Old 07-11-2003, 02:00 PM   #4051
CRASH's Avatar
Trader Rating: 26 (100%+)
All of my batteries are already configured that way from my FTTC3.
Later,
CRASH is offline   Reply With Quote
Old 07-11-2003, 04:46 PM   #4052
Oasis's Avatar
Trader Rating: 36 (100%+)
Well sense you are an OU fan we will let it slide..
Oasis is offline   Reply With Quote
Old 07-11-2003, 07:42 PM   #4053
Neil Rabara's Avatar
Later,
That's what I said when I got my first Xray. Then I tried saddles, and I haven't looked back. The transitions are much much better, and the car is balanced. With the new 3300's out nowadays, there would be so much weight on the side of the batteries that it would be difficult to balance the car unless you add a ton of weight.
Neil Rabara is offline   Reply With Quote
Old 07-12-2003, 07:11 AM   #4054
CRASH's Avatar
Default Saddle Packs.
Allright I am convinced. It took me this long to try this car that I am going to go ahead and do saddle packs. I can always switch it back later.
Thanks for all the help.
Later
Old 07-12-2003, 08:21 AM   #4055
pucho's Avatar
Send a message via AIM to pucho
CRASH: You can always use the saddles on the FTTC3
pucho is offline   Reply With Quote
Old 07-13-2003, 09:02 AM   #4056
Suspended
Trader Rating: 28 (100%+)
Default vht
Anyone have a setup they run on vht and rubber tires?Thanks!
racenut123 is offline   Reply With Quote
Old 07-13-2003, 09:56 PM   #4057
If you are refering to asphalt, high bite, Ralph Burch recently put up his setup from the ROAR Nats on myTSN.com
Old 07-14-2003, 05:45 PM   #4058
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
hey guys quick question,
on Ralphs setup for the On Road nats last month in NC he has a preload of 4mm and 5mm on his shocks respectively. When measuring this pre load on my own car, I assume you measure from the bottom of the cap to the collar around the spring is that right?
thanks
BHenderson is offline   Reply With Quote
Old 07-14-2003, 06:07 PM   #4059
RBLove's Avatar
Trader Rating: 72 (100%+)
Porsche,
I honestly do not know. I "NEVER" run any preload on my springs. I would almost think he was talking about uptravel (droop). Not sure!
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 07-14-2003, 07:39 PM   #4060
Preload can be measured from the top of the shock collar to the bottom of the shock cap. That's arbitrary though, some people measure the preload by how compressed the spring is. But from the sounds of it, Ralph's preload is the former.
Old 07-14-2003, 09:59 PM   #4061
Carbon_Fibre3's Avatar
RBLove, if you never run any preload how do you get a decent ride height?
Carbon_Fibre3 is offline   Reply With Quote
Old 07-14-2003, 11:36 PM   #4062
RBLove's Avatar
I run foams at 3 to 4 mm of ride height and do not have a problem with ride height. I run the lowered shock tower in front and run in the lowest row of holes on the ultra tune shock tower on the rear. I usually build my shocks a little long. I measure my droop by up travel "after" I set my ride height. Droop setting will have a lot to do with preload and ride height.
Old 07-15-2003, 12:28 AM   #4063
ahh yep i understand, thanks
Old 07-15-2003, 08:13 AM   #4064
Scrad's Avatar
Trader Rating: 15 (100%+)
I need some help. My car handles pretty good at the parking lot track I've been racing. But there are 2 180's that I have a hard time with. The car usually doesn't turn tight enough or I have to brake and get the rear end to slide around and it's cutting down my corner speed. My expo it all the way up on my radio for full travel. I've moved the front shock all the way in. What else can I do to make the 180 better? Move the camber link in on the bridge? Or soften the front spring? Thanks guys.
Scrad is offline   Reply With Quote
Old 07-15-2003, 11:09 AM   #4065
Default i need help on my T1...
i have a problem with the hex screws on the top deck near the left arm, i damaged the screws and now i can't loosen it.. i was actually going to try the top deck of the T1 Evo2 which is softer than the stock top deck of the T1.. my friends suggested that i use a dremel tool, unfortunately, i don't have one. i tried filing it (as in a flat screw) it but i can't go deep enough without scratching the carbon.. any suggestion guys?
thanks in advance..
rcprix is offline   Reply With Quote
