Old 07-23-2003, 12:58 PM   #4126
Accord's Avatar
Send a message via AIM to Accord
Originally posted by ziggy12345
How are they wired together? Have you got a pic?
Cheers
I have my battery setup identical to the saddle pack setup that is reccomended in the manual and is in the picture on the box and in every picture in every magazine.
Accord is offline   Reply With Quote
Old 07-23-2003, 01:09 PM   #4127
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
heres a pic for ya if you need one
BHenderson is offline   Reply With Quote
Old 07-23-2003, 06:53 PM   #4128
Oasis's Avatar
Trader Rating: 36 (100%+)
Matt04, I own both an xray(upgraded to an evo2) and an alex R2 cuda,I like both cars but I like the xray a little more,not as many problems with the xray as their are with the cuda..like eating spur gears(that problem can be fixed but it's going to cost you $90 us)If you want your xray to get out of the corners like a shaft car you get the 1.77 pulley set($30us)I think the Xray is easier to work on,has more radio room on the T1R than the cuda(I really did not like cutting part of the servo's mounting tabs)One drawback on the Xray..saddle packs.but as far as money spent goes the T1R is a screaming deal,the problem with the cuda is striped spur gears,in 3 years racing I think I have striped 1,then the cuda, 1 a day untill I bought the alum shaft mounts,I still strip them just not as often.My choice would be the Xray or the Tamiya evo III.
Oasis is offline   Reply With Quote
Old 07-23-2003, 09:29 PM   #4129
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Default Re: Re: Re: Re: Re: pullies
Originally posted by Rick Draper
On the stock layshaft of the evo 2 there are 2 pin holes, you use both of these to pin the gears in place then to holt the gears in place you use the 3 dome washers and the plastic nut that you would normally use to lock the 1 way. I will take some pics later on if i get chance. Its all very simple and you build it like the normal 1 way setup. Rick
hi rick,
i know there's 2 holes on the evo 2 layshaft. but i've heard of the plastic nut loosen up sometimes! i'll just gv it a try and add a dab of threadlock on the threads to prevent them loosening up. thanks alot pal.
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 07-23-2003, 10:03 PM   #4130
Regional Moderator
BHenderson's Avatar
just curious not meaning to get at anyone, but why are saddle packs an issue? Instead of using another bar you have a piece of wire to connect to the next cell. I make mine real short, not tight but short. That way if I did want to use them in like an associated off road truck they will fit no problem and you dont have to deal with a lot of extra wire.
In my mind the only way to distribute the weight of the items you have to have on the car evenly, (batts, servo, esc, rx) saddle packs are the way to go, I only have the center weight on my car and the car is perfectly balanced side to side. The only reason for the center weight is so that my car is 53 oz.
just my 2 cents on that.
Old 07-24-2003, 12:09 AM   #4131
Matt04's Avatar
so how much does it cost to convert the T1R into an T1 EVO 2?and does the c hubs on the T1R a composit material like the T1 or is it plastic?
thanks
Matt04 is offline   Reply With Quote
Old 07-24-2003, 12:37 AM   #4132
(SE)XRAY's Avatar
Hey guys,
Does anyone have a good setup for Carpet racing?
Raing with foams.
Its a nice short track !
Any help would be good.
(SE)XRAY is offline   Reply With Quote
Old 07-24-2003, 02:59 AM   #4133
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Anyone have any Xray Decals they want to give away? Ill pay for postage. Thanks
Email me
DOMOisCOOL is offline   Reply With Quote
Old 07-24-2003, 06:50 AM   #4134
CRASH's Avatar
Trader Rating: 26 (100%+)
Snowbird Nationals
Has anyone here raced at the Snowbirds, who has an EVO2? Looking for a good starting setup for stock and 19 turn.
Appreciate the help,
Later,
CRASH is offline   Reply With Quote
Old 07-24-2003, 08:26 AM   #4135
pucho's Avatar
Send a message via AIM to pucho
OK, but what are you using to space it on the other side? Normally the oneway takes up that space where as the solid lay shaft comes with a spacer specifically for that purpose. Buying the solid lay shaft is just so much better because of the rotating mass that you are eliminating. that's my .02!
pucho is offline   Reply With Quote
Old 07-24-2003, 10:48 AM   #4136
Neil Rabara's Avatar
Good point Porche. I've found that the stock batt positions is the way to go. By moving the batts forward or to one side, that will upset the balance of the car.
Neil Rabara is offline   Reply With Quote
Old 07-24-2003, 11:00 AM   #4137
John Fontaine's Avatar
Send a message via AIM to John Fontaine
For you guys that are running the 1.77 gears, did you have to tighten the positions on the rear bulkheads as there could be more slack in the rear belt? Im switching to the new 3mm high speed rear belt. If so, how many did you advance to have a loose belt but not slipping?
John Fontaine is offline   Reply With Quote
Old 07-24-2003, 11:01 AM   #4138
Regional Moderator
BHenderson's Avatar
devin,
I didnt have to move mine at all. when the car is still it looks as if the belt will rub against the motor, but once you get on power the belt never touches the motor.
Old 07-24-2003, 11:19 AM   #4139
I didn't tighten the eccentric hubs either. I did have to purchase a large spur gear so that the motor clears the new pulleys.
Old 07-24-2003, 11:28 AM   #4140
Thanks guys. I'll have to see if I can round up a 128 gear as a 124 is the biggest that I have. Are you guys still running around a 7.2-7.5 for a monster stock with the 1.77's?
