Old 06-02-2003, 12:10 AM   #3571
Hey guys!
Andrew Swanson did a great job on running the T1 Raycer at the 4th Anuaul "SpeedWorld Cup" race in Roseville California. He took 3rd in the Expert Mod class, (1st place was Greg Hodapp, 2nd was Matt Francis), the car was pretty much stock out of the box, except of the following: Alu Shock body, and the bulk heads off the Evo 2.
Andrew thanks for the help over the weekend.
milf is offline   Reply With Quote
Old 06-02-2003, 05:44 AM   #3572
The Teacher's Avatar
Trader Rating: 48 (100%+)
Rayhuang, which bulkheads are you running on you hybrid car T1R or EVO 2??? Looks to me that the T1R bulkheads are just about the same, am I missing something. Do you find one better for carpet than the other???
The Teacher is offline   Reply With Quote
Old 06-02-2003, 06:19 AM   #3573
RandyB's Avatar
The Bulkheads are the same except finish. I also noticed that the cams forthe diff bearings are different. I think you move them opposite. I have to check my manuals again.
later
randyb
RandyB is offline   Reply With Quote
Old 06-02-2003, 06:34 AM   #3574
Oasis's Avatar
Trader Rating: 36 (100%+)
I just finished installing the c hub kit on my T1 and man that took forever..I'm not sure if i'm slow or it really does take a long time,I hope it's worth it..
Oasis is offline   Reply With Quote
Old 06-02-2003, 07:30 AM   #3575
The EVO2 bulks are the same only not hard annodized aluminum...... The Duraluminum is quite strong enough that it doesn't need to be hard annodized.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-02-2003, 07:57 AM   #3576
dtm
dtm's Avatar
Send a message via ICQ to dtm
Strong it is....but the surface gets scratched really easily.
dtm is offline   Reply With Quote
Old 06-02-2003, 10:25 AM   #3577
c-lyon's Avatar
Joneser, I did similar to IMPACTPLAYR, but used an L shaped strip of lexan (waste from a body), and servotaped to the chassis. It's flexible enough to install the batteries with no problem, and so far no lost batteries. I lost two prior to the fix.
c-lyon is offline   Reply With Quote
Old 06-02-2003, 11:51 AM   #3578
Neil Rabara's Avatar
Some people have had that problem with the batts popping out, but only those that filed the edges of the batt slots. I noticed the problem after a couple of Xray drivers short circuited their batts. I decided not to file the edges and hadn't had a problem with the batts popping out.
Neil Rabara is offline   Reply With Quote
Old 06-03-2003, 09:44 AM   #3579
rayhuang's Avatar
Default 1.77 pullies
I got my 1.77 pulleys installed and yes-by god-the drivetrain is much freer!!! my 3mm belt was on back-order-so I am not getting the full effect!! But it is freer-no doubt.
I moved the eccentrics around quite a bit-based on where Neil and Ralph said to set-them, but I did go one looser front and rear as they felt too tight for stock racing, but-I could be wrong.
But-the front and rear belts are still as tight or tighter than how I had them before.
Just FYI-The belt tensioner has an amplified affect on the belt now. At its loosest position at applies more pressure on belt than the stock pulley set-up. I took mine off for now.
Ray
Old 06-03-2003, 09:54 AM   #3580
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Ray, where did you get these from?
John Fontaine is offline   Reply With Quote
Old 06-03-2003, 10:26 AM   #3581
Exclamation
Hey Ray. Do you remember how much that new pullies set and new rear belt cost? Or is it secret I`m just courius to know, because i do not see prices nowhere
Proto pilot is offline   Reply With Quote
Old 06-03-2003, 10:27 AM   #3582
rc-zombies's Avatar
I got my pullies for $34.00 and 3mm belt for $8.00
Old 06-03-2003, 10:29 AM   #3583
Where did you get them?
DOTMAN is offline   Reply With Quote
Old 06-03-2003, 10:32 AM   #3584
rc-zombies's Avatar
Not allowed to say...I will be shot if I do...
Private supplier Unfortunately he is all out of the belts
and liquidating all his Xray parts.
Try contacting Jimmy...you can find him on this thread...
Old 06-03-2003, 10:33 AM   #3585
Jimmy Fukuyama's Avatar
Default Re: 1.77 pullies
Ray
Ray, did you mill your belt down? or what?
Jimmy
Jimmy Fukuyama is offline   Reply With Quote
