Old 04-14-2003, 09:52 PM   #3241
Warlord - you are running 5mm of rear droop? this is a ton of droop and that is what would be making your car oversteer, as the rear end would be getting extremely light under braking and thus transferring all of the weight to the front. Try and reduce rear droop to 3mm and you will ber much happier
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-15-2003, 02:11 AM   #3242
warlord385's Avatar
But would 3mm droop make more weight transfer to the front. on the Hudy by increasing droop you decrease weight transfte to the front. U mean using droop gauge on hudy blocks and its 3mm about 0 right. This would mean that more weight is transfered to the front if i am correct
warlord385 is offline   Reply With Quote
Old 04-15-2003, 05:08 AM   #3243
Sorry as you said it i thought you meant 5 mm of static droop not number 5 on the block.
Sorry i dont really go by these numbers as using foam tires this figure is constantly changing
Old 04-15-2003, 07:00 AM   #3244
omalley's Avatar
Send a message via AIM to omalley
Default New XRAY Owner
i just got a Xray, looking forward to driving it.
omalley is offline   Reply With Quote
Old 04-15-2003, 07:39 AM   #3245
rayhuang's Avatar
Omalley-are you still planning on running on Brushed Concrete track? If yes-Remember-softer compound tire (CS27 to 32) with a medium to firm insert and No Air Gap between insert and tire!!! Anything else and you'll tear those tires up in a few heats!!!
Old 04-15-2003, 11:29 AM   #3246
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Default Re: New XRAY Owner
Welcome...it's a wonderful car.
John Fontaine is offline   Reply With Quote
Old 04-15-2003, 11:38 AM   #3247
omalley's Avatar
yep still planning on running on brushed concrete, and also carpet. thanks for the tips
Old 04-15-2003, 12:00 PM   #3248
Send a message via AIM to Alex Lopez
Whats up guys,
Well i drove my Xray again this past weekend and i am very pleased with the car once again.I won the touring class in 19 turn pro and the car just kept getting better and better.As i would make an adjustment according to the track changing,the car would answer to the change.If yoiu guys would like the set-up i used for ashpalt with cs-27's,let me know.
Alex Lopez
Alex Lopez is offline   Reply With Quote
Old 04-15-2003, 12:06 PM   #3249
pucho's Avatar
Send a message via AIM to pucho
OH! Please give me your set up MASTER!!
pucho is offline   Reply With Quote
Old 04-15-2003, 03:14 PM   #3250
omalley's Avatar
Default parts
what are some good sites for xray parts?
Old 04-15-2003, 04:35 PM   #3251
Jimmy fukuyamas site has alot in stock i have heard, he is on this forum as well. he should be able to help you out.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 04-15-2003, 07:22 PM   #3252
pucho's Avatar
Default T1R
Has anyone ran this car yet? I have been really thinkering with the idea. I can get one really cheap. any sugestions or coments are wellcome. Also what are the most comonly used springs in the lineup?
Old 04-15-2003, 07:53 PM   #3253
RBLove's Avatar
Trader Rating: 72 (100%+)
I think a T1R with thick carbon top deck and carbon shock towers would be killer............. It would stiffen the car up nicely for carpet.
I think have X-Ray has some of the best springs on the market. Very consisten. I would recommend buying the kit. You get 4 springs of each rate..........................
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 04-15-2003, 08:42 PM   #3254
Default top deck
For those of you running on carpet......which top deck are you using. I purchased the solid top deck which really stiffens the car up. I drove R. Huangs car today in testing and he has the stock top deck on the car......I liked his car a little better but I was not sure if it was the top deck causing it.
Joneser is offline   Reply With Quote
Old 04-16-2003, 03:46 AM   #3255
university_dave's Avatar
For carpet I use the original chassis and top deck. I've found that otherwise the car is lazy into turns and is really inconsistent.
university_dave is offline   Reply With Quote
