Old 06-10-2003, 12:29 AM   #3706
Default Servo
The Evo2 and this car have been great to build...I really appreciate the craftmanship. The raycer did have a diff that was not put together correctly but that was easily fixed after getting a tool. The servo mounts are a total of .2 inches wide. I can fit a 2.5 mm hex wrench between the servo and each mount so obviously it is not holding much servo.
Joneser is offline   Reply With Quote
Old 06-10-2003, 12:30 AM   #3707
Default shoo goo?
did you just squeeze the shoo goo between the mounts and the servo?
Old 06-10-2003, 12:38 AM   #3708
Joneser, I think Jimmy meant to Shoo Goo the servo to the bottom of the chassis. You can also use servo tape on the bottom and Shoo Goo around the edges.
Headbanger is offline   Reply With Quote
Old 06-10-2003, 05:45 AM   #3709
ICEMAN's Avatar
the servo mounts are a little wide but they will fit any servo. i run jr8450's in my xray's and have no problem just let the servo sit in both mounts equally and tighten them up. this holds it tight enough that if you don't space it in on the EVO'S that in most cases you'll break the servo case if you get hit on the passenger side.
jimmy
you're right the car has just the same a mount of rip as the others, and the motor is really close at 7.50
Blizzard Concepts / Team Losi / Team ProMatch / Team MuchMore / The SPEED Shop / Ko Propo USA / AVID RC / BigDog Graphics / Nitro R/C Chop Shop /
The ONE that DIES with the Most Toys WINS!!!
ICEMAN is offline   Reply With Quote
Old 06-10-2003, 08:30 AM   #3710
rayhuang's Avatar
Default T1R servo
Heres a pic!!! I also shimmed it back quite a bit to get the angle out of the drag link. Then as added insurance- i put a crush spacer between the servo and mount in case of a head on collision!!! I hope you can see it in the shot. Its nothing more than thick paper stock wrapped in tape.
Old 06-10-2003, 08:36 AM   #3711
rayhuang's Avatar
Oh-yeah-I also had to use a Tc3 Servo shim and I also used two 4-40 washers (wide ones) to really clamp the servo down onto the mounts. I knew I couldnt screw the screws in too tight as I might strip the mounts-so this is my possibly over-shade tree mechaniced way of doing it!!!
The worst part is this is not the servo I intend to use in the car. My other didgital JR8450 died in the gas car over the weekend so I had to put this Airtronics 94157 servo in it.
Old 06-10-2003, 09:19 AM   #3712
rc-zombies's Avatar
Default Re: Re: New 1.77 pulleys
Originally posted by Jimmy Fukuyama
Hi RC,
I hate it when I have another secret but can't disclose this in the forum. I'll email you and let you in on it, but you'll be so surprise and in for a real treat once you know how that is done. I'm sure you'll kill your same class competitions with this.
Jimmy
Thanks Jimmy...looking forward to your secret...
Old 06-10-2003, 01:20 PM   #3713
Neil Rabara's Avatar
What type of servo is that 157? Does it have plastic gears?
Neil Rabara is offline   Reply With Quote
Old 06-10-2003, 01:34 PM   #3714
rayhuang's Avatar
Neil,
The 157 is the predecessor to the 94257. It is metal geared and whicked fast. I believe the specs are: 0.06 to 60* and 93 oz torque at 6v. Its pretty old by now-but working fine.
Ray
Old 06-10-2003, 01:44 PM   #3715
Neil,
Ray
Oh okay
I was trying to find it on the Airtronics servo specs page. I have a similar servo as well and didn't know the specs. I had to e-mail Airtronics and get the specs. Old as well.
Old 06-10-2003, 08:51 PM   #3716
RBLove's Avatar
Trader Rating: 72 (100%+)
Anybody know where I can get the new pulley's?????
Thanks!
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 06-10-2003, 09:03 PM   #3717
Thanks!
I e-mailed Serpent-USA last week about the new pulleys. I got a reply from Ralph saying they were due in this week. You may want to call in an order if you want them right away. Unless, Jimmy has a secret stash of them....
Old 06-10-2003, 09:08 PM   #3718
Jimmy Fukuyama's Avatar
Thanks!
Hi Rob, Err........ I might have one or two laying around.
Jim
Jimmy Fukuyama is offline   Reply With Quote
Old 06-10-2003, 09:40 PM   #3719
RBLove's Avatar
Let me know Jimmy.
[email protected]
I do not have e-mail access at work, but I am off at 7:00 a.m. est... I can check then...
Old 06-10-2003, 10:09 PM   #3720
Default Oil help
Can anyone help me with a comparison of shock oils (xray, Associated, Losi). I have various setups that use the different oils and I would like to get an idea of a weight comparison. Thanks
