Old 04-04-2003, 03:14 PM   #3136
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Default Easy there skippy
perhaps I just want my X-Ray to be at its best when I do a head2head with the ABC. There both mustard as far as I'm concerned :-)
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-04-2003, 03:28 PM   #3137
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: RCI tell me about your C-hub setup
Originally posted by RCInfinity
I see you couldn't resist getting back to the "real car", not that toy you've been tinkering with.
Toy ummmm OK
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-05-2003, 09:57 AM   #3138
Neil Rabara's Avatar
Default Re: Easy there skippy
ABC? Mustard? Don't you mean Cuda, and gravy?
Neil Rabara is offline   Reply With Quote
Old 04-05-2003, 10:34 AM   #3139
Default wassup RCI
Shouldn't you be out at Tamiya playing with your new eVoIII
Old 04-05-2003, 01:40 PM   #3140
Default Re: wassup RCI
You must have me confused with someone else. I don't have an eVoII, it's a F201! Considering all that redbull you drink, I can understand the simple mistake.
Old 04-07-2003, 08:43 AM   #3141
rayhuang's Avatar
Can someone please supply me with a part number for the latest and lowest front shock tower for the evo2? I need a lower shock tower than the C-hub one so I can get my body lower. Right now its sitting on top of the shocks. I need to drop my body at least 1/8" if not a little more!!!
Thanks,
Ray
Old 04-07-2003, 08:57 AM   #3142
rc-zombies's Avatar
Ray
Use the Ultra tune shock tower:
http://www.teamxray.com/teamxray/pro...hp?prod_id=529
it's about .25in lower than the stock C-hub tower.
Old 04-07-2003, 09:07 AM   #3143
rayhuang's Avatar
rc-zombies to my rescue again!!
I thought my car had the Ultra-tune on it-thats where my confusion was at!!!
Ray
Old 04-07-2003, 09:10 AM   #3144
RC Nitro's Avatar
That is actually the tower for running foams. Otherwise you need to run longer shocks in the front. I run this on myself, great when your tires are 58mm or less.
RC Nitro is offline   Reply With Quote
Old 04-07-2003, 09:13 AM   #3145
rc-zombies's Avatar
Running longer shocks will work...but I use the shorter shock bodies... this will alow me to keep the same droop settings.
Ray
I think all there shock towers are called Ultra-tune...
the lower shock tower has 4 shock mounting holes vs the 3 found on the C-hub tower...
Old 04-07-2003, 09:17 AM   #3146
RC Nitro's Avatar
Zombies, I agree. Ran the longer springs (rear) prior to this tower coming out. Would run out of negitave suspension travel w/o this tower ~ 56mm or less.
Old 04-07-2003, 09:23 AM   #3147
rayhuang's Avatar
guys,
Yup-I am almost out of threads on my front shocks now as my foam tires are starting to dip below 2.25"!!!!
I finshed the race day yesterday at 4.5mm ride height and 0.5 front droop on gauge. And-like I said-to achive 4.5mm-I am almost out of threads to tighten down the shock collars. But this is with the shorter AE Purple springs. I have the Xray springs coming.
Man-OH man do I need that front sway bar. When the traction came up-car was overly planted. I stood shocks up-but it wasnt enough.
Ray
Old 04-07-2003, 09:27 AM   #3148
rc-zombies's Avatar
guys,
Ray
the bladed sway bars are nice...but I still like the wire sway bars...
the rear sway bars will work up front too.
Old 04-07-2003, 09:47 AM   #3149
RC Nitro's Avatar
Ray: Temp fix is to screw out the lower shock eyelet ~ 1mm 2 thread. This will give you enough more lenght with the longer springs to run the stock tower till you get the new. That is what I had to do.
Old 04-07-2003, 09:55 AM   #3150
J_Longbrake's Avatar
Trader Rating: 20 (100%+)
Can you post a pic of the installed rear sway bar on the front? Is this with the c-hub suspension? The only way I see to mount the links is on the back of the lower arm, which limits the steering travel? I must be missing something?
Ray, how did sunday go? I had some friends come in from out of town on saturday, and it turned in to a looooooong night.
J_Longbrake is offline   Reply With Quote
