difference than all the hop ups in the world. The Xray is clearly a competitive car where u race, Adam Formby in stock, Jake Zarb in mod, and at one point bradd vercoe in 540 v8. These guys compete against all comers (car wise) from tc3 and evo 3 to losi xxx-s's etc.. and still come out on top..
money spent on hop ups is money better spent on practice
Carbon_Fibre3 is offline   Reply With Quote
Old 07-29-2003, 07:12 AM   #4207
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Does anyone know where I can find a 128 64 pitch spur to run with the 1.77 gears? Kimbrough's fit the solid alum mid shaft perfectly and they seem to be the only ones that fit without drilling new holes. Towerhobbies does not carry it and I can't seem to find it on kimbroughs website. What's everone using?
A fellow racer this weekend had a trinity 128 64 pitch, but only one screw hole lined up
John Fontaine is offline   Reply With Quote
Old 07-29-2003, 07:31 AM   #4208
rayhuang's Avatar
Default Spur gears
Devin,
Because the layshafts have the friction fit center hub, all you need to do is drill yourself two more holes in the spur gear. I did that with my RW spur gears to fit on the solid aluminum layshafts. I sold out of 128 kimbroughs or else I would send you one.
Ray
Old 07-29-2003, 08:38 AM   #4209
Ray, are you getting more of the kimbrough 128's in soon? If so let me know and i'll pick one up. Or, if you have another 128 alternative gear that requires drilling let me know if you have it in stock (ie. Robinson Racing)
Old 07-29-2003, 09:02 AM   #4210
rayhuang's Avatar
Devin,
I am afraid I wont be ordering anything for awhile. We have one race and practice left at our track then we take a long deserved break to get ready for the Fall. So not much demand for parts right now. IN fact on my car I am just running a used/old 122 RW spur on the solid alum layshaft.
Ray
Old 07-29-2003, 10:15 AM   #4211
Devin,
Send me a PM, and give me your address, I'll send you one of those 128 spurs
Old 07-29-2003, 10:29 AM   #4212
Originally posted by Jimmy Fukuyama
Hi Sherman,
No, I didn't when did you send it? can you re-send it again?
Jimmy
Hi Jimmy,
I had re-send the email.
Sherman
Old 07-29-2003, 10:47 AM   #4213
Originally posted by milf
Devin,
PM sent, Thanks!
Old 07-29-2003, 11:02 AM   #4214
PM sent, Thanks!
I got your message, and i'll send it today or tomorrow,
Old 07-29-2003, 11:20 AM   #4215
Neil Rabara's Avatar
I like the Kimborough spurs, the material they are made from makes the car very quiet. The only problem is they aren't perfectly round. The RW spurs are very very nice! Yet they are a bit louder and you need to drill or dremel two holes to line up with the center shaft.
Neil Rabara is offline   Reply With Quote
